| VW MKIV-A4 TDIs (VE and PD) This is a general discussion about A4/MkIV Jetta (99.5-~2005), Golf(99.5-2006), and New Beetle(98-2006). Both VE and PD engines are covered here. |
March 13th, 2012, 06:57
#1
Cruise stalk interchange?
Does anyone know if the newer style cruise stalk would work in a 99.5 car? I like the rocker switch on my 02, and would love to retrofit the same controls on my 99.5
Thanks!
1999.5 T-RED Jetta GL TDI "Sport Edition" 391k: ASR Retrofit, 1.8T/VR6 Front Brakes MFA Display, GTI Steering Wheel, F&R Fogs, GLI Tails, Red/Black Sport Seats, Rear Sunshade, OEM iPod Integration
1998 Green Pearl Jetta GLS TDI 254k: GLX Black Leather Interior, DE Steering Wheel, Shift knob and E-Brake Boot, Trek Taillights and Spoiler
March 13th, 2012, 07:28
#2
*would like to know this too
March 13th, 2012, 07:32
#3
idparts lists only one, Turn Signal High-Low Stalk (A4 w/ Cruise), with fitment for the following models:
Volkswagen
Golf TDI MkIV (A4 chassis) w/ ALH engine (1999-2003)
Golf TDI MkIV (A4 chassis) w/ BEW engine (2004-2006)
Jetta TDI MkIV (A4 chassis) w/ ALH engine (1999-2003)
Jetta TDI MkIV (A4 chassis) w/ BEW engine (2004-2005)
New Beetle TDI (A4 chassis) w/ ALH engine (1998-2003)
New Beetle TDI (A4 chassis) w/ BEW engine (2004-2006)
Passat TDI (B5.5 chassis) w/ BHW engine (2004-2005)
Can someone confirm this?
March 13th, 2012, 08:08
#4
March 14th, 2012, 07:48
#5
I have installed the rocker end switch stalk on my cars when the original got flakey. I think VW went to the rocker because it is a better switch. If it comes out of an A4 chassis, it will fit. Plug & play.
'00 4dr 5-sp white over black Golf: Sprint 520 nozzles, ABS+ASR, Koni FSD enhanced suspension, vented hood; '00 2dr 5-sp silver over black Golf. DG 5-sp short shifter. Nuthin' special yet.
VW does not build or sell cars. VW builds and sells mobile DIY kits disguised as cars.
March 14th, 2012, 12:15
#6
Mine isn't broken, I just think the rocker is so much more intuitive.. Whenever I drive my 99.5, I am constantly pressing the wrong buttons when trying to change speeds while cruising..
Thanks for the info!
March 14th, 2012, 13:28
#7
Fuel Economy: 44.5 summer / 47 on snows
I guess I should test mine. I replaced the stalk because the headlight dimmer was bad and the new one had the controls built into it. The steering wheel controls still function so I never tried the new ones.
04 Jetta GLS 5sp - EGR delete, RC3, VNT17/22, 3" turbo back exhaust & 2.5" FMIC. SBC Stage 2 Endurance w/SMF, EBC Greenstuff. Ready to go: 3Bar MAP, PD150 intake.
