Old March 20th, 2012, 18:00   #1
joseluis.17g
Default VR6 clutch, high frecuency vibration, what do you think it's the problem?
Ok so I just get my clutch replaced with Sachs vr6 SMF like 3 weeks ago and it just started vibrating whenever I try to accelerate with low boost, once I start getting some boost it stops, the vibration I can feel it on the clutch pedal and the accelerator pedal, no strange noise on idle just the SMF normal noise, I can also feel it on the gear leaver, when going from a stop I can feel like 3 or 4 clicks on the clutch and then the vibration.
Can you help me? I just get some opinions before I go to the mechanic to be better informed
Thank you
http://clubtdimexico.com El Primer Club TDI en México
07 Mexican MKIV PD AXR engine 40,000 miles, vr6 clutch, eibach pro kit, homemade fiberglass corner subwoofer box, trunk mounted battery, mufflerectomy.. Saving for a tune, boost valve and water/methanol injection unless advise otherwise
joseluis.17g is offline   Reply With Quote
Old March 21st, 2012, 03:59   #2
Ol'Rattler
Ol'Rattler's Avatar
TDI(s): 2006 Jetta
Sounds like what ever the problem is, to investigate will require taking the transaxle back out, except as a long shot, check the motor mounts and motor mount bolts first.
3 or 4 clicks then the vibration? You should have no clicks. My SMF with 51K miles has absolutely no clicks, vibration or noise and it was like that from the first time I started the car after replacement.
I would recommend you stop driving the car until the problem is fixed. If something does come apart while you are driving it, it could cause severe damage to your transaxle and/or engine.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old March 21st, 2012, 07:45   #3
Satiro
Satiro's Avatar
maybe a wrong lever/bearing installation?
Just for interest,did you change the stock lever for G60 unit?
I have my Sachs VR6 clutch with G60 lever and no problems after 100.000km on it...
Don't drive car so,find the problem before serious damage.
Good luck!
SEAT IBIZA GT 1.9 TDI 110hps AFN 1998 - CHIPPED by Rub87
Some goodies!
Satiro is offline   Reply With Quote
Old March 21st, 2012, 14:08   #4
joseluis.17g
Stock leaver, what could be if something in the transaxle? Maybe flywheel wasn't torqued correctly? Or what could it be? I'll check the motor mounts, does any one know the torque specs for the bolts on the motor mounts?
Old March 22nd, 2012, 04:00   #5
Satiro
Satiro's Avatar
do you have vibrations at idle? I think if flywheel isn't torqued correctly, you should have vibrations all the time...
Some goodies!
Old March 22nd, 2012, 06:40   #6
oldpoopie
oldpoopie's Avatar
Fuel Economy: whats that?
Pull it apart ant investigate unfortunately.
Pacific Northwest TRUSTED TDIClub mechanic
Email me, justgrow@gmail.com
Old March 22nd, 2012, 11:21   #7
joseluis.17g
no vibrations at idle, just when the engine it's at load according to scangague is almost when the load is over 50-60
Today I'll take it to the mechanic, see what he says, he'll probably want to take it apart, unfortunately that means no car until Monday probably
Old March 22nd, 2012, 12:44   #8
oldpoopie
oldpoopie's Avatar
Driveshaft
Old March 22nd, 2012, 20:49   #9
NewTdi
Fuel Economy: 52/47/39
Originally Posted by oldpoopie View Post
Driveshaft
aren't you just the bearer of bad news!
NewTdi is offline   Reply With Quote
Old March 22nd, 2012, 22:07   #10
oldpoopie
oldpoopie's Avatar
Just voicing my suspicion.
New Valeo (G60/VR6) Clutch problem 05 Jetta locodoctor VW MKIV-A4 TDIs (VE and PD) 2 April 1st, 2008 20:01
Local Response needed ASAP: MK4 VR6 or MK3 VR6 Clutch Kit? aburchell44 Atlantic Canada 10 August 25th, 2006 16:37
Gearbox Vibration after VR6/G60 Change jeromec VW MKIV-A4 TDIs (VE and PD) 7 July 22nd, 2006 16:39
Anyone solved the noisy vr6 clutch problem Stephen P TDI Power Enhancements 12 September 9th, 2002 21:04
G60/VR6 clutch owner,Any problem with starter? vitesse VW MKIV-A4 TDIs (VE and PD) 9 January 26th, 2001 00:45
Page generated in 0.14317 seconds with 10 queries
[Output: 99.01 Kb. compressed to 83.99 Kb. by saving 15.02 Kb. (15.17%)]
