TDIFest 2013 Registration is now open!
Old April 18th, 2012, 18:02   #1
countryboy5960
Default 1996 vw passat tdi
hi i own a 1996 vw passat tdi and its always going into limp mode and having a lack of power going up hills until going into limp mode car runs good and has plenty of power... was wondering if i could get some ideas on what to check that might be wrong or bad as i am sure more then just myself has come across this... thought of ordering a new turbo but not so sure that it would fix it since it works good until it kicks out going up hills thank you very much
countryboy5960 is offline   Reply With Quote
Old April 19th, 2012, 07:05   #2
Abacus
Abacus's Avatar
http://forums.tdiclub.com/showthread.php?t=75959
'97 B4: 434,000 miles RC2+, PP520's, Stage 2 cam, SBC3, ARP studs, Westach EGT/Boost, Koni Reds/Yellows, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR, Evo plate, leathers, 16" MSW's
'96 B4V: 311,000 miles Wettenauer Chips, PP520's (on the shelf), Scangauge, Bilstein TC's
'96 B4 (wife's): 205,000 miles Sprint 205's, Bilstein TC's, RC3+ on the shelf
HEX-USB-CAN Vag-Com, A3/A4/B4 timing belt tools & manuals, IP socket, alt & specialty tools.
Abacus is online now   Reply With Quote
Old April 19th, 2012, 17:51   #3
countryboy5960
is there one most common problem where is would be best to start
Old April 19th, 2012, 17:57   #4
OntarioVW_TDI
Best place to start is figuring out what code your cars putting out when it goes into limp mode
OntarioVW_TDI is offline   Reply With Quote
Old April 19th, 2012, 18:03   #5
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: Which VW diesel? There have been Twelve of them!
My experience (and mine aren't all inclusive) is to view the guide to which Abacus linked in post #2, scroll down to item 2, and then 2G with the N75.
Your described symptoms are all too familiar and are signs of poor boost pressure / wastegate control. Check the red and blue hoses between the turbo and the N75 valve paying attention to the integrity of the hose ends. If you don't find an torn or holed hose, replace the N75 valve.
Don't bother trying to clean it, it will work for a few weeks at best, and it's cheap to replace.
And I just saved you $1400.00.
That's how much a dealer charged me for a bad turbo they diagnosed on my first Passat. And that didn't fix the problem. Cutting a bad inch off a hose and putting on a $0.05 worm clamp did.
Svante Arrhenius 1896
Old May 27th, 2012, 14:47   #6
MMAXX
I had the problem a year or so ago. My 96 TDI would go into limp mode every time I had it in a hard pull up an incline requiring more boost for more than 10 or 12 seconds. I would have to depress the clutch, turn the switch off, then restart. This would reset the computer. Scans would not show a problem other than over boost. The problem was a dirty intake. After scraping the gunk out and allowing it to breath, it has not gone into limp mode since. Running strong @ 282,000.
MMAXX is offline   Reply With Quote
Old May 27th, 2012, 14:58   #7
loganbmx4gt
loganbmx4gt's Avatar
As the others have stated, I would look into the intake and see if it needs cleaning. Then replace the N75 and vacuum lines also. Do you have vagcom or able to get to somebody that can scan the car for you? Here is the Vag-Com locator if you don't have it.
Middle Tennessee G2G March 30th
Passing through West TN and need help or want to hang out? Call/Text my Google Talk # (937) 505-0829
loganbmx4gt is offline   Reply With Quote
Old May 31st, 2012, 05:07   #8
97Jedi111
Fuel Economy: 50 mpg
Default limp mode fix (Maybe, worked for me)
Are you getting a code? I had the same problem and I found it was the vacuum line going to the ecm was not hooked up at all. My code was charge pressure deviation...I think p1550. I have a jetta so Im not sure if the ecm is located in the same spot on your passat. Mine is on the passenger side underneath the panel near the passenger wiper blade. hope this helps
97Jedi111 is offline   Reply With Quote
1996 vw passat tdi countryboy5960 TDI 101 1 April 12th, 2012 07:38
1996 VW Passat TDI LumberJack5500 VW MKIII-A3/B4 TDIs 152 September 10th, 2009 08:49
1996 VW Passat TDI $1750............ dariod TDI Cars for Sale/Wanted 0 June 2nd, 2009 08:23
FS: 1996 VW Passat TDI 914rrr TDI Cars for Sale/Wanted 10 December 16th, 2008 06:54
1996 VW Passat TDI Wagon IrieMoeTDI TDI Cars for Sale/Wanted 16 May 22nd, 2006 12:19
Page generated in 0.15152 seconds with 10 queries
[Output: 86.21 Kb. compressed to 74.16 Kb. by saving 12.04 Kb. (13.97%)]
