Old February 21st, 2012, 07:23   #1
bc151rules
Default Timing Belt Replacement Cost?
I've decided to change my Timing Belt, I'm at about 82K miles.
I started calling around to get pricing and was a little surprised by the first estimate. Does $800.00 sound resonable for timing belt/component change?
Thanks!
bc151rules is offline   Reply With Quote
Old February 21st, 2012, 07:45   #2
slamhouse
slamhouse's Avatar
Fuel Economy: Better than 95% of cars on the road
If the water pump is being changed as well with an updated metal impelled pump, then yes. For a shop that is...
For a guru to do the job(recommended highly) you might be looking at about 600$ or so with better quality work.
slamhouse is offline   Reply With Quote
Old February 21st, 2012, 07:49   #3
nord
And about $350 if you can do your own work... That is as long as you have the locking tools.
nord is offline   Reply With Quote
Old February 21st, 2012, 07:59   #4
bc151rules
This was an independent, local shop with high reviews for working on VW's, etc. I don't have the tools to do this myself, and I'm not sure I'd want to.
Any other local guru's in the Akron/Cleveland Ohio area?
Thanks!
Old February 21st, 2012, 09:06   #5
Andrewh
local guru to me quoted 675. so not too far out of line.
vw dealer wanted like 1200 I think.
Andrewh is offline   Reply With Quote
Old February 21st, 2012, 09:08   #6
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
The BRM is about $750 here, parts and labor.
Keep in mind, the bitterness of poor quality (be it parts or workmanship) lingers long after a cheap price is forgotten.
oilhammer
www.cardocautomotive.com
Old February 21st, 2012, 09:12   #7
earlthepearl
I wonder what the dealership would try to charge. Had mine done by a guru. $787.
earlthepearl is offline   Reply With Quote
Old February 21st, 2012, 09:17   #8
bc151rules
Alright then, sounds like this price is in line!
Thanks for the feedback.
Old February 21st, 2012, 09:49   #9
tdiatlast
Have you looked here?:
Trusted TDI Mechanics - By State ( 1 2 3 4 5 ... Last Page
2014 Passat TDI SEL DSG (returned 12/14/16)
2009 JSW TDI DSG (returned 12/15/16)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
tdiatlast is offline   Reply With Quote
Old February 21st, 2012, 10:00   #10
Henrick
False. It was never updated nor needing the update.
Although I'm on the other side of the pond, I still might share the info. I asked for price and labour of the TB job one of our business partners who specialise in VWs. The parts (TB, roller, tensioner, pump, no bolts or coolant) was ~175$ and they promised to do the job for $80. But again, this is our business partner, that's why such a reasonable price.
Henrick is offline   Reply With Quote
Old February 21st, 2012, 10:02   #11
oilhammer
oilhammer's Avatar
It is a pretty common problem here to see broken impellers. Which is why so many (including me) install the metal ones.
oilhammer
Old February 21st, 2012, 12:11   #12
ATLSilverTDI
ATLSilverTDI's Avatar
Fuel Economy: 42.5
Parts (belt, water pump, idler, tensioner and bolts) cost around $250 and average is 375-575 depending on the Guru. I priced dealers here before I did mine, and they quoted between 1100 and 1300 for a timing belt... I had a guru do it and other service for less than that combined.
2006.5 Special Edition Package 1, Reflex Silver, Anthracite Leatherette, DSG, (Sunroof),RC1+. EGR Delete
ATLSilverTDI is offline   Reply With Quote
Old February 22nd, 2012, 01:24   #13
Henrick
I think you're talking about the old style plastics then. They were updated several years ago to a more robust plastic which resists high temperatures. Plastic impeller might separate from the shaft but still it's plastic. It has also to do something with maintaining fuel economy. WPs with metal impellers also see failures. And if the metal one fails, it might destroy the block and more. Either way, both pumps (plastic and metal version) have exactly the same expected service life per book.
Old February 22nd, 2012, 04:43   #14
oilhammer
oilhammer's Avatar
Never seen a metal one break to pieces. And in the last week I've already seen a plastic one in pieces on a 2005 model car. Is that not new enough? Or is that still "old style"? What has changed in these plastics in the last 7 years?
We are still seeing plastic intake manifolds warping, too. Have those improved any?
oilhammer
Old February 22nd, 2012, 09:51   #15
psd1
Fuel Economy: See Fuelly link
Seems a little high to me, have you looked at sourcing the parts yourself? Lots of good vendors on this site that can get you you good parts for under $300!
psd1 is offline   Reply With Quote
timing belt replacement cost bozemanTDI VW MKIV-A4 TDIs (VE and PD) 46 September 27th, 2010 17:54
Timing belt replacement cost rminor VW MKV-A5 Golf/Jettas 4 December 2nd, 2009 16:23
Timing belt replacement cost? Black Dung Beetle TDI 101 10 November 18th, 2008 09:43
timing belt replacement cost jack_shellac VW MKIV-A4 TDIs (VE and PD) 10 November 15th, 2004 16:28
Timing Belt Replacement Cost marko VW MKIV-A4 TDIs (VE and PD) 5 April 25th, 2003 06:27
Page generated in 0.14970 seconds with 10 queries
[Output: 124.39 Kb. compressed to 103.46 Kb. by saving 20.92 Kb. (16.82%)]
