Old March 15th, 2012, 12:31   #1
CoyoteStarfish
TDI(s): 01 Beetle
Default Turbo went boom. [pics]
So I'm driving along, and I hear an all too familiar POP and loss of power. I immediately shut the engine down and coast into a parking lot expecting a charge pipe blew off somewhere. Not so lucky.
I see oil pouring all over the ground near the rear of the engine, so I play it safe.. call in, wait for a tow.
I get home and start checking around only to find THIS:
The entire compressor housing had sheared off!
When I reached down to feel how bad the compressor blade had been chewed up - knowing it wouldn't be salvageable anyway - I didn't feel anything at all. The compressor blade was gone.
Any idea what might have caused this? Vehicle details and mods are in my signature... keep in mind the EVRY mod is on a momentary button only activated at WOT. I was nowhere near WOT when this happened.
My rides:
2001 New Beetle - ALH/TDI - EVRY mod - .216 nozzles - Eating turbos left and right.
1986 BMW 524td - Gone to the great junkyard in the sky. But kept the engine.
Everything - on B100
CoyoteStarfish is offline   Reply With Quote
Old March 15th, 2012, 15:43   #2
Nutsnbolts
Nutsnbolts's Avatar
Fuel Economy: Average is about 47 now (2010)
That is absolutely amazing. I've got nothing as far as an idea about why that would have happened, though. At first glance, it looks like it took a hit from behind, but I'm not sure what could have done it. Was the nut that holds the turbo outlet pipe to the body (the one between the turbo and the intercooler) still on? If the pipe was hanging free, vibration over time might have fatigued the housing?
-Rich
521,500 miles...and counting!
2000 Jetta, M1TDT since 20K, RC2, PP520s, W8 panel, front/rear fogs, Pseat w/mem. Other cars: 1972 Plymouth Satellite Sebring 2dr HT (my FIRST car!), 1968 Chrysler 300 2dr HT
Nutsnbolts is offline   Reply With Quote
Old March 15th, 2012, 15:51   #3
CoyoteStarfish
TDI(s): 01 Beetle
I just had to go check.. the pipe was still bolted to the body. Someone else suggested it may have been a casting flaw. There is a hair-line crack that runs from the center out to the outside of the flange. I'm trying to get a better picture right now.
My rides:
Old March 15th, 2012, 15:53   #4
Ski in NC
Fuel Economy: 48-52 typical
Seen other photos of the same type failure on this site. Looks like fatigue failure. Boost pressure up high?? High boost puts alot of force on that housing (looks like a piston to the pressurized air) and that will stress it where it failed. Each gear shift is a load cycle, creating a fatigue situation. Maybe some other turbos are beefier there.
2001 Jetta TDI 5sp Stock 193k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1645Hrs..in the yard for REFIT!!
Ski in NC is offline   Reply With Quote
Old March 15th, 2012, 15:56   #5
CoyoteStarfish
TDI(s): 01 Beetle
I'm running stock boost, and I don't drive it that hard. Oh well.. time for a VNT17 or 20 perhaps?
My rides:
Old March 15th, 2012, 17:12   #6
CoyoteStarfish
TDI(s): 01 Beetle
More pictures:
My rides:
Old March 15th, 2012, 17:43   #7
bloc
Shaft failure > compressor wheel wedging itself between the cartridge & housing? maybe?
2000 Jetta TDI - 5spd swap, VNT-17, DLC1019s, Kerma Tune
bloc is offline   Reply With Quote
Old March 15th, 2012, 18:39   #8
diesel-dave
diesel-dave's Avatar
looks like you need a new turbo, My suggestion is to get a vnt 17 this time. they are similar to vnt 15 in price.
2003 Bora Wagon TDI Bosio R520's,colt cam, VNT 17
q loader. no smoke
2001 Beetle TDI GLS Bosio 764 7 hole's, tune, VNT 15
2010 JSW wagon DSG loaded
2003 golf auto
diesel-dave is offline   Reply With Quote
Old March 15th, 2012, 19:10   #9
CoyoteStarfish
TDI(s): 01 Beetle
I'm looking at a VNT20 using a cast 8V manifold with a T25 flange. Not sure about clearances on this Beetle, however.. anyone want to chime in?
If that doesn't pan out, I'm also looking at a KP39A [Isn't this essentially a VNT17?] with integrated exhaust manifold.
We wanted to go big power with this Beetle, this was just a little unexpected. But if I have to shell out, I might as well go big.
My rides:
Old March 15th, 2012, 19:33   #10
FordGuy100
The same KP39 found on BEW's? if that's the cause many say that are to small andust be upgraded for bigger power.
2004 Jetta TDI Auto, 98K. mufflerectomy 34/49mpg low/high mpg. 2004 Jetta TDI 5 speed 170K. 1985 Ford F250 6.9 IDI/4 speed 4x4 RCLB ATS wastegated turbo, ARP studs, ISSPRO gauges, new paint.
