Old February 15th, 2012, 15:15   #1
S_Sanders
Fuel Economy: 41 AVG
Default P0470 - Exhaust Pressure Sensor
Does anyone have information on the P0470 - Exhaust Pressure Sensor code? This is what my VAG COM told me...
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 906 019 CL HW: 03L 906 022 TS
Component: R4 2,0L EDC G000SG 7966
Revision: 12H02--- Serial number:
Coding: 0050072
Shop #: WSC 07134 444 04953
VCID: 77D3309806D65B6
1 Fault Found:
001136 - Exhaust Pressure Sensor 1 (G450)
P0470 - 000 - Malfunction - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 2
Fault Frequency: 16
Mileage: 74069 km
Time Indication: 0
Freeze Frame:
RPM: 828 /min
Speed: 4.0 km/h
Temperature: 8.1C
Temperature: 92.7C
Temperature: 90.0C
Pressure: 326 mbar
Pressure: 8 mbar
2010 Golf TDI Coupe, 6 Spd Manual, Sunroof, Gray
2012 JSW, DSG, Black
S_Sanders is offline   Reply With Quote
Old February 19th, 2012, 16:52   #2
S_Sanders
Update...
No one, including the dealer parts department has a parts listing for a backpressure sensor.
I decided that if there's too much backpressure, then perhaps I've been driving too gently. So, I have been revving it higher and having more fun with the car for the last few days. The CEL went out!
Old February 19th, 2012, 17:46   #3
Elfnmagik
Elfnmagik's Avatar
And there you have it.
HPFP, DSG, DPF, DMF...I hate acronyms!
Elfnmagik is offline   Reply With Quote
Old February 21st, 2012, 19:45   #4
S_Sanders
Update 2:
CEL came on again. Talked to non-dealer VW certified mechanic, and was recommended to take it to the dealer suspecting DPF / Cat 1 issues.
It turns out that there is a backpressure sensor that's mounted on the valve cover. It has two tubes that connect to the exhaust system, and apparently mine is broken. OH, I almost forgot, it's not covered by the emissions warranty. Hopefully the $160.00 repair bill will fix the problem.
Old February 22nd, 2012, 04:09   #5
sgoldste01
Don't you just love how something that causes a DPF error (with the DPF being there for emissions purposes) isn't covered by the emissions warranty? ***?
I know it's only $160, but I'd raise a bit of hell just on principle.
SOLD: 2010 Golf 4-door TDI with 30k on odometer.
BOUGHT: 2012 Subaru Impreza Sport Premium 5-door with manual tranny.
sgoldste01 is offline   Reply With Quote
Old February 22nd, 2012, 12:53   #6
740GLE
The DPF and "Cats" and ECU and few other things are covered out to 80,000 as part of the Federal Emissions Warranty.
Everything else needs to be "properly maintained", even though you could clog your DPF because of a bad sensor. I've been emailing the EPA warranty department over the past few days, the warranty isn't really worth a whole lot anymore.
Old February 23rd, 2012, 21:16   #7
S_Sanders
The lawyers have earned their paychecks! That's all that matters any more.
It's not worth fighting about. I've already tried to fight with them once, and all it did was make me mad. So, it's not worth it.
Today's update is that after waiting two days, the wrong part arrived. The dealer ordered the wrong part. So, I picked up the car and will take it back when they get the correct part.
Last edited by S_Sanders; February 23rd, 2012 at 21:19. Reason: I forgot something.
Old February 27th, 2012, 18:15   #8
S_Sanders
In case anyone else has this problem, the sensor's part number is 076-906-051-B, and it costs $87.45. Total repair bill was $156.04.
It's a small black box with one electrical connector and two rubber hose connections of different sizes. It's mounted on a metal bracket to the left of the oil fill cap.
The old one, that they gave back to me, says "VWAG DPS 1003G 906 051G".
Hopefully this will be useful to someone.
Old March 15th, 2012, 17:02   #9
UberVW_TDI
UberVW_TDI's Avatar
Just scanned my car due to a "Check Engine Light"
P0471 EXHAUST PRESSURE SENSOR (RANGE/PERFORMANCE)
P0470 EXHAUST PRESSURE SENSOR ERROR
Thanks S_Sanders.
I'll take a look at the sensor your referencing.
CP3 HPFP, Valeo SMF Clutch Kit, Dieselgeek Sigma6 Sport Shifter, H&R Premium Performance Coilovers, H&R 24mm Rear Stabilizer Bar, H&R 26mm Front Stabilizer Bar, 17" VW Goal Wheels, Michelin Pilot Sport A/S 3 (245/45R17)
UberVW_TDI is offline   Reply With Quote
Old April 28th, 2012, 07:35   #10
UberVW_TDI
UberVW_TDI's Avatar
Need More Information: Can anyone help?
Check Engine Light.
Read Code with cheap OBDII reader....."P0470 EXHAUST PRESSURE SENSOR ERROR"
VAG COM reader scan results......
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency:54
So, I ordered and replaced differential pressure "sensor 1 G450"
Sensor 1 G450 P/N = 076 906 051B ($80)
Page 26-10 in the Bentley Manual.
The Check Engine Light stayed on. =(
There is another differential pressure sensor (sensor 2) next to sensor 1.
The sensors "look" the same, but have different part numbers.
Sensor 2 G451 P/N = 03G 906 051G
I decided to swap the original sensor 1 I removed and install it in the sensor 2 position.
