Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old March 9th, 2012, 07:00   #1
vivithemage
Question 2000-2004 - which get the best MPG?
Which engines get the best MPG, or is it dependent on the year too?
Also, what kind of MPG can someone average going about 75~?
vivithemage is offline   Reply With Quote
Old March 9th, 2012, 10:15   #2
Turbospool
Turbospool's Avatar
Fuel Economy: 57.0 mpg running average on the Jetta, and 41 mpg on the Passat
Check the milage thread for your own reference. 2000- 2003 will be slightly best with the ALH engine and a manual tranny, driver will also have a lot to do with actual achieved. Going 75mph will not get you the best however.... you would need to slow down a bit 60-65mph to get average of those getting the best. 50-60 mph will do it best, hope this helps.
DG racepipe, muffler/catectomy, 2.5 PP downpipe from Kerma, 3"exh., Sprint 520's, Rocketchip stage 2, Scanguage II w/ boost xguage,
2004 Passat unchained 180k on clock Rocketchip stage 2
Turbospool is offline   Reply With Quote
Old March 9th, 2012, 10:16   #3
yatzee
yatzee's Avatar
TDI(s): see sig
i found my ALH was better in town, my PD better on the highway. I drive around 75 most of the time and the .658 5th gear was a great mod.
2005 C230 6 spd, 1994 E280 5 spd, 1991 405 mi16, 1986 190e 2.3-16. No TDIs in the fleet for now
Please use the search function
yatzee is offline   Reply With Quote
Old March 9th, 2012, 11:03   #4
vivithemage
Thanks, I like the .658gear mod idea.
Old March 10th, 2012, 09:47   #5
Randall
Fuel Economy: 850 mile club, on the 98
I want to do the 658 mod too! I have it on my 2000 but want to do it on the 98. The 2000 is a beast. Way non stock. I fell down the performance rabbit hole with the 2000. Want to go pure efficieincy with the 98.
I am open to any advice!
I am sure glad I own a VW bug. It keeps me occupied with constant repairs so life never gets boring.
Randall is offline   Reply With Quote
Old March 24th, 2012, 04:46   #6
brax4x4
My '03 Jetta, 5sp manual transmission gets a consistent 45-47mpg driving highway @ 75+ with the air on. I have 199,980 miles on it and still going strong. Like others said if you back it down to around 55-60, the mileage goes up to the 50mpg range.
brax4x4 is offline   Reply With Quote
Old March 27th, 2012, 11:33   #7
CStone
CStone's Avatar
I have a 0.658 gear in the car in my sig. Drive 200 miles/day - all but 10 miles are interstate at 80mph indicated (really about 77mph). 242k+ on the clock. All original hardware except for head at 150k due to premature TB break. No visible damage due to TB break, but replaced the head just to be safe.
This time of year, at that speed, I get 54-55mpg. Winter/summer I get closer to 51-52mpg.
C. Stone
CStone is offline   Reply With Quote
Old March 27th, 2012, 13:20   #8
VWBeamer
Fuel Economy: 42.79 mpg Woot!
I also have owned both and share your findings on ALH vs PD. The ALH was about 1.5-2 mpg better around town and the PD is about 1 mpg better highway.
800 club. 828.5 miles, 16.33 gallons, 50.79 mpg.
2004 Jetta GLS Wagon TDi-17/22, 2.5 DP.2.5 Exhaust, Stage 5 Malone Tune.3 bar MAP, pd150 Injectors, Ebay FMIC, 1.8T Pancake pipe. Gutted PD100 intake.
VWBeamer is offline   Reply With Quote
Old March 27th, 2012, 16:26   #9
josh8loop
josh8loop's Avatar
Fuel Economy: 45 MPG City with the previous 01M, 5-speed 60+ MPG City. Always searching for ways to make it better!!
You can also go to the fuelly website and search vehicles. There are alot of the jetta TDIs on there, and millions of miles tracked. It paints a pretty interesting picture if you take the time to look at it. If I ever contemplate another vehicle purchase I will be using that website to guide my decision.
2002 VW Jetta TDI 5-speed(completed 01M-5-speed swap at 155K miles) 60+ MPG City.
Experimenting with the "Hybrid" 205 Deg F T-stat:
http://forums.tdiclub.com/showthread.php?t=306799&page=4
Now have Nokian Entyre Low RR tires!
josh8loop is offline   Reply With Quote
Old March 28th, 2012, 17:11   #10
Wksg
Fuel Economy: 64/56/45mpg
Very happy with my '03! Just turned over 390K miles today, and going to get a 1000 mile tank in March in Michigan! (yes, with summer warmth lately...)
