Old March 17th, 2012, 10:49   #1
gmcjetpilot
gmcjetpilot's Avatar
Default Rain-X window treatment Rain-X washer fluid
I just bought both at Walmart..... small bottle of the classic Rain-X you apply direct to the window. I also bought for well under $3.00 a gallon of Rain-X windshield washer reservoir fluid "2 in 1". It is ORANGE in color so be sure not to mix it with your antifreeze (which is ORANGE I have been told).
I treated the window with the classic (clean, apply, haze, remove), BUT I may not use the fluid and return it. First my reservoir is full with new clean blue stuff (my car is still newish). May be double dipping Rain-X might be over kill. I read amazon and other reviews on retailer sites; it got good ratings, but some say it leaves some kind of residue and the first application it streaks. However a majority of reviews are positive, +4 out of 5 stars. The idea of using rain-X is in light rain, is so you can drive with out wipers on.....
ANY ONE USE THE FLUID? COMMENTS?
gmcjetpilot is offline   Reply With Quote
Old March 17th, 2012, 11:14   #2
Abacus
That helpful B4 guy
Abacus's Avatar
I use both all the time and have for many many years on all my vehicles. Use it without worry.
'97 B4: 453,000 miles Malone 3, K03/04 Hybrid Turbo, PP520's, Stage 2 cam, SBC3, ARP studs, Westach EGT/Boost, Koni Reds/Yellows, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR, Evo plate,
BUG*PWR 2013 Award Winner
Old March 17th, 2012, 11:19   #3
OilBurningBrit
Fuel Economy: 38mpg
There are some opinions here: http://forums.tdiclub.com/showthread...t=washer+fluid
The biggest complaint I've read (and this applies to Rain-X in general, not just the washer fluid) is there's a build-up over time that appears different between the wiped and non-wiped areas of the windscreen.
OilBurningBrit is online now   Reply With Quote
Old March 17th, 2012, 12:55   #4
P0234
TDI(s): 11 JSW
Aquapel FTW.
P0234 is offline   Reply With Quote
Old March 17th, 2012, 17:43   #5
frugality
frugality's Avatar
Fuel Economy: 33mpg
That's been my experience -- with both the wipe-on Rain-X as well as the washer juice.
The non-wiped area gets a little hazy. You're basically putting a thin coat of plastic/wax on your windshield, and dust sticks to it.
So I don't use it anymore.
2016 GTI SE 6M with lighting package, runs on RUG, has spark plugs? AVERAGING 33mpg!
2010 Jetta Sportwagen TDI, 197,089 miles, Silver, manual, 17" Goals, original brakes -- GONE; REPURCHASED BY THE MANUFACTURER.
frugality is offline   Reply With Quote
Old March 17th, 2012, 18:39   #6
Early8Q
Originally Posted by P0234 View Post
Aquapel FTW.
I prefer aquapel as well. It costs lots more, but lasts lots longer. I also find I don't get the radar like hazing and glaring I get with with rainx on dark rainy nights which I have experienced on an older car. YMMV.
Wishing for a TDI with Torsen all wheel drive and a manual Transmission
Early8Q is offline   Reply With Quote
Old March 18th, 2012, 06:02   #7
dweisel
dweisel's Avatar
Fuel Economy: 09 MB R320 Bluetec and too many ALH Beetles!
Just use a good quality paste wax on your windshield. Sheds water like a duck.
LUBRICITY,LUBRICITY,LUBRICITY!
dweisel isn't diesel anymore!
dweisel is online now   Reply With Quote
Old March 18th, 2012, 07:45   #8
Abacus
That helpful B4 guy
Abacus's Avatar
Never had an issue with any hazing. Not sure of what people are doing, but I'll keep using it.
Old March 18th, 2012, 10:05   #9
baglenn
TDI(s): 2015 GLK 250
I made that mistake of putting the washer fluid in the radiator overfill tank. But I got it over to west Houston vw and they drained my radiator fluid and I just paid for new coolant 23 bux. I should be fine. They said it wouldn't hurt since washer fluid is water and alcohol.
baglenn is offline   Reply With Quote
Old March 19th, 2012, 00:04   #10
Rauss
Rauss's Avatar
Fuel Economy: Worst 38mpg \ Best 52mpg
One advice! Dont mix blue washer liquid with rain x one. Sometimes in mk4 car and some mk5, the rain x one(yellow for winter) will not be detected by the level sensor, resulting a disturbing yellow light for nothing in the dash.
Using Rain-x washer fluid with rain-x treatment will make it last longer.
.:Rauss
Rauss is offline   Reply With Quote
Old March 19th, 2012, 07:51   #11
tomc585
I remember when I 1st tried rainX about 25 years ago I hated it. Then a regular customer came in for an inspection and his wiper motor was missing. He said he uses rainx. I told him I had tried it and hated it. He said to apply as instructed then let him know. Back then I never read the back label. Glad I did. Love it ever since.
2009 TDI JSW w/DSG 16" rims
VAG Com & Bentley Service Manual
tomc585 is offline   Reply With Quote
Old March 19th, 2012, 08:06   #12
aznwhip
Aquapel FTW.
+1 Aquapel FTW. Why settle for anything less than the best for visibility which I hear is kinda important while driving.
Build Thread: http://forums.tdiclub.com/showthread.php?t=330665
aznwhip is offline   Reply With Quote
Old March 19th, 2012, 08:31   #13
Rauss
Rauss's Avatar
Agreed aquapel is the best...
.:Rauss
Old March 19th, 2012, 08:40   #14
KITEWAGON
KITEWAGON's Avatar
I recently tried the rain-x in the yellow spray bottle. I applied as directed, but really hate the haziness. I don't think that I'll use it again. My windshield is pretty old and pitted and I wonder if the haziness is worse for people with older windshields than new ones.
2014 Touareg TDI Executive, Canyon Grey, 130k
2014 JSW TDI, Platinum Grey, 43k
2005 Toyota Tundra Double Cab SR5 TRD 4x4, Silver, 165k
KITEWAGON is offline   Reply With Quote
Rain Started...Window Stopped Bopper VW MKIII-A3/B4 TDIs 4 October 16th, 2007 00:42
Window left open in Rain doubleupcrow TDI 101 12 August 13th, 2007 19:17
left window open. Rain came in. 2500hd2 VW MKV-A5 Golf/Jettas 21 August 10th, 2007 19:38
Rain rain go away (till I open the drains...) BoFH General VW Discussion 0 December 3rd, 2003 01:33
Rain-X Washer Fluid Mass. Wine Guy VW MKIV-A4 TDIs (VE and PD) 20 February 9th, 2002 14:49
Page generated in 0.18406 seconds with 10 queries
[Output: 120.40 Kb. compressed to 100.23 Kb. by saving 20.17 Kb. (16.75%)]
