DavidFoertsch
Hey all, I have a 2001 Jetta TDI with approximately 204,000 miles on it. Since around 190,000 miles I've had a P0740 (Transmission Clutch Circuit Malfunction). I've been coping with the problem by putting it in neutral whenever I coast to a stop. I want to finally tackle this problem and I was hoping you all could help.
I'm new here on the forums, but I've browsed here for the past month. I noticed CoolAirVW (I believe that was his name) posted a thread regarding this issue, and a fix or two that he had for people's issues. Since he made clear that there isn't any one fix for this problem, I decided to list my symptoms so maybe we could narrow down where the problem could be coming from.
My TDI has a Dr Jekyll / Mr Hyde type of personality regarding this issue.
I read that someone mentioned that the first bullet point was a fail-safe system when the transmission isn't working properly. While I understand that, I DO NOT understand why it switches back and forth randomly. Driving over a pothole, or driving on a hot or cold day doesn't change it.
When I start my TDI, I need to let it idle for approximately 5 minutes in order to drive it at all. If I try to put it in reverse, or drive, then the car will sputter and then turn off.
ALSO, I forgot to mention earlier that my car has a P3130 code when the CEL is on. I don't know if those error codes are causing one another, or if they are completely unrelated.
If you all have anything that needs clarification, let me know. Thanks so much.
- If the CEL is on, then my RPMs are higher than they should be at any given speed, and there isn't a rough idle or a clutch slip.
- If the CEL is off, the RPMs are normal for a given speed, but the gears shift early and I have a rough idle.
