Old February 29th, 2012, 18:40   #1
Texas_sky
Fuel Economy: unknown at the time, waiting for engine swap
Default Running slow after oil pump tensioner/intake cleaning job
I have one small issue, After we did the oil pump tensioner which requires the timing belt to come off... its been running slow ever since and the temperature is lower then it should be, maybe the timing is slightly off? We also cleaned the intake manifold/egr. We also set the injection pump timing to 60 degrees with a rosstech. It feels almost as slow as a mk2 diesel but I can still get it up to 75-80 if need be on freeway just takes about 30-40 seconds or longer
Texas_sky is offline   Reply With Quote
Old February 29th, 2012, 18:57   #2
Seatman
Seatman's Avatar
Fuel Economy: No idea
Sounds like you might have missed something in the turbo/boost path somewhere when puting it all back together. Check all the boost pipe connections and vac lines, maybe one of the vac lines is off or is split.
Seatman is offline   Reply With Quote
Old February 29th, 2012, 23:14   #3
Texas_sky
Thanks Seatman I will be sure to check those two things next time I get back in garage or when weather warms up this weekend. What explains why its running cold and won't heat up all the way?
What Labor is Required to Install OIL PUMP CHAIN TENSIONER? Texas_sky VW MKIV-A4 TDIs (VE and PD) 12 February 13th, 2012 04:40
RE: 2002 intake cleaned, new tb water pump and tensioner. rhinotalon VW MKIV-A4 TDIs (VE and PD) 1 June 7th, 2010 15:30
Cleaning Intake Stopped My Oil Usage Frankenwagen VW MKIV-A4 TDIs (VE and PD) 3 January 2nd, 2004 21:00
Timing belt, water pump, intake cleaning = $$$ Help! VIC VW MKIV-A4 TDIs (VE and PD) 16 November 27th, 2003 09:12
My First Intake Cleaning Job CoolWhiteDude VW MKIV-A4 TDIs (VE and PD) 17 June 11th, 2001 10:40
Page generated in 0.14542 seconds with 10 queries
[Output: 57.57 Kb. compressed to 52.39 Kb. by saving 5.18 Kb. (8.99%)]
