Old March 19th, 2012, 20:00   #1
freeman
Default p0401 code - 2009 Jetta TDI
I have a 2009 early season Jetta TDI with slightly over 60000 miles. I had a HPFP failure shortly after 10000 miles and no problems since. I popped a CEL 12/2011 and took car into dealer (I live over 3 hours from the closest TDIclub recco shop). They replaced the EGR valve (for $400!) with the CEL coming back in less than 30 miles. They then replaced the DPF with the same result and then the catalytic converter (both under warrantry) again with the same result.
The dealer and techline were stumped and told me they would research further when the most experienced tech was back from cancer surgery . For the next month I a called back a couple of times and he was still sick. I suggested maybe a wiring harness problem but they wanted to wait for the tech to return. Then the left low beam headlight bulb went out. After replacing it, about 15 miles later the CEL was off and has remained off the last week. Thought it would be good info for the database. I did notice I am getting 2-3 mpg better with all the replacements.
freeman is offline   Reply With Quote
Old March 20th, 2012, 04:24   #2
tdiatlast
This isn't an answer to your question, but questions of my own:
1) Did you have a catastrophic failure of your HPFP? Did they replace the entire fuel system?
2) Why did they replace the DPF? Was it clogged? Did they tell you it was clogged, or were you experiencing frequent regenerations?
3) Did the EGR electric motor fail, or was the flapper corroded?
4) Were you using any fuel additive? If so, what kind? Was the oil changed regularly (10k) with 507 oil?
I'm not trying to annoy you with these questions, but you've had all the failures (except intercooler icing) that we all fear the most, and we're all trying to figure out cause, other than poor design. I hope your dealer has been doing the right thing, and not just throwing parts at the car.
Thanks in advance.
2014 Passat TDI SEL DSG (returned 12/14/16)
2009 JSW TDI DSG (returned 12/15/16)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
tdiatlast is offline   Reply With Quote
Old March 22nd, 2012, 10:48   #3
TJP37857
Default Same issue.
I also have a 2009 Jetta TDI that I just bought on March 1st. The very next day I get a CEL code of P0401( EGR Valve). I had it cleared and it stayed off for several days and then came back on. I was wanting to get some things taken care of at dealer and scheduled to have them done and have this code check.
I was told by the dealer that my whole DPF system needed to be replaced at a cost of $4638 since I have 86000 miles on car and am beyond Emissions warrenty of 80000. I called VWoA and they refused to give me any help since I purchased it after the warrenty had expired. I am not seeing any kind of performance issues and fuel economy remains in the low to mid 40's.
I don't really believe that the DPF needs replaced, because of performance, fuel economy and the fact that the DPF light on dash has never come on only the CEL.
I am very interested to hear what you find out about your car in hopes that it may save me a few thousand $ and my desire to have a TDI.
TJP37857 is offline   Reply With Quote
Old March 25th, 2012, 19:45   #4
dsieme01
Run far and fast from the stealer. Lookup one of the gurus here. Get away from the stealer. Most of them don't have a clue and are way overpriced. I think vagcom has a measurement for dpf load and they would give a indication if it was plugged up.
dsieme01 is offline   Reply With Quote
Old April 9th, 2012, 19:06   #5
freeman
Hi Tdiatlast,
As far as I know the entire fuel system was replaced with the HPFP failure - it took two weeks.
I think they replaced the DPF and catalytic converter because that was the next thing to do after the EGR valve per the Tech bulletin. They did not tell me if there was any corrosion or not of the EGR., but it did not make any difference that I could tell. Oil changed every 10000 miles with 507.
I never had any problem with the car other than the CEL, it drove fine. I never noticed any increased regenerations. I did run a few tanks with some diesel that had PRI-D in it, but none in the last 20-30,000 miles. At the end I really think it was an electrical fault, maybe related to a voltage drain from the failing headlight. The CEL was present for weeks and I erased a couple of times but it returned until I replaced the headlamp bulb. Still no CEL two weeks later.
Old April 10th, 2012, 09:46   #6
TJP37857
Default P0401 again
I took my 09 Jetta TDI to a TDIClub mechanic and he was sure it was just the EGR valve and replaced it a cost of just over $600 including labor. Two hours after leaving the shop the light came on again and when code was checked it was the same P0401 code.
The mechanic is brain storming and is trying to come up with a solution. I have had this car since March 1st and have already put $1400 in it. I am very disappointed with my VW. I wish somebody new what to do to fix it, instead of have me throw money at it.
