Old March 21st, 2012, 06:44   #1
Rudolph Rajendra
TDI(s): New Beetle
Default VW TDI Manual Gear Shift Problem
Is there an irreversible problem that occurs with Volkswagen manual transmissions as they age? Or the hydraulic system?
The manual transmission has started to miss shift in the last few years after I had it in for a brake bleed at the Pickering VW Dealer. So far the ABS unit has been replaced twice, the brake master cylinder has failed dangerously, and no dealer has been able to solve the transmission problem. Is there a simple fix? Does this happen to all VW manual transmissions after a few years?
Rudolph Rajendra is offline   Reply With Quote
Old March 21st, 2012, 09:46   #2
gforce1108
gforce1108's Avatar
Fuel Economy: Jetta: 44.5 summer / 47 on snows
What year is your beetle? The earlier ones had a different shifter than the later ones. The plastic guide had worn out on mine and replacing it made a major improvement. Here is the part for an early unit:http://www.idparts.com/catalog/produ...oducts_id=2457
You can see the linkage from the engine compartment - look for slop when someone is wiggling the shifter from inside the car. Also - having the right (and good) trans fluid helps
They may have also not bled the brakes correctly (the clutch cylinder shares the brake fluid).
I hate rockauto.com http://forums.tdiclub.com/showpost.p...&postcount=236
04 Jetta GLS 5sp - EGR delete, RC3, VNT17/22, 3" turbo back exhaust & 2.5" FMIC+PD150 intake. SBC Stage 2 Endurance w/SMF. Eibach lowering springs
gforce1108 is offline   Reply With Quote
Old March 21st, 2012, 11:17   #3
Rudolph Rajendra
TDI(s): New Beetle
It's a 2001 New Beatle. It's been pressure bled repeatedly by the dealer, and grinds occasionally going into second. After they bleed it, the problem disappears for a while, only to return a few months later.
Would the wearing of that part cause that problem, and be difficult for the dealer to diagnose?
Old March 22nd, 2012, 13:03   #4
gforce1108
gforce1108's Avatar
The 01 should have the newer design that is much better. Does the clutch release right at the floor? Interesting that it will go away after bleeding but return. That would make me think that one of the cylinders is leaking.
Old March 29th, 2013, 12:18   #5
turbotorq
turbotorq's Avatar
TDI(s): 04 Jetta TDI
Fuel Economy: 45ish
Hey nice 04 jetta. I have the same one. I installed performance chip which gave me 40% more power . I also straight piped. I've been thinking about the VNT 17, how is fuel economy/ power/ sound?
turbotorq is offline   Reply With Quote
Old March 29th, 2013, 12:20   #6
turbotorq
turbotorq's Avatar
Fuel Economy: 45ish
What's the benefit of the PD150 intake? Noticeable difference? Also what's EGR delete?
Old March 29th, 2013, 12:36   #7
BobnOH
Fuel Economy: 50/45/35
I have read the bearings in the shift tower can go bad. I have broken the shift lever and the shift actuator on mine. But please rule out any clutch/hydraulic issues
BobnOH is online now   Reply With Quote
New major problem: won't shift in or out of gear! sfierz VW MKIII-A3/B4 TDIs 12 October 16th, 2009 13:06
Added Flameball gear shift knob to manual 5spd trapperkeeper VW MKIV-A4 TDIs (VE and PD) 8 December 26th, 2007 01:47
Manual Transmission Gear Shift Cables pward TDI 101 3 April 3rd, 2007 21:11
Manual Gear Shift Position billsbuddie TDI 101 2 March 1st, 2005 10:17
WTB-2001Jetta Manual Shift Gear selector + cyclonecoasters Private TDI Items for Sale/Wanted 0 September 2nd, 2003 07:51
Page generated in 0.16200 seconds with 10 queries
[Output: 80.91 Kb. compressed to 70.39 Kb. by saving 10.52 Kb. (13.00%)]