Basically assuming the sensors are the same and that sensor 2 was bad not sensor 1...even though my VAG COM scan is sayings its sensor 1 that is bad.
Anyway, after swapping sensor 2 out and installing the original sensor 1 in its place the check engine light went out and has stayed off.
The car runs normal. Nothing abnormal. No check engine lights.
I forced a regen and the car has also done a normal regen with no issues.
So, my question is:
What is the difference between those two sensors? Should I assume they are the same and just run the car with two "sensor 1" differencial pressure sensors?
I'd like to know why those two sensors have different part numbers? I would rather not have to go buy a new "sensor 2" sensor since my original "sensor 1" is working fine in its place....just don't want to assume too much and cause an issue down the road?
Anyone know what the differences are, if any, between:
Thanks.
Old April 28th, 2012, 11:11   #11
specsalot
specsalot's Avatar
So, my question is:
Thanks.
G450 = Exhaust Gas Pressure Sensor
G451 = Low Pressure EGR Differential Pressure Sensor
[Note the SSG I have doesn't reference this sensor G451 by number - only name. You'll have to trace back the lines to be sure G451 does measure across LP EGR Valve.]
G450 measures the differential pressure across the DPF. This information used to develop one of two soot load models used to trigger DPF regenerations. G451 is used to help position the Low Pressure EGR Valve. It is not likely that these sensors are interchangeable. They are both differential pressure sensors (ie the compare differences in pressure between two points). This implies they have been engineered for their specific locations (i.e. correct DP range, zero setpoint, electrical properties).
I'm sure you intuitively feel that this may not be the best thing to be doing. Hence your question. Just because the physical sensors look the same, given the different P/N's there is no reason to believe they can be interchanged. Germans are if nothing else efficient. If the same sensor worked in both locations they would have the same P/N.
Using a DP sensor of the wrong range, calibration, or electrical properties will at best just be feeding your engine controller bad information. At worst this situation could cause:
1. Electrical problems for the ECU controller.
2. In correct operation of your vehicle emission system.
B/R specs Current Rides:
'07 Grand Cherokee 3.0 CRD
'13 Jetta Hybrid SEL Premium
'88 Porsche 944 Turbo
specsalot is offline   Reply With Quote
Old April 29th, 2012, 07:10   #12
UberVW_TDI
UberVW_TDI's Avatar
I agree. Even though my car is running fine (at least seems to be).
The two part numbers are telling me they are different sensors and are not interchangeable.
Looks like 03G 906 051G (sensor 2, G0451) is about $80. I'll order a new one and swap it out to be safe.
Thanks for your reply...
Old April 29th, 2012, 10:41   #13
specsalot
specsalot's Avatar
You're welcome. Part of my day job involves maintenance to automation systems. Most industrial sensors are intelligent devices. They can be programmed for minor shifts in engineering range (span), zero, and even minor corrections to linearity. Most of the auto stuff is dumb. It is way cheaper and mostly non-adjustable. Only option is replacement.
Diagnosing issues can be a challenge. Let's say a sensor drifts a bit. Now it may be sending bad info, but not bad enough to throw a code. This is why GFF (guided fault finding) is an imperfect process. Technology is here to stay. Maybe one day auto sensors will become intelligent. Then you would be down to just 1 part number, but the sensor would have to be programmed before use.
Old April 18th, 2013, 16:34   #14
Seapup
Fuel Economy: wife says 45mpg easy
Hey TDI Buddies,
I just pulled the codes off my wifes 2010 Jetta TDI Sportwagon with 36,000 miles. I checked out some code reader from Advanced Auto and stumbled my way thru. At first it found no codes but a little later I found 2 codes set. Each was P0470 Exhaust Pressure Sensor 1 of 2 and 2 of 2. I wrote down the code and then erase the codes set and cleared the check engine light. I restarted the TDI and no more check engine light. I returned the code reader and got my drivers license back. I drove home and still no check engine light. When I got home I turned the engine off, waited a few minutes and restarted the TDI, still no check engine light. I told my wife to watch for the check engine light and that most likely we will be buying the 2 sensors mentioned above. I assume they cost $80 a piece, is that thru the VW dealership? I'll check RockAuto and see if they carry the 2 parts. This information is great, I'm brand new to this forum even tho my wife has had the car since Christmas 2009.
Seapup is offline   Reply With Quote
Old April 18th, 2013, 17:11   #15
Seapup
looked up the prices of the 2 parts 076906051b cost $65 dollars, p.n. 03G906051G bad part number but I just read in a post here that the 03G906051G has been replaced with 076906051b so....they are the same from what I read here?
Can anyone confirm this, thanks.
n75 valve (1.8 turbo vag) - pressure sensor and air intake sensor (afn 1.9 tdi) cus Private TDI Items for Sale/Wanted 0 November 29th, 2011 02:45
17563 - Manifold Pressure Sensor (G71): Short to Plus, new sensor???? greg123 OBD Scanners 5 November 10th, 2011 23:29
Exhaust Pressure Sensor B Circuit Low - CEL Code (P047C). What does this mean? ChodeysTDi VW MKV-A5 Golf/Jettas 2 September 27th, 2011 19:17
2.0 exhaust pressure sensor vw_steve TDI 101 4 July 14th, 2011 18:13
Back pressure and exhaust discussion Ookpic TDI Power Enhancements 4 May 22nd, 2009 19:15
Page generated in 0.19332 seconds with 10 queries
[Output: 134.86 Kb. compressed to 112.69 Kb. by saving 22.18 Kb. (16.44%)]
