Old February 19th, 2012, 12:03   #1
diesel142
Default Cooling fans won't shut off
I came out of the house today and both cooling fans where running on my 2000 golf it hadn't been started yet and it's 32 degrees outside. I pulled the plug for the temp sensor on the drivers side of the radiator but they still won't shut off. Any ideas?
diesel142 is offline   Reply With Quote
Old February 19th, 2012, 12:18   #2
PB_NB
PB_NB's Avatar
I have the reverse problem, my fans wont come on at all. I think my problem is the fan control module which is probably the same problem you have. It is located under the battery or in that area. I have seen these pretty cheap online and very expensive at the dealership. You will need to get the number off the actual unit to ensure you get the right one.
Hope this helps.
1999 New Beetle TDI - Bosio 1019's, Malone S4, Skid Plate, Neuspeed Sway Bars, KW V2, 19's BBS-CH, Spyder LED's, EGR Delete, VF Mounts, South Bend Clutch, B&M Shift Kit, VNT17, Custom Side Mount Intercooler, HPA Big Brakes 355mm Ft/335mm Rr, 2.5" Custom SS Straight Through Exhaust, Colt Stage 2 Cam, 3 Bar Map.
PB_NB is offline   Reply With Quote
Old February 19th, 2012, 15:40   #3
deadend9009
deadend9009's Avatar
TDI(s): '03 Wagon
Run a search, the problem is well documented (both cases actually!)
The relay is indeed right below the battery, you need to be under the car to see it without removing anything (unless you still have a skidplate!)
If they don't work, check and see how difficult it is to turn them by hand. Mine were seized!
deadend9009 is offline   Reply With Quote
Old February 19th, 2012, 17:15   #4
diesel142
I just pulled the fuse on top of the battery to shut them off,I should be okay in this weather and will pull the relays under the battery to get the # Off of them and get them ordered.
Old February 19th, 2012, 20:25   #5
Sky King
Sky King's Avatar
Fuel Economy: Under 40 with the Cam upgrade and Malone Tune
Mine came back from the dealer and the fans would not shut off. Of course, the dealer said that was normal. Even 3 hours later when they were still running. I just disconnected the battery overnight. When I reconnected the battery they did not come back on. Of course, when my wife brought the car back to the dealer, the guy made fun and acted like he was listening for the fans, knowing they were not running. My wife responded in kind. A couple of months later the guy got moved to another job. He was a true idiot.
Cheers,
Gene
2006 Beetle TDI
Sky King is offline   Reply With Quote
Old February 20th, 2012, 09:10   #6
MrSafety
Newbie at Heart
Fuel Economy: ~35 mpg "as was" when purchased TDI
I suspect that the control function for one or both of these fans is actually both timer and relay...
probably both in the same component that are commonly called "fan relay" or two separate fan relays.
IF this was my DIY trouble-shoot/repair project, I would try to:
(a) determine the actual current loads there are when:
...... (1) the one fan is operating, and
...... (2) both fans are operating
(b) and then see if I could find out what the "continuous operating amperage"
rating is for the OE relay/relay(s) are.
IF these relays are not rated substantially higher than the actual amperage loads,
then this could mean the relay's power-on contacts stick closed and
then subsequently release due to cooling off or vibration!
--------------- Try this ---------
IF it stays on again... after you turn off the key and it has cooled some,
"rap" on the relay's outer case and IF the relay turns off in response,
well this is strong evidence as to what is happening!
You can purchase heavy-duty 50A, 100A & 200A industrial relays
for far less than what I suspect VW OE relays cost!
I did this to solve my repeated Glow Plug burn outs on my Mercedes 240D!
My last two 100A relays cost me less than $20/ea...
and I will be adding one of these to control
my new '81 VW Caddy P/U project car's GP system!
[IMPORTANT edit] - Keep in mind that these electrically controlled fans are
IMPORTANT in that they help to solve overheating and
damage to the aluminum heads that "percolate" when the engine is first shut down...
and the fan's continued operation is needed to reduce the
potential for warping or other damage to the weaker parts of these heads!
So don't let your zest to come up with a DIYer solution for "run-on" fans
end up costing you major engine damage!
Regards,
Sam Ross
Son's 2002 Jetta TDI 01M / My '81 Rabbit "Caddy" project / My '80 240D MB...
Other Projects
: Safe Intake Cleanout / IP-QA Craniotomy /
Working on way for DIYers to more fully FLUSH 01M trans as well as check/"top-off" the O1M Fluid Level.
Perform diesel purge without ingesting troublesome air !
Last edited by MrSafety; February 20th, 2012 at 09:26. Reason: [edit] in Bright Blue!... [final edit] in Bright PINK!
MrSafety is offline   Reply With Quote
New Battery - cooling fans wont shut down Tnsee894 VW MKV-A5 Golf/Jettas 7 February 10th, 2011 09:22
2000 golf tdi coolant fans won't shut off brenner TDI 101 9 August 28th, 2010 10:25
Engine cooling fans won't stop TDIfor TDI 101 8 July 9th, 2010 18:22
cooling fans won't shut off and A/C dosn't work nev89117 TDI 101 1 July 26th, 2005 17:18
Cooling fan won't shut off. jpco VW MKIV-A4 TDIs (VE and PD) 3 October 6th, 2004 06:24
Page generated in 0.14852 seconds with 10 queries
[Output: 76.53 Kb. compressed to 67.04 Kb. by saving 9.50 Kb. (12.41%)]
