Old March 22nd, 2012, 11:24   #1
Oleolson
TDI(s): 2003 Jetta
Fuel Economy: 50mpg on a good day
Default Changing thermostat in a 2003 jetta tdi?
I have been looking for video of how-to change a thermostat in my 2003 tdi getta, Only finding gas ones on you-tube. Does any one have a or know of link? Or any other helpfully ideas for changing the thermostat??
Thanks, Ole
Oleolson is offline   Reply With Quote
Old March 22nd, 2012, 11:36   #2
jcrews
jcrews's Avatar
TDI(s): 2003 Golf
It's very easy. Get a new thermostat with o-ring, preferably genuine/OEM.
Place a catch pan under the radiator and open the drain by twisting it and pulling it out until it stops. Open the overflow reservoir cap to speed up draining. Close the radiator drain once the water stops draining Use spring clamp release pliers to release a hose from the oil-water heat exchanger below the oil filter housing. Replace the hose once the water stops draining.
You can skip the above if you put a large catch pan under the engine and allow the water to spill out of the thermostat housing, but it will make a big mess.
Just below the injection pump, remove the plastic water nipple from the water pump housing on the engine block using a 10 mm 1/4" drive socket and long (6 inch) extension. Carefully try to release the nipple from the thermostat by twisting it.
Clean the sealing surface on the engine with a rag.
Install the new thermostat and seal in the nipple. There are two tabs that hold the thermostat in place. If those are broken, remove any loose pieces and use a loop of string or wire to hold the thermostat in from the open end. The string or wire will be removed once the nipple is secured in place with the screws. Do not overtighten the screws.
Yard sale - misc. mk4 TDI parts.
jcrews is offline   Reply With Quote
Old March 22nd, 2012, 11:53   #3
jettawreck
jettawreck's Avatar
Yep, follow the above steps, it doesn't get much easier.
Oh, one thing. I recommend an OEM stat. I've tried a few others and so far haven't been happy with any except 1 out of 2 Wahler (which isn't good average). The OEM ones are about the only ones that work with the clips/tabs in the coolant flange. They aren't neccessary, but do make it a bit easier.
2004 Cadillac SLS (wife's)
Old March 22nd, 2012, 11:56   #4
Oleolson
TDI(s): 2003 Jetta
When you say seal in the nipple, what type of sealint should I use?
Thanks, I take a look and see if I can figure that out, would be really nice if you new of a video...I could watch...anyway I'll take a look..Thanks!
Old March 22nd, 2012, 11:57   #5
Oleolson
TDI(s): 2003 Jetta
OK...thanks for the Tip!
Old March 22nd, 2012, 18:35   #6
jcrews
jcrews's Avatar
TDI(s): 2003 Golf
It's just a rubber o ring that comes with the thermostat.
Old March 22nd, 2012, 21:08   #7
DieselOx
DieselOx's Avatar
Fuel Economy: 42/46/51
Make sure the o ring is outside the t stat, under the housing.mine stock to the block and I thought thats where it went, took days to finally figure out.
Also, got my stat from napa, made in france, fit the clips, 17 bucks, works great.
2012 Subaru OB 2.5i 6-sp, all weather package; 53,000 mi 26 mpg
1986 FJ60 Landcruiser, (Ursa Major), 165,000mi, rusty fenders, leans to the left. 75-95 mpg, inc bike to work miles 3 seasons
gone:
2003 Dodge Ram 2500 Cummins Diesel
2000 Black Golf 5-speed TDI
DieselOx is offline   Reply With Quote
Old March 23rd, 2012, 07:20   #8
jettawreck
jettawreck's Avatar
That's interesting. The one I got from NAPA was a US made Stant brand (didn't fit the clips) and it was "rated" at 195F but I had to remove it as it was running up over 205 (and climbing, even with the cabin blower fan running full tilt) in the warmer 60* temps.
Old March 23rd, 2012, 09:58   #9
jcrews
jcrews's Avatar
TDI(s): 2003 Golf
G12++ (or G12) is $21 at the dealership for 4L concentrate. Mix about 60/40 with distilled water to make 6 L.
Changing thermostat alloutdoorsboy VW MKIII-A3/B4 TDIs 2 February 19th, 2012 18:58
Changing Thermostat MG ClearTDI TDI 101 25 October 6th, 2008 15:25
2003 Jetta Wagon & Engine Thermostat Problems jollypair TDI 101 4 February 5th, 2005 14:57
Changing Thermostat on 98 Jetta Secret Squirrel VW MKIII-A3/B4 TDIs 8 October 14th, 2003 08:47
Page generated in 0.13294 seconds with 10 queries
[Output: 96.65 Kb. compressed to 83.22 Kb. by saving 13.43 Kb. (13.90%)]
