Old March 31st, 2012, 05:20   #1
germ
Default Flat towing a Passat
Anyone know if you can flat tow a manual transmission Passat behind a motorhome?
germ is offline   Reply With Quote
Old March 31st, 2012, 06:02   #2
kjclow
Fuel Economy: 55 max / 44 avg on beetle ~37 on JSW
Check the owners manual. IIRC, my JSW with the dsg does not recommend flat towing for more than emergency issues. There's a release inside the shifter box that has to be moved for flat towing.
2010 silver/black JSW TDI with DSG, 2011 red Golf TDI with dsg, 2003 red/gray Passat 1.8l gasser
kjclow is offline   Reply With Quote
Old April 1st, 2012, 05:28   #3
Rico567
The best solution may be one of those "dolly trailers" with just a pair of wheels that keeps the drive wheels of your vehicle off the ground.
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is offline   Reply With Quote
Old April 1st, 2012, 17:23   #4
r11
A good story about how not to tow stuff: me and a few buddies were on our way to a local pizza place for lunch. We see a cop and a tow truck trying to get an Audi A4 from a tight parking spot, owner absent ... guess unpaid tickets etc.
Minutes later as we wuz enjoying our slices, the A4 is towed in the front of the joint, front wheels off the ground, the rear wheels skipping and jerking like crazy, as they certainly destroyed the tranny and/or transfer case in that Quatro equipped car. $6K in damage ?
r11 is offline   Reply With Quote
Old April 1st, 2012, 17:46   #5
skark_burmer
Manual trans, no problem
skark_burmer is offline   Reply With Quote
Flat towing a 2004 Jetta TDI stick trans? Hank Folk TDI 101 29 February 9th, 2018 06:50
Flat-Towing a '10 JSW TDi 6M?? SANman VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 7 May 22nd, 2013 14:43
Flat towing a 10' Jetta tdi 6 speed MT Jim Karns General VW Discussion 1 February 10th, 2011 11:57
Flat towing another car with B4, can it be done? 914rrr VW MKIII-A3/B4 TDIs 9 October 1st, 2008 00:42
Flat towing? mavapa VW MKIV-A4 TDIs (VE and PD) 8 November 9th, 2006 10:55
Page generated in 0.14735 seconds with 10 queries
[Output: 67.47 Kb. compressed to 59.49 Kb. by saving 7.98 Kb. (11.83%)]