Old April 20th, 2012, 10:53   #7
TJP37857
My 09 Jetta TDI has been with the mechanic for over a week with no luck in figuring out what is throwing the code. He is doing all this work because he is determined to find the problem to save him time and aggrevation in the future. He is starting to believe that there is a possiblity that the DPF is getting full and limiting flow even though performance and mileage are not yet effected. He is going to try a few more things since he has a perfectly running 09 that he can trade parts with and experiment.
I am thinking of doing a EGR/DPF delete if it is the DPF. It will cost half as much as replacing the emissions system and will increase performance and fuel economy. I also might just drive it with the light on and hope that VW will do recall at some point since I am hearing that this is becoming a popular problem with the CR and their DPF systems since they are starting to get some mileage on them.
Does anyone have any opinions on this?
Old April 30th, 2012, 15:04   #8
MotoWPK
TDI(s): 2009 Jetta
Only that it would seem that due to how recent the introduction of the current emissions control system is (beginning with MY2009) and relatively young age (by mileage and years) of this series, I would think that there is limited experience of these systems among the independent shops. Related, I expect the majority of MY2009+ owners take their vehicles to the dealer for maintenance, so the dealer's mechanics likely have more experience with these systems. Still, given the relative rarity of these issues even the dealers' mechanics likely have limited experience, but, they have access to those who do have the most by far...VW.
I just have to wonder how much knowledge the independent shops have in dealing with MY2009+ emission control systems.
MotoWPK is offline   Reply With Quote
Old May 15th, 2012, 08:23   #9
jrm390
My dealer just told me the same thing. Said I need to replace the entire exhaust. Except they quoted me $6500.... I haven't seen any decrease in performance or fuel mileage.
jrm390 is offline   Reply With Quote
Old May 23rd, 2012, 07:52   #10
1972SS454
Which EGR valve does this code refer to? The HP EGR valve mounted in the intake piping or the LP EGR valve mounted in the EGR cooler?
If anyone needs replacements for any EGR or exhaust parts let me know. I have an extra full factory EGR and exhaust setup that are fully functional.
1972SS454 is offline   Reply With Quote
Old October 3rd, 2012, 14:14   #11
aflorey
I have a 2010 jetta tdi sportwagen with 50435 miles. My CEL has been coming on and off for 3/4 weeks. Mechanic found code p0401 egr insufficient flow. mattie vw is telling me that my warranty doesn't cover the egr, is this correct? any new advice?
aflorey is offline   Reply With Quote
Old July 18th, 2013, 08:32   #12
Shayneco
Bump. I'm having the same issues. Any answers. 10 tdi. P-0401. No coverage because 93xxx miles and coverage to 80k/8 yrs. say needs DPF replaced. $3000+ job.
Shayneco is offline   Reply With Quote
Old July 25th, 2013, 16:24   #13
TDI-B.O.B.
could you just swap in an aftermarket exhaust system? Don't beat up the new guy....I'm not sure....just asking... I'm new at this tdi stuff. All I know is that my light came on for p0401, I cleared the code. It came on a day later...then I drove it harder in attempts to blow crap out of it, instead of light footing it for gas mileage....then my light went away. Dunno??????
TDI-B.O.B. is offline   Reply With Quote
Old July 27th, 2013, 16:20   #14
shrifty
shrifty's Avatar
Fuel Economy: Around 45 MPG
I have the same code, been coming on and off now over the past week or two. I am having the EGR/DPF delete done in about 2 weeks, would it be advisable to drive it during this time?
shrifty is offline   Reply With Quote
Old August 14th, 2013, 17:14   #15
flatout
TDI(s): 2009 JETTA
Any updates? Shrifty?
09 Jetta TDI sedan, 6 speed, built 03/09
Best Tank 646 miles
flatout is offline   Reply With Quote
Help!!! P0401 code comes and goes !!!! Softrockrenegade VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 17 October 1st, 2016 05:15
Engine code P0401 cdscar TDI 101 15 September 29th, 2015 10:48
CEL code P0401? jettawreck VW MKIV-A4 TDIs (VE and PD) 12 September 9th, 2010 18:22
Throwin a P0401 code slowbooster VW MKIV-A4 TDIs (VE and PD) 5 April 3rd, 2010 16:29
P0401 Code TDi_Dan_R19 OBD Scanners 0 June 21st, 2005 22:05
Page generated in 0.16108 seconds with 10 queries
[Output: 124.88 Kb. compressed to 104.78 Kb. by saving 20.10 Kb. (16.09%)]
