Old March 10th, 2012, 08:29   #1
vgr
Default Blinking Oil Light / oil pressure question
I started my car this morning in my driveway after it sat for 3 days and within 15 seconds of starting my oil light started blinking and beeping. I panicked and turned the car off. (I just assume if an oil light goes off its telling me "STOP")
I checked the motor and the undercarriage for oil spray and I didn't see any, nor is there any sign of leaking oil on my skidplate. The oil level is a little lower than it was a week ago when I checked it, but not significantly.
From my research here it seems like to properly diagnose this I need to do an oil pressure test. It sounds like this issue could just be the oil pressure sensor, however, it could also be an oil pressure problem which will cook the engine quick. (according to this thread). http://forums.tdiclub.com/showthread.php?t=334289
I live 3 hours from the nearest guru so taking it to a guru would mean a 3 hour tow, or a 3 hour drive, I'm not going to do the drive if I'm in question about this (hell I'm not going to do a 30 second drive). Is this something that with the right tools, I could accomplish myself? I did some searching and didn't find anything about how to do it, maybe I missed it?
My last thought is this, from talking with a friend who owned a tdi for several years, he said had this happen to him when the car would sit for several days in cold weather, and he would assume that the oil drained from the heads, and that it was never an issue for him. How plausible is this, as this is my exact situation.
Lubrication Specialists 2 Micron CAT Fuel Filter / Dieselgeek Panzer Plate
Other Car: 1986 MB 190D 5Spd
vgr is offline   Reply With Quote
Old March 10th, 2012, 09:32   #2
jettawreck
jettawreck's Avatar
I have never had the oil light come on from sitting in the cold even for months. Oil pressure builds almost instantly, unless maybe you are using some 15w-40 dino stuff.
I did have a few randon scares when I had the 2000 Jetta TDI while cruising down the road. Shut off immediately and looked it over and when restarted, no more light/buzzer. Months or year later it would happen again. Bad sending unit/connection??
2004 Cadillac SLS (wife's)
Old March 10th, 2012, 09:40   #3
whitedog
The oil pressure switch is a single wire switch, so you can unplug it and touch it to ground to see if the flashing stops.
You should check to see what the oil pressure is though. The port thread is M10X1.0, but in a pinch you can use a 1/8 pipe thread adapter, but I don't know what it would do to the metric threads, so I don't recommend it.
Can fold paper in half eight times.
whitedog is online now   Reply With Quote
Old March 10th, 2012, 10:02   #4
vgr
Jettawreck its quartz 15w40
Whitedog great information one question however what sort of tool do i use to test the oil, and would they sell it at advanced/napa (ive never done this sort of engine dianostics). I should note that i do have the full Bentley manual and vagcom cable
Old March 10th, 2012, 10:55   #5
whitedog
NAPA should have what you need.
Old March 10th, 2012, 11:10   #6
jettawreck
jettawreck's Avatar
Wrong oil. '98 TDI is 5w-40 full synthetic. Get that out of there.
Old March 10th, 2012, 11:28   #7
vgr
Sorry, dumb not reading/typing on phone, it is 5w in the engine, I double checked the bottle I used (still in my shed)
Old March 11th, 2012, 11:30   #8
MrSafety
Newbie at Heart
Fuel Economy: ~35 mpg "as was" when purchased TDI
Default ... my Oil Pressure "idiot light" came on too... !
"vgr",
Yes, my Oil Pressure "idiot warning light" came on recently and
I too shut down the engine out of the same concern as yours....
but in my case it was my 1.6L diesel powered Rabbit p/u that is my latest project vehicle !
After checking to make sure my recent oil/filter change was still showing on the dip-stick,
I checked the pressure sender unit/switch... and not being convinced it was OK,
I changed it out anyhow for ~$8.00 !
Well my light kept turning on intermittently... so I abandoned paying any attention
to the dash cluster oil pressure Idiot Light and installed an
audible "ding-dong" alarm and hooked it up to the new pressure sender switch...
so now it really gets my attention... and essentially my problem went away.
So in my case the problem was intermittent and somewhere in the dash cluster light warning system!
Now that I have a reliable audible warning system, my idiot light still periodically comes on!
So maybe you have the same kind of problem... in your dash cluster!??
But IF I were you and you can adapt and hook up
an analog pressure gauge for a while to monitor your oil pressure
and also keep your dash idiot light working,
I would use both and look at the gauge regularly and
definitely look at it any time the dash idiot light came on!
I now kind of like my "ding-dong" alarm...
for it definitely does a better job of alerting the driver than the lights ever did!
I might keep my "ding-dong" alarm... for recently it alerted me that
I was a mere 0.5 qts low in oil when it kept giving me a single "ding" whenever I made a sharp left turn!!!
I added the oil and no more "ding" !!
Regards,
Sam Ross
Son's 2002 Jetta TDI 01M / My '81 Rabbit "Caddy" project / My '80 240D MB...
Other Projects
: Safe Intake Cleanout / IP-QA Craniotomy /
Working on way for DIYers to more fully FLUSH 01M trans as well as check/"top-off" the O1M Fluid Level.
Perform diesel purge without ingesting troublesome air !
Last edited by MrSafety; March 11th, 2012 at 11:33. Reason: [edit] in Bright Blue!
MrSafety is offline   Reply With Quote
Old March 13th, 2012, 20:27   #9
Lawman36
TDI(s): vw jetta tdi
Where is the the oil sensor located?
Lawman36 is offline   Reply With Quote
Old March 13th, 2012, 21:02   #10
whitedog
On the oil filter housing, on the left side as you look down.
Old March 13th, 2012, 21:03   #11
KROWBAR
KROWBAR's Avatar
TDI(s): 2003 NB
Don't use a 1/8 NPT in the port it will ruin it. M10X1.0 threads are not tapered but NPT threads are (i.e. crush fit). You are going into aluminum not steel. Not sure where the sender is on a Jetta but on an A4 beetle it's near the base where the oil filter is. You can put in a tee adapter and have the stock oil pressure sender as well as one for an oil pressure gauge. Takes away the guessing.
2003 - Beetle TDI 4X2
KROWBAR is offline   Reply With Quote
Old March 13th, 2012, 21:10   #12
whitedog
Absolutely agree, but sometimes a dogs gotta do what a dogs gotta do.
HELP! Oil pressure light is blinking for no reason???? and Tach question. Lemon VW MKIII-A3/B4 TDIs 5 February 15th, 2011 09:08
Oil light blinking after change of oil type BrianW TDI 101 7 August 23rd, 2006 17:24
Oil light blinking intermittently.... Lgood TDI 101 14 June 12th, 2006 14:32
Engine oil light blinking ? hddon TDI 101 10 November 4th, 2005 05:33
No "low oil pressure" idiot light at oil change Ric Woodruff Fuels & Lubricants 17 June 16th, 2000 18:48
Page generated in 0.13023 seconds with 10 queries
[Output: 112.42 Kb. compressed to 94.51 Kb. by saving 17.91 Kb. (15.93%)]
