Old March 1st, 2012, 12:34   #1
dpg
Default Adjusting Headlights
Anyone know how to adjust the aftermarket headlights from Ed? Also, what height are they supposed to be adjusted at? Thanks in advance!
These are the headlights I need to adjust:
dpg is offline   Reply With Quote
Old March 1st, 2012, 12:36   #2
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
Adjust them so that you can see an acceptable distance in front of you while traveling at highway speeds. Be cognizant of oncoming traffic - make sure your lights aren't adjusted so far out that you're blinding them.
Some people adjust headlights by making tape marks on a garage door or the wall of a building. I prefer to go for a drive, stopping periodically to make adjustments until I'm satisfied with the light output.
Trusted TDI Mechanics Map || TDIClub Chat
Old March 1st, 2012, 12:44   #3
dpg
Cool, thanks! I've been doing both over the years. Adjust against a wall and take it for a drive as well just to make sure and make adjustments that way over the course of a few nights.
Do you know how to actually adjust the housings? Are there adjustment screws somewhere. I don't want to start turning random screws I find on the housing.
Old March 1st, 2012, 13:07   #4
Good Ol' Boy
VeeDubTDI's Avatar
I have no idea how to actually adjust the lights on your car -- never messed with one.
One pro tip I have is to adjust the passenger's light slightly higher than the driver's light. You'll be able to see the shoulder a little bit better that way without affecting oncoming traffic.
Old March 1st, 2012, 13:23   #5
dpg
Thanks for the tip VeeDub
After some more searching I happened to find a thread about it on vortex. Their search sucks, you're better off using google to search vortex threads.
Anyway, it's the white allen key screws just inside the low beam rubber cap.
Old March 1st, 2012, 13:31   #6
Good Ol' Boy
VeeDubTDI's Avatar
Searching on most forums is generally terrible. Best bet is to use google and "site:forumname.com" for searching.
Old March 1st, 2012, 13:36   #7
BarnyardsTDI
Fuel Economy: Depends on my right foot
With those lights (HID's) you should be able to adjust using VAGcom. I remember seeing a module for that in the list.
BarnyardsTDI is offline   Reply With Quote
Old March 1st, 2012, 13:38   #8
MayorDJQ
There may be an adjuster on the housing. Look for phillips head, torx, or allen head screws. On the OEM housings they're usually a different color than all the others in the area.
MayorDJQ is offline   Reply With Quote
Old March 1st, 2012, 13:50   #9
MN_TDI12
Check out this link for the properly adjusted beam height.
http://www.danielsternlighting.com/tech/aim/aim.html
As far as how to adjust them... I recall reading a thread about it but don't recall where. I do recall it requiring adjusting the highs, then lows, then highs again... or maybe it was flipped... idk.
2012 VW Jetta TDI w/ Nav, Malone Stage 1.5 and DSG Tune, 2Micron's Contain Flow
I have VCDS - Micro/CAN
MN_TDI12 is offline   Reply With Quote
Old March 1st, 2012, 13:50   #10
dpg
With factory HIDs I think you're right. These are the aftermarket ones though. No auto leveling feature on these
Old March 1st, 2012, 19:03   #11
elro
There are two white plastic 6mm hex socket adjusting screws on each light. The top screw adjust from left to right and the lower screw adjusts the up and down. There are also leveling motors in each light and PHD-12v is working on the wiring with leveling switch to try and make them functional.
Lots of info here: http://www.golfmk6.com/forums/showthread.php?t=32843 and here http://www.golfmk6.com/forums/showthread.php?t=24942
elro is offline   Reply With Quote
Old March 2nd, 2012, 07:55   #12
BarnyardsTDI
Ahh good call.
Best Location for adjusting headlights ?? Sebpt Ontario 5 January 20th, 2009 10:30
Adjusting headlights 3800rpmDiesel TDI 101 13 October 31st, 2008 08:01
Adjusting headlights? Longsnowsm General Automotive 13 May 8th, 2006 16:37
adjusting headlights bowlerman TDI 101 2 November 18th, 2002 06:03
Adjusting Headlights JoeDiesel VW MKIV-A4 TDIs (VE and PD) 5 September 17th, 2001 18:14
Page generated in 0.20857 seconds with 10 queries
[Output: 110.95 Kb. compressed to 93.56 Kb. by saving 17.38 Kb. (15.67%)]
