Old April 1st, 2012, 16:45   #1
Robo48
Default CV joint replacement how to...
I have searched and can't seem to find the information I need regarding CV joint replacement or swapping from one axle to another. Any guru's out there who can help me out? Thank you in advance
Robo48 is offline   Reply With Quote
Old April 1st, 2012, 20:09   #2
Robo48
Nobody knows how to rebuild cv joints/axles?
Old April 1st, 2012, 20:46   #3
cfa5
cfa5's Avatar
Fuel Economy: Great...
I replaced all my half shafts, straight forward job, If you need a video to watch, You tube it, replacing VW mk4 axle. Rebuilding them is messy. New half shafts come with everything you need.
goodluck
cfa5 is offline   Reply With Quote
Old April 1st, 2012, 21:23   #4
Robo48
Where did u source them from?
Old April 2nd, 2012, 15:59   #5
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
Its pretty easy. Inner just has a C clip that comes off and the joint comes right off the shaft. The outer gets hammered off and on. If you take the joint apart, make sure to mark the races before as they have to back the exact same way.
I don't understand why people buy entire axles when rebuilding them is so darn easy.IMO, its harder to get the axle off the car.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old April 2nd, 2012, 16:29   #6
cfa5
cfa5's Avatar
From metalman parts, good service good prices.
goodluck
Old April 2nd, 2012, 18:00   #7
Robo48
Is it ok to hammer the joint back on the axle while its on the car?
Old April 2nd, 2012, 18:04   #8
turbocharged798
Probably not.
Old April 2nd, 2012, 18:14   #9
Robo48
Thats what I figured....
Old April 4th, 2012, 19:05   #10
2002MK4
I know for a fact there is a video how to on You tube somewhere. Doesn't look to be that difficult really.
2002MK4 is offline   Reply With Quote
Old April 4th, 2012, 19:06   #11
2002MK4
Whats the mileage on your car out of curiosity and why the sudden focus on CVs? Did you check them? I had - what I thought - was CVs going. Ended up being strut mounts that were gone.
Old April 4th, 2012, 19:09   #12
deezelpower
deezelpower's Avatar
Fuel Economy: ~40 combined city and highway with spirited driving habits.
Axle boots crack on VW's regularly. Keep an eye on them, replace them as needed, and the axle should last indefinitely. If my axles ever give out, I'll be replacing them with rebuilt ones from raxles ONLY. Almost all aftermarket ones (i.e. <$500 each side) are junk.
2015 Audi Q7 TDI Prem+, Tow, Hot/Cool Pkg, 20", 21K (hers+Twins) acquired 10d before stop-sale!
2004 Jetta GLS TDI 5-sp, Kerma Q, 17" Goals, GLI Brakes, DarkSide SMIC, 214K (mine)
1974 Super Beetle Red
deezelpower is offline   Reply With Quote
Old April 4th, 2012, 19:53   #13
drewtdi
TDI(s): 2002 Wagon
Default Grease?
What brand grease are you guys using when you rebuild? The Vw grease is a bit expensive, is there a suitable alternative?
drewtdi is offline   Reply With Quote
Old April 4th, 2012, 22:28   #14
chewyboy
TDI(s): '00 NB TDI
Here are the two links i looked at when i did mine. It really is an easy job, just messy and time consuming. From my experience definitely mark the cv joint like is shown and i found that keeping the bearings in their correct positions helped out in re-assembly as well. like i said messy and time consuming, most people are just to lazy to do it.
hope these links help
http://forums.vwvortex.com/showthrea...V-Boot-R-amp-R
http://volksweb.relitech.com/cvjoints.htm
chewyboy is offline   Reply With Quote
Old April 6th, 2012, 18:07   #15
Robo48
All suspension parts are brand new. I discovered my outer cv joint didn't have the retainer clip on it when I was doing my wheel bearings as it slid off the end of the shaft and only the boot was holding it on the axle. I thought maybe the clip had come off inside the joint but I searched inside the cv boot with a magnet and couldn't find the clip. So I'm assuming its not in there and hasn't been. I thought it was probably time to reboot grease and reassemble the right side. CV joints seem to be quiet no vibration or anything so thinking they are good?
Is there a CV Joint replacement "HOW TO? STRANGETDI TDI 101 29 July 30th, 2011 07:08
Inner CV joint replacement 2-Stroke Freak TDI 101 10 March 17th, 2010 20:08
CV Joint Replacement ttzuke44 TDI 101 4 July 30th, 2008 10:33
CV joint replacement? wakeboarder_shawn VW MKIV-A4 TDIs (VE and PD) 6 June 16th, 2006 14:55
What is involved with a CV Joint Replacement? STRANGETDI VW MKIV-A4 TDIs (VE and PD) 4 April 30th, 2005 15:35
Page generated in 0.14821 seconds with 10 queries
[Output: 122.30 Kb. compressed to 101.80 Kb. by saving 20.50 Kb. (16.76%)]
