Old April 2nd, 2012, 06:40   #1
srvblues00
srvblues00's Avatar
Fuel Economy: 19 - 24
Default Swapping ALH to Jeep - power enhancements?
Hello.. I am working on putting an ALH into a 4wd Jeep Cherokee. I do plan on running either 31 or 33" tires. I've been reading and searching for the last 2 nights on here, and I have some ideas on what I want to do. Basically, I want decent power, but nothing overkill that will effect reliability. So, I'm thinking in the neighborhood of 300 lb/ft of torque and whatever HP that works out to be. I want to emphasize low end torque. I don't want to have to run this thing at 3300rpm to keep it moving. I will also be running a larger turbo and a large FMIC in hopes of keeping EGTs under control, and of course, adding some power. However, I don't want to go too large and kill low end spool up time.
Will a GT1749 be too large? Or would a 1722 be a better choice?
Thinking .216 nozzles..
Probably stick with the factory ALH intake manifold, but add a race pipe.
And who is a good place to send the ECM to for immobilizer delete, EGR delete, and tuning to take advantage of the turbo and injectors? So far, Kerma and TDTuning are on the list.
I don't mind paying for quality parts, but I don't want to get into the area of diminishing returns.. I'm not into spending another $1000 for a 10 lb/ft increase! I need to keep it reasonable.. I'm not building a race jeep lol.
srvblues00 is online now   Reply With Quote
Old April 2nd, 2012, 06:54   #2
LNXGUY
LNXGUY's Avatar
The GT1749 is a vnt15 (The turbo that's on the engine in stock form) GT1749VB is the 'VNT17' with 49mm compressor wheel, the 17/22 is the same hotside as the vnt17 but with a 52mm compressor wheel.
I'd probably run a 11mm pump, intank liftpump, PP764's (.232) vnt17 or 17/22 and a good tune.. 300ftlbs would be cake with that setup... Mike from TDTuning has done all the tuning on my cars, I don't plan on switching anytime soon. Guy knows his stuff.
Keep us posted, would love to see some in-progress pics!
Bill
'05 Jetta TDI Wagon
Custom tuned by Mike @ TDTuning.com
LNXGUY is offline   Reply With Quote
Old April 2nd, 2012, 12:44   #3
srvblues00
srvblues00's Avatar
Thanks for the info.. for what I'm trying to achieve, do you think there's a big difference in driveability in the VNT 17 vs 17/22 hybrid?
When I get farther along in my project, I will certainly put up pics! Right now I am just working on the engine. Once I get an engine and trans that bolt together, I'll look for a chassis to put it in. I don't have a lot of room at the moment just to have a non-running jeep hanging out in the way!
Old April 2nd, 2012, 12:55   #4
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
Go with the hybrid.. You won't regret it... Typically you want the engine to be around 2000 at 60mph, especially in a cherokee.. The stock 4.0 5-speed gearing would do just fine.. I'll be doing my wrangler in the near future with the stock 4.10 gearing and 33" tires.. That'll put me around 2500rpm at 60mph.. A little steep but I won't be doing a ton of highway miles so it'll work out fine..
Trusted northeast TDI guru (They tell me I can fix these things)
TDIJetta99 is online now   Reply With Quote
Old April 2nd, 2012, 12:57   #5
Ben Dur
Ben Dur's Avatar
vnt 17 is an OEM turbo option (from other1.9tdis and 2.0tdis) that should give you an idea of its drivability. that being said the 17/22 is also quite drivable. Both are very reliable, especially at that power output. On an ALH the 17/22 is plug and play, while the 17 will require just a few extra pieces. For my ALH project i selected the 17/22 because after adapting the vnt17 i would only save a couple hundred bucks.
Ben Dur has a build thread
Ben Dur is offline   Reply With Quote
Old April 7th, 2012, 21:19   #6
srvblues00
srvblues00's Avatar
Thanks for all the input and suggestions. I think I'm going to save up a few more clams and get the hybrid.
Old April 8th, 2012, 13:59   #7
Whitbread
Whitbread's Avatar
Fuel Economy: mid 40's with mixed spirited driving
Go with a 1756vk over a 17/22. I just installed one on an ALH last week and WOW. I don't think I'll ever install another 17/22. Spools at 1700-1800rpm easily and rips to 5.5K.
By using a passat/afn manifold and adapter plate, it'll get the turbo away from your starter and make that easier to fit.
02 Jetta TDI. Part 2
Whitbread Performance Innovations
-Full TDI performance and custom fabrication services. 248-755-8118. Dealer for SBC, TD Tuning, Wavetrac, Peloquin, Venair, and Vibrant.
