Old February 16th, 2012, 20:28   #1
CoasterMoose
CoasterMoose's Avatar
Default Need a Balance Shaft Module kit!!!!
Hi Fellow B5.5 TDI friends, I am looking for a BSM module for my 05 BHW Passat TDI wagon. My oil pump chain has started rattling pretty loud at 97k miles, and I need to get it upgraded. The shop I am working with near Seattle, WA has said it will take 3 weeks to get the BSM kit.
HELP!!
Does anyone have a BSM kit that I can purchase and have shipped to the Seattle area? If so, I will be eternally grateful! Otherwise, I think I'll need to rent a car for the next 3 weeks because I'm afraid to drive it.
Thanks! If you can help, please call my cell at 253-278-7344.
Scott aka CoasterMoose
Moose
____________________
Former Owner of a wonderful 2005 Passat TDI Wagon - Unchained on Leap Day 2012
CoasterMoose is offline   Reply With Quote
Old February 16th, 2012, 20:35   #2
tditom
Fuel Economy: Golf: 54/48/43.5 B4 Passat: 52/48.5/45 B5.5 Passat: 30 mpg mixed
Boraparts has the kit. Shouldn't take more than a week to get it.
EDIT: Oops- looks like I was mistaken
VW Passat TDI Standard BHW Balance Shaft Module Repair Kit 04-05
[03G198295AP]$1,298.00
Click to enlarge
This now includes the latest revision Balance Shaft Part number (May 2011) of 03G103295AP / 03G103537B
Upgrade your Passat balance shaft before it goes out on you! Special price. Includes all dealer parts, OEM VW--with everything you need to do the change:
As far as we know this is the best price around, we will price match though as needed.
Kit includes:
OEM Differential case complete with shaft, gears, and new oil pump --- 03G103295AP
OEM drive gear for balance shaft --- 03G103305C
OEM Crankshaft replacement gear --- 03G105212D
OEM Balance shaft bolt --- N91051201
OEM Bolt for front of balance shaft --- N91123401
OEM Bolt near oil pump at front of balance shaft --- N90977502
OEM Crankshaft pulley bolt --- WHT004573
5x OEM Balance shaft bolts --- N10601402
4x OEM Bolts from balance shaft to drive gear --- N91121301
2x OEM Bearing cap bolts --- N90889701
If you would like tracking and insurance please choose FedEx ground (or express if you need it faster). Please contact us for international shipping quotes. Crankshaft seals are an optional extra on this kit as most customers have not needed them. Let us know if you will need one.
A howto for changing the balance shaft can be found here. Note page 22 with regards to intermediate gear to avoid a costly mistake!</B>
Note: As of 2 February 2012 these are on a worldwide backorder. None in North America or Europe. Expected restock is mid March. In the meantime we do have a vendor that has a couple in stock, though the price is much higher. IF you absolutely must have one now we still can get 2 as of 7 Feb. Please call us for availability. Otherwise all orders will be processed in the order they are received. Thanks for your understanding.
Their number:
-tom
current autos: 98 MB E300D-T, 09 Camry Hybrid
Find your VW part numbers here.
Why I can't recommend a tdi > MY 06 st this time
Why I recommend fuel additive. Why I can't recommend use of Opti-Lube
tditom is offline   Reply With Quote
Old February 16th, 2012, 20:38   #3
CoasterMoose
Boraparts is out of stock, I'm told. Any other suggestions??? Thanks!
Moose
Old February 16th, 2012, 20:43   #4
tditom
see note in red above- as of a couple of weeks ago they had access to a couple of kits. Did you call them?
good luck!
Old February 16th, 2012, 20:49   #5
tditom
idparts:
Balance Shaft Repair Kit (B5.5)(BHW)
[balanceshaftkitbhw]$1,479.00
Click to enlarge
This balance shaft module repair kit replaces the failure-prone oil pump chain and tensioner on US Market B5.5 Passat TDIs. It includes the following: 03G-103-295Q Housing with gears, shafts, and oil pump
03G-105-212D Crankshaft gear
03G-103-305C Balance shaft drive gear
N-911-213-01 Balance shaft drive gear bolts (qty. 4)
N-106-014-02 Balance shaft bolts (qty. 5)
N-910-512-01 Balance shaft bolt
N-911-234-01 Balance shaft front bolt
N-909-775-02 Balance shaft bolt (near oil pump)
038-103-085E: Crankshaft seal
045-105-229: Crankshaft Pulley Bolt
N-908-897-01: Bearing cap bolts (qty. 2) These are all genuine parts direct from Volkswagen. Many owners are replacing these parts when completing the 100K timing belt service.
This is a special order kit and will ship in 3-5 days from ordering.
