Old March 13th, 2012, 11:08   #1
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: 130 MPGe
Question NMS/B7 - Passat '12+ FAQ & Maintenance HOW-TO
At kromicacid's request, I'm starting a sticky FAQ thread for the 2012+ Passat (NMS/B7).
kromicacid will be responsible for updating Post #2, so keep your eyes on it for updates.
-Lawson
FAQ #1:
Q: What is the difference between the NMS and a B7?
A: NMS stands for New Midsize Sedan, which is the project code name for the North American, Saudi Arabian and Chinese 2012+ Passats. B7 is a bit of a misnomer (it's really more like a B6.5), but refers to the European Passat, which is a completely different vehicle from the NMS. The B7 and NMS share practically nothing between them. While VWvortex and other sites commonly (and incorrectly) refer to all new Passats as B7s, it is technically incorrect.
Because TDIClub has a number of international members and prides itself on correct model identification, please use the proper terminology to refer to your Passat while posting here.
Summary: B7 = European Passat. NMS = North American, Saudi Arabian and Chinese Passat.
If you live in North America, you do not have a B7.
Old March 13th, 2012, 11:12   #2
kromicacid
kromicacid's Avatar
Please PM me for updates and suggestions. Please provide documentation or a link for a quick cross reference.
How to search the forums -
http://forums.tdiclub.com/showthread.php?t=133579
FAQ:
Timing Belt Change Interval - 130,000 mile intervals for timing belt and water pump stated in the owners manual
Break-in Period by Drivbiwire - http://forums.tdiclub.com/showthread...biwire+breakin
Engine Fan running after shutoff - http://forums.tdiclub.com/showthread.php?t=344500
Light Bulb information - http://forums.vwvortex.com/showthrea...1#post77997050
RNS510 Firmware & Maps Info Thread
Turbo Failure Discussion:
General Discussion Thread: http://forums.tdiclub.com/showthread.php?t=360617
Failure Reports Thread: http://forums.tdiclub.com/showthread.php?t=375789
Data Collection Thread: http://forums.tdiclub.com/showthread.php?t=381481
DIY Service: (If you do something, and document it, please let me know so I can post it for the masses...)
Oil Change/ 10k service video - https://www.youtube.com/watch?v=YO8Qpv7P_QE
Cabin filter change - http://www.youtube.com/watch?v=yW0MD7XyezQ and http://forums.tdiclub.com/showthread.php?t=403318
Fuel Filter Change - http://www.youtube.com/watch?v=zwkxiIbI0Qc
Urea/Adblue Exhaust Fluid - https://www.youtube.com/watch?v=r5rXEWIeGCU
Coolant flush
DSG oil change -
Reset TPMS - http://my.vw.com/2012-passat/perform...essure-monitor
10,000 mile service video - http://www.crdsite.com/3.html [no-blue-screen]
A/C condenser cleaning video http://youtu.be/IxxP3RuPyQQ [no-blue-screen]
Remove ECU bracket http://forums.tdiclub.com/showthread.php?t=410144 [AARodriguez]
AdBlue Fill procedure: https://www.youtube.com/watch?v=r5rXEWIeGCU
Replacing the Adblue Heater: http://forums.tdiclub.com/showthread.php?t=438458 by docmanny
Heater core replacement: http://forums.tdiclub.com/showthread.php?t=450667 by 767wrench
DIY Mods: (if there are lots of modifications I will subdivide to make it easier to find. ie: body, electrical, etc.)
Fog Lights - http://forums.vwvortex.com/showthrea...9#post75403809
VAG-COM Tweaks - http://wiki.ross-tech.com/wiki/index...S/A3%29_Tweaks
More VCDS Tweaks - http://forums.tdiclub.com/showpost.p...&postcount=141
Rain Closing Windows - http://www.myturbodiesel.com/1000q/b...ctivation.html
Trunk Hinge Cover (for Right Hinge) http://forums.vwvortex.com/showthrea...nk-Hinge-Cover part #561-971-821-82V
Diesel Geek Shortshifter - by EatPasta - http://www.youtube.com/watch?v=ATy7ZIhIrEY
Reverse Camera for RNS-510 - http://forums.vwvortex.com/showthrea...Camera-Install
Custom front tag holder. No holes or drills - https://www.youtube.com/watch?v=foaZ_ADFECQ
Install Dash Cam http://forums.tdiclub.com/showthread.php?t=474333
VWVortex B7 FAQ/DIY: http://forums.vwvortex.com/showthrea...and-FAQ-Thread
As with most Internet forums, the people with the most problems speak the loudest. Rarely do people come on to sing the praises of something that's working well on a regular basis. If you have questions, please search for an answer and ask questions. Your experience may differ greatly from those posted on this forum.
