Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW Touareg TDIs
VW Touareg TDIs This is a general discussion about Touareg TDIs. Non TDI related postings will be moved or removed.
Old April 19th, 2012, 18:41   #1
tek4tex
TDI(s): 2001 Jetta
Default Oil Change
I took my 2011 TDI Sport in for an oil change at 3,500 miles. Previously I had purchased a real dip stick to get a more accurate oil level reading. I explained that I wanted to make sure the level was exactly on the full mark so the reading on the dip stick could be referenced. The dealer added 8.8 quarts, I thought capacity was 8.3? Is that liters maybe? The bad part was paying $143.00 for the filter, oil plug gasket, and oil. Is this an average charge?
How does the electronic meter work? The manual directions are worthless. The dealer is claiming that the oil meter level does not register if the oil is at the full mark only displaying the oil level okay message. I could swear the meter used to read a level?
tek4tex is offline   Reply With Quote
Old April 20th, 2012, 07:27   #2
grohgreg
grohgreg's Avatar
Fuel Economy: ~36 highway, 31 long term
The dealer is fulla crap. Just put your keyfob in its slot and let the computer boot up. Once the computer is up, press the CAR button. Turn the keyfob to the left and release. That will enable the SERVICE selection on the touchscreen. Touching the SERVICE box will display the oil level display.
Can't be certain without actually consulting the manual, but I think it's 8.3 engine + 0.5 filter = 8.8 total.
Too bad you had to pay though. Wouldn't it have been simpler just to buy the dipstick, then top up the oil level yourself? I've got nearly 13k on mine, and have had it in twice for scheduled inspection/service. That included topping off all fluids (90 day inspection) and a complete oil/filter change (10k service). So far I haven't paid a penny.
//greg//
grohgreg is offline   Reply With Quote
Old April 20th, 2012, 08:46   #3
Niner
duplicate account, banned
//greg//
They want your car in for check ups, and 10, 20, and 30k so they can pull data off your cars memory. Nothing is free these days.
Niner is offline   Reply With Quote
Old April 20th, 2012, 08:57   #4
Niner
9 liters of oil at $8.50 each, a filter at what, $20, that's $98 in parts, plus tax on material, plus .5 hr for labor, at $120 an hour. Do the math.
Read the owners manual, go what ever it says to go before oil changes, and service it when the manual says to... the first 30,000 miles with oil, filter and adblue are on VW. Also, make sure at 30k, they change your brake fluid.
This isn't a Honda or a Toyota for service prices or parts, it's a luxury SUV with a luxury tax by Vw to keep it running and maintained.
Old April 20th, 2012, 09:10   #5
tditom
Fuel Economy: Golf: 54/48/43.5 B4 Passat: 52/48.5/45 B5.5 Passat: 30 mpg mixed
Guys- my apologies. For some reason I thought you were discussing the Jetta Sportwagon. I will delete my irrelevant posts.
tditom is offline   Reply With Quote
Old April 20th, 2012, 11:32   #6
grohgreg
grohgreg's Avatar
Yeah. And what tics me off is that they reset the long term mileage memory. I wanted to maintain an onboard record of what kind of fuel economy I'd experienced since purchasing the vehicle new. That sort of thing comes in handy when you want to trade/sell the damn thing. The boneheads reset the long term to zero at the 10k service. So now I've got a car that's nearly a year old, yet now has a long term trip memory based upon <13k
//greg//
Old April 20th, 2012, 11:55   #7
Plus 3 Golfer
Plus 3 Golfer's Avatar
//greg//
Doesn't the Touareg's MFD long term memory reset after 9999 miles, 99 hours 59 minutes, or 999 gallons of fuel like my 2009 does? If it resets, it should be in your owner's manual.
Plus 3 Golfer is offline   Reply With Quote
Old April 20th, 2012, 20:58   #8
Trooper81
Fuel Economy: 72 MPG Record for 00' TDI
Your dealer is cheap mine charges 250 for an oil change. Which is why i do every second one myself for less than 100, with better oil.
Trooper81 is offline   Reply With Quote
Old April 20th, 2012, 21:49   #9
Niner
What better oil is that? is it available in the USA?
Old April 20th, 2012, 22:45   #10
Trooper81
Lubro moly Top Tech 507.00 yes should be available in the US.
http://lubromoly.com/liquimoly/web.n..._usa_home.html
Old April 21st, 2012, 08:14   #11
Niner
Which version are you running in the summer time?
Old April 30th, 2012, 03:35   #12
showdown 42
TDI(s): 2012 touareg
Hi TEK, Why did you have an oil change at 3500 mi ?, You get free oil service for 3yrs 36k miles . These engines need to break in with the first oil the car comes with. The dealer should have given you better advice. My dealer wouldn't chang mine if I came in at that mileage . JP
showdown 42 is offline   Reply With Quote
Old May 1st, 2012, 18:00   #13
abtmuda
abtmuda's Avatar
It has been proven by independent oil analysis (member on the forum) that oil had substantial breakdown and needed to be replaced on the 3L Diesel engine at around 5k marker.
I replaced my own oil at 4,700 miles since I am planning to drive the car for a long time.
it was a messy process...
abtmuda is offline   Reply With Quote
Old May 1st, 2012, 21:57   #14
Trooper81
4200 top tech
Old May 3rd, 2012, 17:12   #15
Fourdiesel
Fuel Economy: ~53 mpg on Golf (sold)
snip
That is a surprising result! Do you have a link to a post that contains the UOA?
2004 Touareg V10 TDI Colorado Red
Blk 2000 Golf 5spd 2-dr (now grandsons)
Sand Biege 2008 Mercedes GL320 CDI (wife's)
'83 Mitsubishi 4X4 PU(2.3L turbodiesel)
'85 U1700 UNIMOG ["I DO understand - its a UNIMOG thing"]
Fourdiesel is offline   Reply With Quote
First Oil Change and Manual Tranny Fluid Change JettaTDI8655 Fuels & Lubricants 5 September 2nd, 2009 12:40
Oil light, after change. Plenty of oil. Oil Pump? Chris NF VW MKIV-A4 TDIs (VE and PD) 6 September 1st, 2008 18:37
Diesel oil change compared to gasser oil change? TDILOVE VW MKIV-A4 TDIs (VE and PD) 20 February 7th, 2005 11:13
What is the difference in price from regular oil change and synthetic oil change? superman477 Fuels & Lubricants 2 September 23rd, 2000 23:44
Oil Change 101 - Determining Oil & Filter Change Intervals Turbo Steve Fuels & Lubricants 6 February 11th, 2000 15:03
Page generated in 0.15907 seconds with 10 queries
[Output: 126.38 Kb. compressed to 105.40 Kb. by saving 20.97 Kb. (16.59%)]