FordGuy100 is offline   Reply With Quote
Old May 18th, 2012, 14:59   #11
1.9 TDI Awd
1.9 TDI Awd's Avatar
Fuel Economy: Lowest is 40 sofar
i would love to know how yours blew aparts/ split. i did get a message from my VWvortex a guy John that had a same issue. i should call him like he offered. just wondering are all of your vacuum lines oem? mine r. have you ever replaced your N75 valve? mines OEM as far as i know, had the TDI a year and never replaced. old owner didnt know much. needed alot of tlc when i bought it. still needs some... anyways i had my EVRY mod on at WOT 2nd gear up hill pull, full running temp after bout 1hr plus driving lightly no evry. just normal cruising, wanted to pull up hill... BOOF. same though of boost pipe, no response. then i saw a bit of white smoke, had to crest the hill as i was on a highway. it started dieseling the oil(rpm and feel gave that away) i shuter down ASAP, in gear as i have PD150 IM and RP. no asv to shut for me as im egr deleted. coulda been the Engine!! glad to upgrade also, just way to unexpected....enough rambling
"Beef Budget Suspension" Club, MadeWhitbreads DIY Shorthrow. EvryMod,SmashedKat,Intakecutout,R32Snorkle, 5thbrakemod, Murdered(tint everything/black), Ecodes with oem Fog, VW Emblems cut in wheel well for SMIC, Shine RSB, BlauParts VR6refresh, 1.8t Pancake Pipe, PD150 IM and RacePipe..Working on FMIC/Clutch...always adding more ask if your curious
1.9 TDI Awd is offline   Reply With Quote
Old May 18th, 2012, 15:06   #12
1.9 TDI Awd
Exclamation My Split housing
This is the housing off my VNT15. as you can see pieces of the wheel are lodged into the housing...
then the whole housing, still unable to locate the actual shaft. however the nut is in mint condition threads and all! so confused on that part
seperated form the cast...
and literally all that i found in the housing on the road after blow out. wheel pieces where on my skid plate.
after tearing everything apart, the vanes work flawlessly. the actuator moves(unsure of how much vacuum it takes) and the soot was minimal. just oily as can be!...upgrade i guess!
Old May 18th, 2012, 15:13   #13
CoyoteStarfish
TDI(s): 01 Beetle
I also have the EVRY mod, but mine is a bit different. I have a trigger button under the accelerator which only triggers it at WOT and there is a toggle which arms the trigger mounted just by my hazards. The EVRY was OFF when this happened!
I will admit, I did like to race this little Beetle around town, and with the EVRY it was pretty quick - so I did abuse it on occasion. It has no boost gauge, which is why I stopped using the EVRY in the interest of waiting until I could put a quality pyrometer and boost gauge on it.
I was leaving a McDonald's parking lot with casual acceleration and when I hit second gear.. "BOOF!" describes the sound perfectly. I thought maybe I had blown an intercooler hose but then I saw the white cloud and the engine started accelerating on its own. The first post describes the rest.
The compressor stage had been sheered off completely, leaving the damage pattern on the compressor housing you see above.
This car had OEM everything with no service records, 150k on it, clueless POs and the lady (my friend, owner for 3 years) I bought it from wasn't very well informed by myself as I didn't know much about the TDIs at the time of her ownership either. The only things I DO is that I installed some .216 "prothe" nozzles about 1.5 years ago and that the car had a timing belt and clutch installed a few months prior to my purchase.
My rides:
Old May 18th, 2012, 15:28   #14
1.9 TDI Awd
hmm, i wish i new the reason? is it too much overboosting previous to it letting go? just bad turbo, oil seals going out anyways. i wish i knew more about what lead to this catostrophic failure.... have you repaired your setup yet? or are you still turbo less?
Old May 18th, 2012, 16:01   #15
CoyoteStarfish
TDI(s): 01 Beetle
I've got a good used turbo on mine right now, still VNT15 until I get up the parts to do a 17 or 17/22 swap.
I did an EGR/CCV delete while I had it open so I'm in limp mode until I either tune it or go mTDI.
My rides:
Low Boom-boom Noise From Under Car edpipeline VW MKIV-A4 TDIs (VE and PD) 5 December 31st, 2006 21:42
'96 Passat "Turbo goes boom" milleraw VW MKIII-A3/B4 TDIs 40 January 5th, 2005 20:40
Big squeel, Lots of smoke, Turbo go Boom Red_Tdi VW MKIV-A4 TDIs (VE and PD) 6 April 27th, 2004 04:31
Turbo goes boom...maybe BobTDI VW MKIV-A4 TDIs (VE and PD) 5 March 22nd, 2003 05:38
Page generated in 0.16611 seconds with 10 queries
[Output: 131.03 Kb. compressed to 109.54 Kb. by saving 21.49 Kb. (16.40%)]
