Old March 12th, 2012, 20:44   #1
sqhschief
sqhschief's Avatar
Question Making popping noises in the front end
2000 Jetta TDI. So it's been doing this for awhile now. When I am turning in either direction onto another road or an intersection for example, I hear these loud pops coming from the front end, somewhere near the tires. It also makes these sounds when driving straight/slow over a bumpy road or over speed bumps.
I'm pretty good with these engines, but everything else baffles me. Any help is appreciated.
Mufflerectomy, Ventectomy, 5 Brake Light Mod. Curt hitch. HID BiXenon RETROFIT 4300K Morimoto Denso 35W Ballast, "Coming Home Lights" Mod, all LED interior lighting, brake/signals, and license plate lights.
sqhschief is offline   Reply With Quote
Old March 13th, 2012, 05:01   #2
2005TDI_1994IDI
2005TDI_1994IDI's Avatar
Fuel Economy: 49/44/38
It is most likely in the struts, and usually the washer looking thing that is on top of the strut. These washers crack often. Also, the bushings on top of the struts are a wear item. I went with Bilstiens HD with shine springs. This setup will give you about a 1 inch lift. If you change the struts and springs, be careful. The springs are not under much pressure, and you don't need a spring compressor to re-assemble.
2005 Rabbit (Golf) TDI 5-speed, 4 door, blue. Bilstein HD with Shine springs. Panzer Plate, CCV filter mod. 205/65 r 15 Michelin Pilots. 2000 F-350 dually 7.3. 1977 KZ650B.
2005TDI_1994IDI is offline   Reply With Quote
Old March 13th, 2012, 06:30   #3
LNXGUY
LNXGUY's Avatar
Balljoints, LCA bushings, swaybar bushings, etc.
Bill
LNXGUY is offline   Reply With Quote
Old March 13th, 2012, 13:05   #4
sqhschief
sqhschief's Avatar
How would I check this?
Could you elaborate? Thanks.
EDIT: Would any of these things be something major that I have to get fixed immediately?
Old March 14th, 2012, 04:50   #5
2005TDI_1994IDI
No easy way to check that I know of. I would check the struts for any oil residue, if so they are gone and need replacement.
Does the car have any tracking issues? or steering wheel play? If so, then most likely balljoints or bushings.
With that many miles on the car you might need to refresh the entire front end including the struts. I got mine from Kermi, he has a good selection, but the web page is no so good. If you order from Kermi, call Paul and he will make sure you get what you need. I have also ordered from idparts, there web page is much better.
Old March 14th, 2012, 13:40   #6
sqhschief
sqhschief's Avatar
No tracking issues or any play in the steering wheel. I wonder if there's any other way to check the struts.
Old March 14th, 2012, 13:58   #7
rackaracka
Sounds like a bad cv joint to me. Is it a rhythmic popping or is it an occassional clunk?
2002 Jetta Wagon TDI Auto- Reflex Silver/Leather/Monsoon
95 Dodge 2500 w/Cummins TD - Straight piped 4 "
98 Beetle TDI 5spd - Herbie/11MM/VNT17/pp520/RC3/Mcnally Gauges/SBC2 Endurance/Bilstein HD's/Dieselgeek Panzer FMJ/3" Kerma turbo back
rackaracka is offline   Reply With Quote
Old March 14th, 2012, 19:16   #8
sqhschief
sqhschief's Avatar
Not rhythmic, just a loud clunk/pop. It does it mainly when I am turning in somewhere.
Old March 15th, 2012, 02:39   #9
rackaracka
Jack the car up and look at the back of the lower control arm. You should be able to see if its the rear bushing (It will be ripped). Most likely it is your rear lower control ar bushing or the sway bar bushing.
Old March 15th, 2012, 03:18   #10
sqhschief
sqhschief's Avatar
Thanks, I'll check it out this weekend.
Old March 15th, 2012, 03:35   #11
respond2us
Red face
My Jetta does the same thing. I notice it more often when I'm backing out of my driveway and turning the wheel sharply to the right. One loud "pop". I've had my suspension done with the bilstien tc's and it still does it. It doesn't seem to be getting worse, so I just try to not turn so sharp while backing up.
'10 JSW 6speed w/Sunroof 95k miles (Owned since 7-2-2016) -- TorkLift EcoHitch, Malone Stage II, DG Sigma Six shifter
'10 JSW DSG w/Sunroof and Nav 67k miles (Owned since 9-2016) Garage/Gate controller from Double Apex
respond2us is offline   Reply With Quote
Old March 15th, 2012, 07:03   #12
shuswap
Mine does this, has for a long time. I had a look while the wheel was turned side to side and it is the spring going *boing* when the strut-top bearing doesn't turn smoothly.
Much worse when turning the wheel while parking
shuswap is offline   Reply With Quote
Old March 15th, 2012, 09:59   #13
JettaJoy
I had similar symptoms about two weeks ago from the front end. If I turned the wheels either while stopped or running, I had popping noises. Driving along a bumpy road at slow speeds. I could also push down above the Front Left fender well and it appeared worse on this side.
After reading many different versions of this from searching on the forum, I figured it was the strut bearing. I jacked the car up by the frame, removed the left front tire, and then used another jack to raise the spindle and put pressure back on the strut. I could reproduce the popping sound then.
Turned out that all of this "loud" noise was coming from that "little" ball joint....
While having someone turn the wheels back and forth, you could "feel" the binding in the joint. I happened to have a "needle" adapter for my grease gun and injected the rubber boot with about 5 pumps on the gun. Worked the suspension up and down and the sound changed. Drove it to work and back the next day (80 miles) and the popping was gone.
I will replace it in another week or two as my timing belt is approaching it's change time..
Good Luck!
2001 VW Jetta GLS TDI 5 Speed
49mpg avg. 90% Hwy/10% City
400 miles weekly. Currently @ 320,000 miles
Mods- Ventectomy, Oldman Intake Pipe, 0.681 5th gear. Bosio T4 Nozzles.
JettaJoy is offline   Reply With Quote
Old March 15th, 2012, 10:19   #14
Powder Hound
Powder Hound's Avatar
My 2-dr was doing this on occasion and it was the roll bar bushings.
Basically, there's lots of things that can do it. Good luck sorting it out.
Old March 16th, 2012, 00:20   #15
sqhschief
sqhschief's Avatar
So when I check these bushings or joints or whatever, do I just grab on either side of the joint and see how much it moves around? I'm just not understanding what I should check here. Also, how might I test the CV joints? Thanks.
EDIT: Oh and to comment on your signature Powder_Hound, it's not called dope because it makes you dumb. Dope is short for Dopamine which is a chemical known as neurotransmitter that is involved in reward system of the brain. Stimulants such as Methamphetamine, Cocaine, or Nicotine act as agonist's increasing Dopamine levels much higher than normal, thereby increasing sensed pleasure by the user. That's why it's called "dope". I just felt compelled to clear that up lol.
Front end popping sound....help invader VW MKV-A5 Golf/Jettas 11 November 13th, 2013 07:58
Popping in front end/steering. kybishop VW MKIII-A3/B4 TDIs 5 October 23rd, 2010 08:20
Popping sound from front end SheeB VW MKIV-A4 TDIs (VE and PD) 13 June 6th, 2010 16:26
Front End Make Popping Noise after Front Bearing Replacement crazywildtoys TDI 101 2 October 7th, 2009 08:24
Popping and Whining From front end.... TexasAmazon TDI 101 2 December 4th, 2006 12:54
Page generated in 0.15544 seconds with 10 queries
[Output: 133.34 Kb. compressed to 111.21 Kb. by saving 22.13 Kb. (16.60%)]
