Go Back   TDIClub Forums > VW TDI Discussion Areas > Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc)
Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) Discussions about alternative fuels for use in our TDI's. This includes biodiesel WVO (Waste Vegetable Oil), SVO (Straight Vegetable Oil), BTL (Biomass to Liquid), GTL (Gas to Liquids) etc. Please note the Fuel Disclaimer.
Old March 26th, 2012, 10:41   #1
Kai
Fuel Economy: about 40 mpg, mixed city & highway; on B100
Default 2012 Passat TDI and biodiesel
Anybody running biodiesel in the new Passat TDI? If so, what blends are you using and with what success? My VW dealer gave us a new Passat loaner car (gas & DSG) and my wife and I really like it. Of course, we'd order a TDI with manual trans.! Thanks.
Kai
Kailua, Hawaii
2004 Jetta TDI wagon, candy white, B20-B100
2006 Jetta TDI sedan, north sea green, B20-B100
Kai is offline   Reply With Quote
Old March 26th, 2012, 11:13   #2
Knarrly Viking
Knarrly Viking's Avatar
B5 is all the warranty currently allows. I'm hoping for a change in the warranty to allow higher % and for greater availability of it.
Knarrly Viking is offline   Reply With Quote
Old March 26th, 2012, 12:59   #3
Kai
If it's the same motor and emission system as in the 2009+ Jetta TDI, those cars have been successfully running B20 since the beginning. There are still some experiments going on with B100. I wrote to the new CEO of VWofA and his assistant told me that VW is considering raising the bio. blend limit for their TDIs. Some states like Minnesota, I believe, are mandating higher limits than B5 at the pump. So if VW doesn't raise their allowable limit, they will be in an awkward position in states where B5 or less blends are no longer available. How can you sell a car in Minnesota if you can't buy fuel for that car there?
Kai
Kailua, Hawaii
Old March 26th, 2012, 19:41   #4
donDavide
donDavide's Avatar
Fuel Economy: 51/45/40
It is not the same emissons system, it has Urea/Adblue or ever you want to call it. But B5 is the limit for now. Higher amounts could ruin DPF, not cheap to relpace. Read The Forum and you will find more info. I have not seen many run B20 in CRs, (09+)
2003 Jetta GLS TDi TTbushings
2005 Passat GLS TDI Wagon Stone Henge Gray
2007 Jeep Grand Cherokee CRD
donDavide is offline   Reply With Quote
Old March 27th, 2012, 04:46   #5
740GLE
higher bio than B5 won't ruin the DPF, it'll dilute the engine oil. Keep searching and reading.
Old March 27th, 2012, 11:00   #6
CsTDI
Fuel Economy: T2: 25-26avg/A6: 49
so maybe instead of "ruin" the DPF, to paraphrase VW, it will cause premature expiration of your DPF... as well as oil dilution
'10 TouaregTDI, Campanella White, '15 JettaTDI, Platinum Gray, '11 GolfTDI, Blue Graphite (buyback), '01 JettaTDI (retired), '05PassatTDI (totaled), '06 TouaregTDI, Campanella White (retired)
CsTDI is offline   Reply With Quote
Old March 27th, 2012, 12:02   #7
Kai
I have not seen many run B20 in CRs, (09+)[/QUOTE]
Over the past few years several TDI club members with Jetta CR's (09+) have reported running successfully on B20. TDIsky is one. Check out his posts. If I bought a CR I would start with B20 and run nothing less. We have B20 pumps on Oahu, so it's easy.
I didn't realize the Passat had a different emissions system. Thanks.
Kai
Kailua, Hawaii
Old March 27th, 2012, 12:42   #8
740GLE
How? does it create more ash when doing a regen? can you not get it as clean?
There's a study posted a while back 2006-7 or so, stating the use of high Bio content will actually reduce the temps at which a passive regen is initiated.
Old March 27th, 2012, 12:54   #9
CsTDI
From experience, I would question the 2006-07 study if it is suggesting by lower temps. that it is fine. Then maybe active regeneration is the issue and it rags it out quicker or clogs? All I can tell you is that DPF backpressure issues occur with B20 and very frequent regenerations. The dealer tech showed me something from VW that said >B5 or LSD would cause "premature expiration" of the DPF. Only ULSD and BD was used
Old March 28th, 2012, 04:45   #10
740GLE
http://forums.tdiclub.com/showthread...iodiesel+study
I haven't heard that Bio will cause clogging from any VW technical paper but i'd be sure interested in reading it. I've put on about 40K using B5.
Old March 28th, 2012, 12:46   #11
TomB
Fuel Economy: 34 mpg on first tank
I would suspect that BD produces less Particulate matter therefore less clogging of the DPF, but then the lower combustion temperature of BD would mean less effective regen cycles when it runs them. Hence not as much clearing as expected. As well the ethyl/methyl esters could cause reactions with the surface material of the dpf too so who knows for sure.
2007 Jeep Grand Cherokee 3.0L MB Diesel
2012 Passat TDI SEL Premium Opera Red/Titan Black
2015 Audi A3 TDI Prestige S-line Lotus Gray Metallic/Black Leather
TomB is offline   Reply With Quote
2012 Passat TDI ~ urea injection & BioDiesel questions Melensdad VW Passat Family (NMS and B7) TDIs (2012+) 25 March 9th, 2012 14:10
2012 Jetta TDI vs 2012 Passat TDI mspropst TDI 101 20 March 5th, 2012 10:14
Comparison: 2012 Sonata Hybrid vs 2012 Camry Hybrid vs. 2012 Passat TDi F8L VW Passat Family (NMS and B7) TDIs (2012+) 22 February 26th, 2012 08:33
Can you clarify the diesel/biodiesel on 2012 jetta tdi for me? dieselinchicago Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 4 January 6th, 2012 13:38
2012 Passat at SEMA Show 2012 Kchorro VW Passat Family (NMS and B7) TDIs (2012+) 1 November 2nd, 2011 15:11
Page generated in 0.11902 seconds with 10 queries
[Output: 105.36 Kb. compressed to 89.04 Kb. by saving 16.32 Kb. (15.49%)]
