Old February 29th, 2012, 15:44   #1
mkhuri
TDI(s): 2004 Passat
Default Incorrect Gear Ratios means new transmission??
My 2004 Passat TDI lost significant power and wouldn't shift past 2nd gear. I took her into VW and they found error codes P0733, P0730, P0732, signaling incorrect gear ratios for 2nd, 3rd and the gear box. They said they need to replace the transmission and quoted me $4,500 parts & labor. Is this for real?! Ive only got 120,000 miles on it and the car is worth about $9,000-$10,000. Please let me know what options I may have. Bummed out.
mkhuri is offline   Reply With Quote
Old February 29th, 2012, 17:11   #2
PDJetta
PDJetta's Avatar
I just checked my Bentley and shure as crap, P0730 is "Incorrect gear ratio", P0732 is "Incorrect gear 2 ratio" and P0733 is "Incorrect gear 3 ratio". I have no idea what this means and have never heard of this before. I believe the gear ratios are set when the transmission is made and can not change. I take it that this is an automatic tranny. I am familiar with manual trannys and have NEVER encountered this terminology. I am perplexed.
One possibility is the dealer gave you the wrong codes.
I googled on the first code you stated and this came up:
http://straighttalkautomotive.com/OBD2/P0730.html
Here is info on the second gear code:
http://helpforcars.net/obd_codes/p0732_volkswagen.html
OK, the above link explains the monitoring going on:
"This diagnosis monitors actual gear position by checking the torque converter slip ratio calculated by Transmission Control Module (TCM) as follows:...." I never knew this was monitored.
--Nate
Old February 29th, 2012, 18:45   #3
MonsterTDI09
MonsterTDI09's Avatar
Sounds like the T/C is tost.This is a know problem on the Passot.Has the blance shaft been replace on your car."If not" It will be problem down the road it around 3K job.You may get lucky you just need a T/C if the trans is not tost.If you want a second opion look up "Wild Rose" he is right out side of La.Sorry for the bad news
Wild Rose Motors
Leonard Harview aka Harvieux
13253 Meyer Road
Whittier, CA 90605
562-946-9000
wrmltd@pacbell.net
www.vwtdionly.com
2010 Jetta sedan TDI DSG Platinum gray metallic.Build date (5/10) Mods ----EV skid plate, E code head lamps, Polar FIS
A cleaning service for DPF. http://www.dpfregeneration.com/ I have no affiliation
MonsterTDI09 is offline   Reply With Quote
Anyone Have the Gear Ratios for an 02J EUH Transmission? PDJetta VW MKIV-A4 TDIs (VE and PD) 3 September 19th, 2011 22:02
Gear ratios in manual transmission SCVW VW MKIV-A4 TDIs (VE and PD) 0 November 13th, 2009 14:39
Different gear ratios? 01JettaTDIDriver VW MKIV-A4 TDIs (VE and PD) 27 February 16th, 2006 14:19
Gear ratios??? WindWagen Upgrades (non TDI Engine related) 9 April 3rd, 2003 09:51
Passat 5th gear ratio incorrect in Bentley Chris Bell VW MKIV-A4 TDIs (VE and PD) 4 February 9th, 2002 06:27
Page generated in 0.13668 seconds with 10 queries
[Output: 59.96 Kb. compressed to 54.20 Kb. by saving 5.76 Kb. (9.61%)]