'03 GLS TDI Wagon, 403K miles, .658 5th gear, RC2, ventectomy, T4 nozzles, Stant 195F Thermostat
Wksg is offline   Reply With Quote
Old March 28th, 2012, 17:32   #11
tdidriver20
TDI(s): 2003 TDI
Fuel Economy: best - 58, worst - 43, avg - 52
"This time of year, at that speed, I get 54-55mpg. Winter/summer I get closer to 51-52mpg."
CStone, Could you please explain how you get 54-55 @ 80 mph. we drive the same car, but I can only achieve that with going 65 mph. I only drive about 80 miles per day, but only 10 of that is non-highway. what mods do you have, etc. thanks
tdidriver20 is offline   Reply With Quote
Old March 28th, 2012, 17:39   #12
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
My findings were quite similar as well.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old March 30th, 2012, 05:59   #13
CStone
CStone's Avatar
Sure thing. First of all, I'm really going 77MPH at an indicated 80MPH as I said in the post. I was getting a consistent 50-51MPH tooling around at interstate speeds for the first few years I had the car, but in the past 2 years I've started to tinker to gain fuel economy. I have done a few mods, fuel-related or not, to gain either fuel economy and/or range in no particular order:
- Snowscreen/intake cleaning (dunno if this matters)
- I stopped using cruise control on my commute.
- Italian tune-up once a week (shift @3500 or so instead of my normal 2600-3000 for one trip through gears)
- 4 oz. Stanadyne in every tank. (yes this is factored into my calcs)
- 0.658 gear (this gave me about a ~1-2MPG gain)
- Timing adaptation via VCDS to 4* BTDC from 1* BTDC . (this gave me about a ~1-2MPG gain)
- ventectomy (not related to economy, but does allow 800+ miles per tank which translates into 4-days' commute for me.)
- 45 cetane fuel. (I do see about 0.5-1.0MPG for 45 cetane fuel from one store vs. the 40 cetane from other stores on my commute)
Biggest factor, I think, is how I drive. My commute allows me to get up to speed and hold that speed for essentially the entire 100 miles without having to change speeds due to traffic conditions.
Another note is that MPG is based upon trip-meter vs. amount to refill tank, entered into fuelly. I always fill to the top of the neck so that I minimize the error in the amount of fuel from tank to tank and more importantly ensure that I can drive 4 full days before I have to refuel.
C. Stone
Old March 30th, 2012, 20:20   #14
tdidriver20
TDI(s): 2003 TDI
thanks for the info, CStone. I have recently started doing Italian tune-ups and have seen a slight bump in FE. I don't use cruise control as I have determined that my foot is better for FE. Unfortunately, I don't (and won't) have the money for the .685 gear, because I am only going to commute to school for another 2 yrs, therefore, not enough time to break even or recoup money. As for 45 cetane, I usually use Turkey Hill gas (other places called Kroger) and I seem to get better mileage out of that vs. Hess or Wawa or others.
A ventectomy and snowscreen clean is probably next on the list for me.
That leaves the timing adaption. Could you please expand on this? I haven't found much on it but I am interested in knowing more.
thanks a lot!
Old March 30th, 2012, 20:28   #15
AARRTTDI
Fuel Economy: 48 city 62 Hwy
I have 2010 Sports Wagon. I can Drive from Newport Coast Ca to Tempe AZ {7 hours} on 3/4 of a tank. I have a automatic. I have also changed the tires to Nokian Entyre
and they get me 10 MPG more then the "Made in China" ones that came with the car.
Does Anyone know if I can run my TDI and Liquified NAT GAS with modifications.
AARRTTDI is offline   Reply With Quote
HELP ME!! Only getting 32 MPG in my 2004 Golf TDI! jgsuperpants TDI 101 19 July 19th, 2008 00:49
Poor MPG in 2004 Golf toobs18 TDI Fuel Economy 6 July 3rd, 2007 06:34
What's going on with the 2004's estimated MPG? LeoTDI TDI Fuel Economy 12 June 1st, 2004 10:28
2003 - 2004 TDI - MPG? Coorsleftfield VW MKIV-A4 TDIs (VE and PD) 14 May 13th, 2004 08:35
2003 to 2004 MPG difference Strong TDI Fuel Economy 2 April 14th, 2004 12:26
Page generated in 0.15686 seconds with 10 queries
[Output: 130.00 Kb. compressed to 108.72 Kb. by saving 21.28 Kb. (16.37%)]