~2015 Passat TDI SEL w/ Sunroof + Fender - White
R.I.P
~2012 Passat TDI SE w/ Sunroof - Platinum Grey ~ 170k miles
~ 2006.5 Special Edition Jetta TDI ~ DSG ~ Graphite Blue ~ 65k miles
~ 2004 Jetta TDI GLS~ Platinum Grey ~ 110k miles
kromicacid is offline   Reply With Quote
Old August 14th, 2012, 14:09   #3
no-blue-screen
TDI Nut
TDI(s): TDI
Custom front tag holder. No holes or drills.
no-blue-screen is offline   Reply With Quote
Old August 14th, 2012, 14:11   #4
no-blue-screen
TDI Nut
TDI(s): TDI
Old August 18th, 2012, 10:33   #5
FormerOwner
FormerOwner's Avatar
Fuel Economy: 35 city / 48+ hwy
I spoke to my dealer's master technician today regarding fuel filter changes. He said to first, remove the torx screws, and then pry off the lid. Next, he said to remove the filter and inspect the housing. Next, he said to insert the new fuel filter into the housing properly (I'm going to learn this @ my 20K service). Finally, you prime the pump... I asked him how he does that: He said that all you do is turn on the key 3 times in succession (without firing the engine). This will prime the pumps (we have 3 fuel pumps on our cars, as some of you know).
So, perhaps, we don't need Vag-com / VCDS to do this procedure, and thus, saving some $$$.
FormerOwner:
2002 VW TDI Wagon Candy White
1982 Audi 4000S diesel 1.6L
Current Owner: 2010 F-150 XLT SCREW 4x4; 2013 VW Passat TDI SE 6M; 2005 Toyota Camry LE
FormerOwner is offline   Reply With Quote
Old August 18th, 2012, 12:26   #6
tdiatlast
Hmmm...so they've gone back to "turn the key to prime the pump", which DOES NOT work on 09>>>CR TDIs. That's very curious, and would be very good to know, if it's true.
Also, to empty out any sediment, or accumulated water that the filter has removed, you MUST remove the canister, invert it, and wipe it clean. If you don't, after several FF changes, you could quite possibly build up a good bit of sediment, and possibly water.
Please ask this master technician if the 2012-2013 Passat common rail TDI is different than previous VW CR TDIs, and be kind enough to post his response here.
Thanks.
2014 Passat TDI, 2009 JSW TDI DSG (buyback)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
2017 Ford Energi Titanium, purchased 12/15/18
tdiatlast is offline   Reply With Quote
Old August 18th, 2012, 12:42   #7
FormerOwner
When I return for my 10K service, I'll be sure to ask him about that aspect. I'm sure that he probably does that too... I'll ask him about whether or not our CKRA TDI is different than the other CR TDI's.
FormerOwner:
Old August 19th, 2012, 02:09   #8
no-blue-screen
TDI Nut
TDI(s): TDI
Same with the PD. There is a lift pump that pressurizes the system when you turn on the key...hence the three key turns is just to make sure you have the system void of air. Don't forget to check for leaks after you complete the job. I have not done this on mine yet.
Old August 22nd, 2012, 11:31   #9
MyAvocation
MyAvocation's Avatar
I use a turkey baster from any dollar store. It's part of the spare filter kit I keep in the trunk.
"Never trust Internet quotes." - John F. Kennedy
MyAvocation is offline   Reply With Quote
Old August 22nd, 2012, 16:01   #10
Softrockrenegade
Softrockrenegade's Avatar
I have the understanding that the passats fuel system only has 2 pumps rather than 3 like the jetta/golf/Jsw ! Also cycling the key may be in his head from pre CR tdi generations ( perhaps they changed this on the passat?).
Softrockrenegade is offline   Reply With Quote
Old August 22nd, 2012, 16:04   #11
FormerOwner
As I said previously... I'll ask to verify all of your concerns when I return @ my 10K service.
FormerOwner:
Old August 22nd, 2012, 17:11   #12
tdiatlast
...uhmm...that would be 4 years ago.
Interesting question (key prime or not). I'm anxious to hear the answer.
Old September 5th, 2012, 09:13   #13
Vmwalker
Vmwalker's Avatar
Default Kessy?
Just push the start button with foot OFF the brake 2 or 3 times?
VW
Vmwalker is offline   Reply With Quote
Old September 5th, 2012, 10:20   #14
no-blue-screen
TDI Nut
TDI(s): TDI
Put some fuel or some powerservice in the fuel filter canister (fill it up) and just start the thing up.
Old September 16th, 2012, 07:29   #15
no-blue-screen
TDI Nut
TDI(s): TDI
Lightbulb
A/C condenser cleaning video:
tv tuner in a b7 nms mattfrayage VW Passat Family (NMS and B7) TDIs (2012+) 0 February 19th, 2013 13:21
NMS versus B7 jafische VW Passat Family (NMS and B7) TDIs (2012+) 23 December 26th, 2012 10:23
OEM B7 NMS Passat Mud Flaps are here! Fixmy59bug Vendor & GroupBuy items for sale 8 November 28th, 2012 10:40
Chassis Ground points 2013 Passat B7/NMS ? freeman VW Passat Family (NMS and B7) TDIs (2012+) 1 September 18th, 2012 21:38
New cars & emissions musings, moved from NMS/B7 storx TDI (Diesel) Emissions 18 August 28th, 2012 13:07
Page generated in 0.18307 seconds with 10 queries
[Output: 135.94 Kb. compressed to 114.12 Kb. by saving 21.82 Kb. (16.05%)]
