Old April 2nd, 2012, 09:33   #1
Z32driver
TDI(s): 99 beetle
Default 99 beetle stuck rpm after timing belt
Ok so I do lots of car stuff but this was my first diesel. My injection pump started leaking very bad at the rotor. So I got a new timing belt and rebuild kit for the pump. Pump went smooth and everything installed nice, got the timing belt on, check the timing three times after rotating the engine a few times. All dead on. Bled the lines up to the injectors. Bam started right up, but it goes to max rpm. I tried starting it a few times and it did the same thing every time. I never let it stay at rpm I shut it off asap. Before all this the car ran great just sprayed fuel everywhere... Help!!!!
Z32driver is offline   Reply With Quote
Old April 2nd, 2012, 09:56   #2
BobnOH
Fuel Economy: 50/45/35
I'll take guess maybe the quantity adjuster is out of position.
What parts were done with rebuild?
Note- I've never been inside one of these pumps.
Old April 2nd, 2012, 11:22   #3
jettawreck
jettawreck's Avatar
I'm with Bob in that I've never been inside the IP (and hope to keep it that way) but his "guess" is the same as mine.
2004 Cadillac SLS (wife's)
Old April 2nd, 2012, 17:22   #4
hevster1
TDI(s): 98 NB
Fuel Economy: 40-42
Just an FYI, I have 30 years experience in the industry. I do not do pump rebuilds. I send them to DFIS or get re-man VW.
NJ's best shop performing Quality Repairs on TDI's, Toyota, Lexus, Scion and other European and Asian cars as well as Motorcycles & ATV's. Written warranty, reasonable prices. ASE L-1 & A-9 Master re-certified. NEW LOCATION: Montague NJ. Hunter Wheel Alignment. Snap-on Tire Service.I don't need to have specials, my prices are better already!
www.mmautocycle.com
hevster1 is offline   Reply With Quote
Old April 2nd, 2012, 19:48   #5
Alchemist
I suspect that when you put the Quantity Adjuster back on the pin didn't engage the hole in the sliding collar. The position of that collar is what determines how much fuel is injected. If it is off one way, there will not be enough fuel and no throttle control. If it is off the other way, you will be stuck at max. The other possibility is that the QA is so far off that it can't control fueling. You did mark its position carefully before removing it, didn't you?
Paul
04 Golf, Evo skidplate, South Bend SMF and Stage 3 clutch, ventectomy, 156K miles, RocketChip tune
94 Jetta AHU Conversion, My winter car 99 Ranger about to be TDI
VCDS, Heated shop with hoist
Alchemist is offline   Reply With Quote
Old April 3rd, 2012, 06:08   #6
jkaiser
TDI(s): 2002 jetta
I would pull the cover and verify you have the pin in the hole.
jkaiser is offline   Reply With Quote
99 Beetle timing belt replaced, now engine light on h20falls VW MKIV-A4 TDIs (VE and PD) 6 June 15th, 2011 09:23
99 beetle timing belt newbeetle99 TDI 101 5 February 14th, 2011 19:46
Annoying Stuck bolt/Timing Belt B4 9PasCollinsat6 VW MKIII-A3/B4 TDIs 11 July 14th, 2008 03:49
Weird Vibration After New Timing Belt 99 Beetle lolalola62 TDI 101 12 April 28th, 2008 19:09
99 or 99.5 Beetle for timing belt tools barney5116 TDI 101 1 November 18th, 2007 22:31
Page generated in 0.12547 seconds with 10 queries
[Output: 74.45 Kb. compressed to 65.25 Kb. by saving 9.21 Kb. (12.37%)]
