Old March 1st, 2012, 14:20   #1
jdbrinkman
jdbrinkman's Avatar
Fuel Economy: 49mpg
Default quantity adjuster p1562 HELP
i have a 2000 tdi with 122,000 miles. p1562 has came up . Ive cleared codes and it comes back on with CEL and flashing GP light. I have VCDS and tried the hammer mod and adjusted fuel quantity to 4.2 mg/s at operating temp. but codes still comes on. Ive replaced fuel temp sensor. still same code. I was going to take out the quantity adjuster and clean it and reset everything but after cutting the spot welds on the circuit board what kind of solder is needed to reattach the electrical to the board? is this hard to do?
Thanks,
John
jdbrinkman is offline   Reply With Quote
Old March 15th, 2012, 14:08   #2
jdbrinkman
jdbrinkman's Avatar
Fuel Economy: 49mpg
anyone please help?
Old March 15th, 2012, 15:29   #3
Nutsnbolts
Nutsnbolts's Avatar
Fuel Economy: Average is about 46 now (2016)
I've never tried to actually remove the QA board from the housing, but I would bet that you could clean it in place with electronics cleaner. The connections that they use on the QA leads (that are just inside the boot where the wiring goes into the pump) may not be low-temp solder- I tried to undo them a few years ago with no success, using my soldering gun at the shop, and the connection seemed to ignore me and laugh...
-Rich
574,500 miles now and counting...25,500 until cluster swap!
'00 Jetta GLS, '03 Jetta GL, 08 Highlander, '72 Plymouth Satellite, '68 Chrysler 300, '75 Benz 300D, 78 LeSabre Turbo.
Nutsnbolts is offline   Reply With Quote
Old March 16th, 2012, 06:56   #4
KLXD
They are welded, not soldered as the OP observed.
I would clean and tin the conductors, wrap the joints with fine wire, maybe steel, then solder them. Acid flux will probably be required.
I had the same issue as well as surging. I was going to try the same thing but opted for a different pump.
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
Old March 20th, 2012, 13:30   #5
jdbrinkman
jdbrinkman's Avatar
Fuel Economy: 49mpg
thanks that what i was looking for!.
Old March 23rd, 2012, 13:41   #6
Mass. Wine Guy
Mass. Wine Guy's Avatar
I got the same code for most of one day a couple of weeks back. Then the fault lights went off. Today I drove over to see Keith in Lowell who very kindly scanned my car. The QA fault's still there. He has a used QA that he could install.
At the moment there's nothing wrong with how my car drives or operates. I'm leaning toward preventive maintenance and replacing the unit. If not, should I just keep going and fix it if it goes belly up? I can accept driving in limp fashion if it does break. But I don't enjoy being stuck on the side of I-95 at 2 am.
Mass. Wine Guy is offline   Reply With Quote
Old June 29th, 2012, 19:16   #7
biker250
TDI(s): '02 Golf
*bump
Does anybody have an answer to Mass. Wine Guy's questions ^^^^^^^^ because I am in the same exact situation right now. The code is there and the lights are on, but the car drives fine........what is the harm in ignoring it for now and keep on driving? Thanks.
biker250 is offline   Reply With Quote
Old June 29th, 2012, 20:30   #8
Mass. Wine Guy
The way Keith explained it to me, if and when the part fails, the car will still drive. But it will be sluggish.
Old July 2nd, 2012, 08:11   #9
KLXD
I drove for years with the flashing plug light due to QA error codes. Had surging at idle and low "throttle" situations. Ran fine at speed.
Finally installed another pump. Some day I'm going to put the old QA on the good pump to see what happens.
Old December 2nd, 2012, 19:50   #10
jdbrinkman
jdbrinkman's Avatar
Fuel Economy: 49mpg
Finally replaced my pump. no more CEL and flashing glow plug light !
Old December 3rd, 2012, 04:45   #11
biker250
TDI(s): '02 Golf
Where did you end up getting a new (or reman) pump?
Old April 24th, 2013, 09:59   #12
jdbrinkman
jdbrinkman's Avatar
Fuel Economy: 49mpg
boraparts.com
Old April 25th, 2013, 04:49   #13
biker250
TDI(s): '02 Golf
Going on a year now and still have the CEL and flashing glow plug light. Sometimes it'll go away for a week or 2, but for the most part, it's on all the time. Car still seems to run OK.
Injection Quantity (IQ) Nozzle Size - Quantity Adjuster (QA) relationship mnorton TDI Power Enhancements 33 February 18th, 2017 06:29
Quantity adjuster chuckcun TDI 101 5 January 15th, 2012 09:59
Emission: P1562 Quantity Adjuster (N146) upper limit reached NutnBolt TDI 101 3 March 20th, 2011 18:26
Quantity Adjuster N146 dieselDaveB VW MKIV-A4 TDIs (VE and PD) 2 January 14th, 2010 10:11
P1562 quantity adjuster upper limit reached?? help mk2 cosworth TDI 101 3 October 28th, 2008 09:40
Page generated in 0.16006 seconds with 10 queries
[Output: 110.03 Kb. compressed to 91.78 Kb. by saving 18.24 Kb. (16.58%)]