Whitbread is offline   Reply With Quote
Old April 8th, 2012, 14:27   #8
NHgranite
NHgranite's Avatar
Yeah, still excited for your kit !!
ALH_'02 Jetta GLS, 5-spd sedan. RC2, Liftpump, PD150 intake, BFI stg 1 (yellow) dogbone, Shine springs&RSB/BilliHD, Audi TT spindles & LCA, 288mm rotars, Raxels, 16x7 rims_225/50R16, DG skid plate, DG oil by-pass filter, euro switch, Hella fogs, 5-brake mod, custom stereo.
NHgranite is offline   Reply With Quote
Old April 8th, 2012, 15:36   #9
loudspl
loudspl's Avatar
TDI(s): 02 ASV
+1 for GTB1756vk
I think "jimbote" is running one of those in his Tacoma
350+ft/lbs shouldn't be a problem with the right nozzles
Should be a wicked setup whatever you end up with. Post pics!
02 Jetta, SBC IV+, ASV110, IE rods, TT springs, monster cam, Whitbread fabrications, B5 oil cooler, DG bypass, B&M ss, FueLab Prodigy pump, Giles 12mm, HFLOX nozzles, remote progressive NX N20, 2260vk, 4Bar, Bilstein coilovers, BFI mounts, Frostheater, Evo skid
70 Charger R/T 500 - restoration project
loudspl is offline   Reply With Quote
Old April 9th, 2012, 19:24   #10
srvblues00
srvblues00's Avatar
Ok, I'm interested... Sounds like what I want for a heavier Jeep with no aero advantages. Where do I get one, and how much? So far, my Google-fu has not resulted in much useful info on this turbo.
Old April 9th, 2012, 21:46   #11
slamhouse
slamhouse's Avatar
Fuel Economy: Better than 95% of cars on the road
Just curious, why not get the liberty CRD and chip it? 200hp and 364ft.lbs. with just a chip! while returning 34mpg!
GDE Tune and Meguiars on the tires
slamhouse is offline   Reply With Quote
Old April 10th, 2012, 05:50   #12
srvblues00
srvblues00's Avatar
I am an ASE tech, and previously worked at a VW dealer. I really like the ALH engine!
Old April 10th, 2012, 06:40   #13
slamhouse
slamhouse's Avatar
Oh i love the thought of a diesel jeep but i couldn't have the patience for a swap. I may just buy a crd...
Old April 10th, 2012, 07:27   #14
TDIJetta99
TDIJetta99's Avatar
What's the price difference between a 17/22 and a 1756vk (vacuum actuated) + manifold?
The 52mm compressor might have an advantage of being able to provide more boost at lower rpm than the 56mm, making it more drivable in a Jeep that gets used offroad.. Not sure how similar it is, but my 2260 HATES making boost under 2000rpm.. No torque at all LOL..
Old April 10th, 2012, 08:13   #15
Lurchalicious
Lurchalicious's Avatar
Fuel Economy: good
depends on where you source the turbo in my opinon - but if you go through ryanp for example - you will pay 775 GBP for the vaccum converted new turbo; manifold will run you 80 GBP and the flange is 40 GBP; shipping is usually 30 GBP - convert all that (as of today on the GBP to USD market) looks like around 1465.
the price is somewhat cheaper for just the turbos w/ manifold - normally the cost changes when putting the 1756vk in an ALH VW because of the custom downpipe, oil lines, gaskets ect. but since you are going in a custom project allready I would get the 1756vk, its newer vane system gives lower EGT's and spools faster. plus I believe it can push more air than the 17/22
02 TR jettaGTB1756VK
02 Golf TDI - sprint 520
Lurchalicious is online now   Reply With Quote
Power enhancements? 01tdiJEtt TDI Power Enhancements 11 January 10th, 2007 14:46
Power enhancements PD130 scottdi70 TDI Power Enhancements 1 May 7th, 2006 13:40
Power enhancements likmywagon VW MKIV-A4 TDIs (VE and PD) 2 April 8th, 2003 19:10
The Best Power Enhancements MiksTDI Jetta/Bora/Vento TDI Picture Gallery 2 February 11th, 2002 11:44
power enhancements hotrodtdi TDI Power Enhancements 0 February 18th, 2000 06:07
Page generated in 0.16576 seconds with 10 queries
[Output: 135.14 Kb. compressed to 113.29 Kb. by saving 21.85 Kb. (16.17%)]
