Old April 19th, 2012, 10:10   #1
coolbean1000
Fuel Economy: 'Don't know yet, still on my first tank. :-)
Default Replace turbo or replace car ('03 jetta tdi)?
Hi - should i replace the turbo or replace the car?
Here's the specifics:
2003 TDI manual, 220,000 miles. (I've had it since 2005/35k miles.) Replaced clutch, timimg belt, tensioner, starter, water pump, intake manifold (due to coke buildup.) The turbo was going into limp-mode, and i gave it about 4 easy-off treatments. it still goes into limp mode at 3-4-5th gear at 100% throttle. (So i don't use 100%) Compression is good; engine has been well maintained with synthentic oil changes every 5k miles. I like this car and would prefer keeping it, but...
The question(s):
How much should replacing the turbo cost (assume rebuilt turbo from rothenbacher Engineering/hansautoparts.com out of N.Carolina)?
Does the motor need to be pulled to replace turbo?
What should the total cost be (Southern NJ) to replace the turbo?
What should i consider replacing while the engine is apart?
Thank you all in advance for any guidance!
Phil
What other things
coolbean1000 is offline   Reply With Quote
Old April 19th, 2012, 10:16   #2
Lex4TDI4Life
Lex4TDI4Life's Avatar
Originally Posted by coolbean1000 View Post
....How much should replacing the turbo cost (assume rebuilt turbo from rothenbacher Engineering/hansautoparts.com out of N.Carolina)?....
Haha! If you buy your turbo from rothenbacher, I would advise you to save up for an entire new engine. Search for the name "Prothe" on this site. You should, in no way, buy ANYTHING from this guy. He is known to sell complete CRAP and, btw, our turbos do not take well to rebuilds.
In my opinionn, IF you need a new turbo, get a real new one from one of our trusted vendors: idparts.com, boraparts.com, kermatdi.com, etc.
Replacing a turbo on these engines is not rocket science. You do not have to pull the engine. Find the username hevster1 on this site. He is a trusted Guru in northern NJ who will do a bang up job on your car.
2001 Golf TDI 5 spd
RC2, Bosch T4-764 injectors, OMI, SBC Stg 2 Clutch, Koni FSDs, TT LCA Bushings, The Mystery Bar, Dieselgeek Panzer Plate, Elephant Hose, DG Race Pipe, Autometer Cobalt Boost Gauge, Boostvalve,Fumoto Valve, Mufflerectomy, Scangauge II
Lex4TDI4Life is offline   Reply With Quote
Old April 19th, 2012, 10:23   #3
apples12
I've got a turbo replacement to look forward to quite soon possibly and my cost will be as follows:
300 for the turbo ~480 USD
34 for the oil line ~50 USD
12 for exhaust gasket ~12USD
3 for EGR pipe gasket
8 for intercooler pipe o-rings
then its just labour cost on top of that, i was told by my mechanic it would be a day and halfs job as they pull out the intercooler and all the intercooler pipework when replacing a turbo and flush everything to get all the oil out, check everything for leaks before re-installing with new seals where necessary or if they're 'cheap' i.e. only a couple of pounds (or dollars in your case)
and if you like the car...replace the turbo and keep on driving, you've replaced most of the major wear items apart from the suspension and DMF so it should be good to go on for another 220,000 miles! but diagnose why the turbo's gone bad first though...
(the exchange rate is just a google estimation.lol. i've only really put the prices up as you requested cost, its moreso to give you an idea of what i'd be changing when i get mine in for its turbo change soon)
apples12 is offline   Reply With Quote
Old April 19th, 2012, 10:26   #4
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
Rothenbacher = NO EFFING WAY!
Turbo replacement is not a complicated job, and certainly doesn't require engine disassembly or removal.
Before you replace the turbo, you need to troubleshoot the entire system to find out WHY it's going into limp mode. I would hate to see you put a new turbo on and have the same limp mode problems due to a bad sensor, vacuum leak, clogged intake manifold or something of that nature.
There is a great turbo troubleshooting HOW TO in the HOW TO sticky at the top of this forum.
Trusted TDI Mechanics Map || TDIClub Chat
Old April 19th, 2012, 10:36   #5
bluesmoker
bluesmoker's Avatar
Fuel Economy: 57 highway mpg
prothe? seriously?
2004 pd 5 speed tip,malone tuning stage 1.5 with egr delete
former:1998 red jetta 5 speed man, malone tuning stage 1 with egr delete (it still lives in Maple Ridge)
new gas guzzler: 2001 Mercedes Benz Ml 320
bluesmoker is offline   Reply With Quote
Old April 19th, 2012, 10:48   #6
Frans
TDI(s): Golf MK2 TDI
There is no need to pull the engine when replacing the turbo.
5k miles between every oil change is not necessary...
If you need a quality rebuilded turbo, send me a PM. I can make you an offer.
Frans is offline   Reply With Quote
Old April 19th, 2012, 10:50   #7
coolbean1000
Ok, peeps. I get the message on prothe. (glad I posted this question!) I'll search elsewhere for the turbo replacement!
Here's an abbreviated summary of the turbo issue:
-approx 150k miles: relaced intake manifold at stealership (my last visit there) the intake was almost coked shut. cost approx $700 USD.
