Old March 1st, 2012, 06:43   #1
rcornejo
TDI(s): 2.5 ACV
Default Doubst with dimension units in Vag-com
Hello dear fellow members of this forum,
I'm new here, I'm Chilean and hope you could understand my basic English. Thanks in advance.
Since a year ago we have a motorhome VW, 2.5 TDI year 1997, motor type ACV.
Recently I've bought an OBD cable and the Vag-com 311.2 SW, and I'm trying to check and understand some things.
My first question is what units are mg/R (is R=revolution?), and what unit is the H in mg/H, and how is the relation between the two. ??? Besides, What is "bin. bits"???
This is because I'm isolating why my turbo is not working, the first task is to check all of the hoses, then the MAF, solenoids, etc.
I hope someone may help me with this stuff.
Regards from Chile,
rcornejo is offline   Reply With Quote
Old March 1st, 2012, 13:26   #2
Sebastian
Not sure how you could have aquired a VAG-COM Version from 2003 "recently" but feel free to use the more current VCDS-Lite from our website with your 3rd party interface.
http://www.ross-tech.com/vcds-lite/download/index.html
As for the Units, the mg/R stands for Revolutions or Strokes while the mg/H is the German term for Hub which also means Stroke. Bin Bits means Binary Bits, but that gets us back to a more current version of VCDS which would probably have proper label files and specifications for your Engine to begin with.
Sebastian
Sebastian is offline   Reply With Quote
Old March 2nd, 2012, 04:16   #3
rcornejo
TDI(s): 2.5 ACV
Hello Sebastian,
Thanks for your answer.
I will follow your advice tryng with a lite version from Ross-Tech.
And thanks again for clearing my question about dimensions, i've been asking for them in Spanish (from Spain) forums but it seems that nobody knows about that.
Regards from Chile,
rca
spline hub dimension carrarmat Upgrades (non TDI Engine related) 14 September 18th, 2011 10:52
Seat Dimension Changes CsTDI General VW Discussion 3 February 2nd, 2011 18:09
tdi axle dimension pcbootleger VW MKIV-A4 TDIs (VE and PD) 3 February 3rd, 2009 20:24
Anyone know the dimension of this nut? Nico3d3 TDI 101 1 May 16th, 2008 19:49
Vag-Com Compatible head units fishmando Upgrades (non TDI Engine related) 2 June 14th, 2006 14:02
Page generated in 0.13806 seconds with 10 queries
[Output: 58.10 Kb. compressed to 52.85 Kb. by saving 5.25 Kb. (9.04%)]
