Old February 19th, 2012, 21:54   #1
toddmanley
Default Engine Fan Still Running after the car is turned off
I searched a few message boards and didn't find any answers yet to this situation.
This occurrence happened twice to me tonight. I drove about 8 miles out to a friend's house (80% freeway) and when I turned the car off the engine fan (not sure if it was the radiator or auxiliary fan) kept running for 30 seconds. The outside temperature was around 55* and I wasn't pushing the car hard.
Drove the same way home and when I pulled in my garage the fan(s) did the same thing, but this time for nearly 2 minutes. I popped open the hood and didn't see anything strange. Surprised that the fans were still running, I turned on the car, let it idle for 5 seconds then turned it off. This time the fans stopped.
I'm not sure what caused this behavior but I'm interested to know if anybody else has experienced this same thing.
-Thanks, Todd
toddmanley is offline   Reply With Quote
Old February 19th, 2012, 21:55   #2
bhutchins
bhutchins's Avatar
Fuel Economy: best 47
particulate filter regeneration causes this. if you turn off the engine in the middle of a regeneration, it will do it again when it heats up
Sold : 234 WHP / 404 WTQ (550 N-M)
bhutchins is offline   Reply With Quote
Old February 19th, 2012, 23:52   #3
Tcobar
I was wondering the same thing. It has happens to me about three times, with a slight smell of gasoline? New engine smells? The air was being blown in from the front and it felt like it was exiting from just behind the driver door. What do you mean by "it will do it again when it heats up"? Would you please explain a bit further?
This is our first Diesel car, so although it felt like strange behavior I just thought it was probably normal.
Tcobar is offline   Reply With Quote
Old February 20th, 2012, 00:28   #4
JSWTDI09
JSWTDI09's Avatar
-Thanks, Todd
Everyone with a 2009+ TDI has experienced this same thing. It is perfectly normal. The regeneration cycle for the DPF is burning off accumulated soot. This generates a lot of heat and the fans running prevents all the plastic bits under the hood from melting. It's nothing to worry about.
See above. The DPF (Diesel Particulate Filter) catches soot. When it gets full the ECU starts a regeneration cycle which burns off that accumulated soot. It is completely normal behavior.
A search for "fans running" or "fans racing" on this site will discover dozens of threads just like this one.
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old February 20th, 2012, 05:34   #5
tdiatlast
Odor is from the new paint/plastics, etc. getting heated for the first few times. The odor will subside over time. Engine temp rises (not seen on the temp gauge), and if the engine is idling, idle speed will bump up to c. 1k rpm.
The DPF (diesel particulate filter) generates HUGE heat, hence the fans (both) are running on high, pulling air through the radiator, around the engine, and exiting below the firewall...that's why you feel it under the body of the car.
Do an advanced search for "DPF" or "regeneration". Lots to read there.
FYI: An active "regen" will occur every 300-400 miles, unless you do a lot of highway (steady-state cruising around 2k RPM) driving, where passive regens occur as needed.
2014 Passat TDI SEL DSG (returned 12/14/16)
2009 JSW TDI DSG (returned 12/15/16)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
tdiatlast is offline   Reply With Quote
Old February 20th, 2012, 11:32   #6
TomB
Fuel Economy: 34 mpg on first tank
VW really needs to put a label under the hood saying that the fans running after engine is turned off is NORMAL.
We keep seeing the same question because it is NOT clearly spelled out or explained by the dealer during feature call out.
2007 Jeep Grand Cherokee 3.0L MB Diesel
2012 Passat TDI SEL Premium Opera Red/Titan Black
2015 Audi A3 TDI Prestige S-line Lotus Gray Metallic/Black Leather
TomB is offline   Reply With Quote
Old February 20th, 2012, 11:40   #7
MyAvocation
MyAvocation's Avatar
Or just read the manual.
"Never trust Internet quotes." - John F. Kennedy
MyAvocation is offline   Reply With Quote
Old February 20th, 2012, 21:26   #8
TDiSkater
Fuel Economy: 35 Winter/41 Summer
My sales guy did two things right for me. Set up my convenience features and told me about regens.
Said he was tired of panicked calls about cars burning up.
Still weird the first time it happens. You'd think VW would have a TDI basics brochure or some kinda quick study guide vs that stupid brochure on changing the radio stations and turning on the wipers.
VW-OEM European Steel Skidplate | 35% LLumar Tint all around | Pano Sunroof | ScanGauge II | WeatherTech Weatherflectors and Digital Fit Floorliners l Faux TDI Mirror Etching l RGM Bumper Guard | Conti PureContact | Non-OEM Aspherical Mirrors - $3 Blind Spot Mirror | 70,000 miles |
TDiSkater is offline   Reply With Quote
Old February 20th, 2012, 22:15   #9
Niner
duplicate account, banned
-Thanks, Todd
Page 320 and 321 of your Owner's Manual, that thing you are supposed to read cover to cover, to understand how your car works.
Niner is offline   Reply With Quote
Old February 20th, 2012, 22:58   #10
Tcobar
Thanks for the replies! And yes, my wife and I are both reading the manual. That's how we learned how to set the presets on the driver seat,... but haven't read this section yet. I've switched to reading on how the navigation system works.
Old February 22nd, 2012, 11:30   #11
tomo366
TDI Lifer
tomo366's Avatar
Here we go again!! this time on the Passat side......how many threads will we see here?
My page is Dedicated to the Memory of
Christopher Farnham RIP my friend!
Great friend and supporter of TDICLUB
2015 Jetta TDI SEL Tornado red
2014 BMW 328D XDrive Glacier Silver
2004 Jeep Grand Cherokee Black!
tomo366 is offline   Reply With Quote
Old February 26th, 2012, 20:49   #12
tdi90hp
Question
did you expect different?
tdi90hp is offline   Reply With Quote
Old February 27th, 2012, 05:43   #13
tomo366
TDI Lifer
tomo366's Avatar
Yeh I guess....
Old February 27th, 2012, 06:05   #14
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
It averages about 5 a month, give or take.
oilhammer
www.cardocautomotive.com
Old February 27th, 2012, 06:24   #15
tomo366
TDI Lifer
tomo366's Avatar
I have said it before and I will say it again....these cars are not for everyone! Please check it out carefully before you buy! With gas prices rising as they are they are going to sell a bunch! And knowing what I do now I wouldn't buy one!
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
Fans running after car is turned off? EnigmaMan VW MKVI-A6 Jetta Sedan (~ 2011+) 16 January 1st, 2012 10:48
fan is running after turning the car off... alragrossman VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 33 July 5th, 2011 20:55
Fan will not shut off when car is not running andrewjoseph TDI 101 7 November 24th, 2010 19:14
Both Radiator fans keep running after engine turned off Iwonder8 VW MKIV-A4 TDIs (VE and PD) 2 June 7th, 2010 13:47
Fan coming up when car is turned off vik VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 19 April 30th, 2010 09:19
Page generated in 0.18537 seconds with 10 queries
[Output: 129.14 Kb. compressed to 107.64 Kb. by saving 21.50 Kb. (16.65%)]