All the following work was done by a master-VW mechanic who opened in his own shop in S. NJ:
-Approx 170k miles: limp mode and CEL light. error codes (forgot #'s) showed overboost condition. Replace MAF
-Overboost code thrown again. Oven cleaner on exhaust side of turbo.
-195k miles: replaced timing belt to spec. Car ran like gasser: no pre-2k rpm power, but after 2k lots o' power and extended rpm range of power. Cleaned exhaust side of turbo again.
-mechanic adjusted timing belt timing (for free): it turns out one of the other three adjustments was off by 3 degrees. This would cause more smoke/soot. Hence the intake replacement at 150k miles! Cleaned exhaust side of turbo again. Overboost error did not show up for about one month when using 100% throttle.
-fast forward to today: 220k miles. Oil is now coming out of what i think is the egr valve. the oil is coming from turbo, i'm guessing from possible bearings. (this is a guess)
Depending on cost, i'm also open to turbo upgrade suggestions.
Old April 19th, 2012, 11:02   #8
Replace the turbo for sure. If you've had enough of the car, it'll sell better with a fresh turbo. If you like it, keep it, it's got lots of life left.
I'd suggest you go visit Mike Hevner in Columbia NJ. He's probably a bit of a drive for you but well worth it. He'll do the turbo work and sort out any other issues the car has as a result of the dealer's loving care.
2002 Jetta wagon, 362K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 257K; 2011 335d, 56K; 2015 Golf Sportwagen, 8K. Principal, http://www.idparts.com
Old April 19th, 2012, 11:36   #9
runonbeer
Maintenance EnthusiastVendor
Fuel Economy: amazing/excellent/still pretty good
New turbo: $1500 installed. At 220K that's around $0.0068/mile
It also sounds like you could use a new mechanic. Talk to this guy: hevster1
runonbeer is offline   Reply With Quote
Old April 19th, 2012, 11:42   #10
That's who I'm talking about.
Old April 19th, 2012, 11:52   #11
runonbeer
Yeah I just realized we both basically said exactly the same thing.
Old April 19th, 2012, 11:53   #12
runonbeer
BTW, I just forwarded that VIN/mileage stuff to you.
Old April 19th, 2012, 11:55   #13
Got it, thanks.
Old April 19th, 2012, 11:57   #14
n1das
n1das's Avatar
Fuel Economy: Who cares? It's a DIESEL! Great fuel economy comes as a bonus!
Exclamation
The intake manifold did not need to be replaced, just cleaned, and can be done for a lot less than $700.00. It's not that hard to do it yourself.
Based on all the other info you posted...you need a new mechanic. Best to go to a TDIclub GURU in your area. Go to hevster1 like others have recommended.
Replace turbo if needed. It may just need a new actuator and not a whole new turbo. Then keep the car. 220k miles is nothing on these cars provided the car has been properly maintained.
Good luck.
David Sterrett, N1DAS
2014 BMW (F10) 535d XDRIVE M-Sport, 255hp & 413 lb-ft of AWD stomp 'n go fun!
2012 BMW (E70) X5 XDRIVE35d, 265hp & 425 lb-ft of AWD stomp 'n go fun!
Member SSBMWO
Why DIESEL is better:
http://webpages.charter.net/lmarz/emissions.html
http://webpages.charter.net/lmarz/efficiency.html
http://webpages.charter.net/lmarz/performance.html
http://webpages.charter.net/lmarz/emissions2014.html
http://webpages.charter.net/lmarz/emissions2016.html
n1das is online now   Reply With Quote
Old April 19th, 2012, 12:20   #15
coolbean1000
Hey these are really good replies. In all fairness to the mechanic, he did quote me $1500 to replace the turbo, stock. He also did the oven cleaner bit at my request. (it was a journey of diagnostics to understand why the turbo was going into limp mode...this forum helped with the ovencleaner suggestion which allowed my to get by for two years of improved performance while putting off the turbo replacement for 50k miles.)
The dealer was the one that suggested replacing the manifold, stating that the labor to clean it was cheaper than replacing the manifold. After that BS is why i don't go there any more. It's also the dealer that did the first timing belt change with the 3 degree error, at 80k miles. (which really sucked to find out)
I kept the manifold when it was replaced, and cleaned it out and will stick that in when the turbo is replaced.
Columbia is 2.5 hours each way, otherwise I'd go there. The mechanic I'm using is local, and helped diagnose in an efficient manner. I didn't convey that in my summary, but he did.
I checked out prices on the two options for upgrades on IDParts.com and decided i'll stick with stock.
Are there any other recommended maintenance items such as a head gasket or anything I should consider while having the turbo done?
Thanks - this conversation so darn useful!
turbo leaking oil - 03 ALH - how long to replace?? Diesel Mania_26 TDI 101 26 September 2nd, 2014 03:32
Just replace auto flyweel in 06 Jetta tdi brm - now car won't start! ServiceManager VW MKV-A5 Golf/Jettas 14 February 1st, 2012 21:42
How to replace truck latch on 03 Jetta? pamike TDI 101 2 October 30th, 2009 13:28
'03 Jetta: Replace Glow Plugs? Mass. Wine Guy VW MKIV-A4 TDIs (VE and PD) 26 March 13th, 2008 20:17
Page generated in 0.17208 seconds with 10 queries
[Output: 134.24 Kb. compressed to 112.71 Kb. by saving 21.53 Kb. (16.04%)]