Old February 16th, 2012, 20:52   #6
tditom
impex:
IMPEX SKU # 935619
GENUINE PART
BHW MODULE REPAIR KIT PASSAT BHW
Included In Kit
03G 103 295 Q differential case with gears, shafts and oil pump
03G 105 212 C replacement gear for crankshaft
03G 103 305 C balance shaft drive gear
4- N 911 213 01 bolts to attach balance shaft drive gear
5- N 106 014 02 Balance shaft bolts
N 910 512 01 balance shaft bolt
N 911 234 01 bolt for balance shaft front near drive gear
N 909 775 02 bolt for balance shaft front near oil pump
038 103 085 E crankshaft seal
045 105 229 crankshaft pulley bolt
2 -N 908 897 01 bearing cap bolts
( OEM part number: 03G-103-295-Q-KIT / 03G103295QKIT )
List Price: $1864.95 :: Impex Price: $1340.00
Availability: In Stock
Old February 16th, 2012, 21:04   #7
CoasterMoose
Thanks Tom, good leads! Much appreciated.
Scott
Moose
Old February 16th, 2012, 21:32   #8
Whitbread
Whitbread's Avatar
Fuel Economy: mid 40's with mixed spirited driving
Call Zeb or Troy over at 1st VW Parts. I just red ordered 2 for jobs here at the shop. Took 5 days to get from Germany, should have them here on monday or tuesday.
02 Jetta TDI. Part 2
Whitbread Performance Innovations
-Full TDI performance and custom fabrication services. 248-755-8118. Dealer for SBC, TD Tuning, Wavetrac, Peloquin, Venair, and Vibrant.
Whitbread is offline   Reply With Quote
Old February 16th, 2012, 21:47   #9
CoasterMoose
Thanks Whitbread!
Moose
Old February 16th, 2012, 23:01   #10
BleachedBora
BleachedBora's Avatar
Fuel Economy: 58/52/44
Hope you get them Whitbread - got a call today that Germany isn't sending any as they are out too. Literally had 5 calls today on BS kits. My dealer is #1 to receive the restock, 10 kits coming in, 7 are presold as of today. Might get one beforehand as a D2D, but it's spoken for.
Before we ran out we had inquiries from Germany, England, Ireland, etc...this is a very big backorder.
For the really desperate there are still 2 shortblocks in North America. You can guess how I know that, yesterday there were three...
Good luck,
-BB
BleachedBora is offline   Reply With Quote
Old February 17th, 2012, 04:06   #11
1854sailor
1854sailor's Avatar
Fuel Economy: Golf 50/36/31, Passat 42/37/30
Check Impex. www.worldimpex.com
or IDparts www.idparts.com
or Advanced Automotion www.advancedautomotion.com
Those people who think they know everything are a great annoyance to those of us who do. ~ Isaac Asimov
1854sailor is online now   Reply With Quote
Old February 17th, 2012, 05:08   #12
oilhammer
oilhammer's Avatar
LOL... and VOA says there is no problem with these.... LMAO... what a flippin' joke.
I only have one here on the shelf, and it is already spoken for. I may have to alert our scheduling to this shortage. This has happened before, but there was only about a month or so shortage.
oilhammer
www.cardocautomotive.com
Help out the TDI club raffle car! :http://forums.tdiclub.com/showthread.php?t=362827
Old February 17th, 2012, 05:22   #13
VWSHPFRMN
VWSHPFRMN's Avatar
TDI(s): 2005 PASSAT
Default Balance shaft
We have one kit in stock. $1300 shipping included.
VWSHPFRMN is offline   Reply With Quote
Old February 17th, 2012, 06:30   #14
CoasterMoose
Thanks Pete, I'll call you.
Moose
Old February 17th, 2012, 08:17   #15
leicaman
leicaman's Avatar
Fuel Economy: Much better than the average car... :o)
Boy how can VW be is so denial that the rainfall of need is now apparent with these units piling on the miles. All I can say is wow and I am sure glad I had mine done at 57k.
2005 Passat GLS TDI, 141k miles, Now a daily driver Chainless and Gear Driven via the procedure by Oilhammer 06/17/2009, ngk hybrid glowplugs, Chainless and proud of it! Mileage?....adequate
leicaman is offline   Reply With Quote
timing kit and balance shaft module???? cajunspice VW B5 Passat TDIs 20 May 27th, 2011 10:24
balance shaft module cajunspice VW B5 Passat TDIs 14 May 10th, 2011 11:46
BHW Balance Shaft Module daedalus Private TDI Items for Sale/Wanted 0 April 23rd, 2010 16:46
bhw balance shaft module dieselboy33 TDI 101 1 February 4th, 2010 08:31
Balance shaft module repair in Texas?? dmk VW B5 Passat TDIs 1 September 17th, 2009 13:55
Page generated in 0.16701 seconds with 10 queries
[Output: 134.90 Kb. compressed to 113.17 Kb. by saving 21.73 Kb. (16.11%)]
