Old February 14th, 2012, 09:32   #31
mlemorie
TDI(s): 2004 Jetta
Fuel Economy: Avg: 43-44
Originally Posted by vwmikel View Post
What software issues? As far as I know, it is just the 170hp versions of this engine which had a Siemens ECU that are more of a problem. This is just EDC16 (though a different variant from those in the US).
This is good to know! I was under the impression for some reason that all of the 16v engines were under siemens management. Madness is definately getting a 16v powerplant now. Just for my own curiousity now, what, if any, differences are there between the 140 BKD and the 170 (unknown code)? Gears are turning...
I have VCDS and plenty of tools.
mlemorie is offline   Reply With Quote
Old February 14th, 2012, 14:26   #32
vwmikel
vwmikel's Avatar
From memory, I do think it has different injectors and a DPF on the 170. The 140 doesn't have the DPF (or at least not most of them). Being that we kept Ryans car together with 300hp I don't think I'd worry too much about the strength of the engine for most builds. The internals may be different, but I doubt it's worth the trouble and if you're really going for some land speed records I would build the bottom end with some aftermarket rods anyway.
vwmikel is offline   Reply With Quote
Old February 14th, 2012, 16:03   #33
mlemorie
TDI(s): 2004 Jetta
Injectors were the main thing I was curious about. It should be fun either way in a sub 2000lb rwd hatch back lol. Must start saving.
Old February 14th, 2012, 19:52   #34
dieselpower04
dieselpower04's Avatar
Fuel Economy: 48-54 mpg
Can the Mk5 be converted to AWD easier than a MK4? Ryan you should look into that...
My TDI Build Thread
dieselpower04 is offline   Reply With Quote
Old February 14th, 2012, 20:03   #35
Whitbread
Whitbread's Avatar
Fuel Economy: mid 40's with mixed spirited driving
With all the parts at his disposal over there its a bolt in affair
02 Jetta TDI. Part 2
Whitbread Performance Innovations
-Full TDI performance and custom fabrication services. 248-755-8118. Dealer for SBC, TD Tuning, Wavetrac, Peloquin, Venair, and Vibrant.
Whitbread is offline   Reply With Quote
Old February 14th, 2012, 20:15   #36
dieselpower04
Right!! No rear pan to swap! Just bolt in the parts! Jelly
My TDI Build Thread
Old February 15th, 2012, 00:48   #37
majesty78
majesty78's Avatar
Fuel Economy: 30mpg
Ryan, do you know if your turbo kits will fit in a Ibiza 6J 2.0L FR TDI?
Mercedes Benz W210 E-Class 320CDI, lowered 2.5", 18" AMG wheels, Decat, GT2566XTV, AMG injectors, 400kpa MAP, MAF delete, EGR delete, tumble flaps delete....SW tweaked to 300+hp/800Nm
www.facebook.com/ZturboZwettl
majesty78 is offline   Reply With Quote
Old February 15th, 2012, 01:34   #38
unclesfunnyonions
unclesfunnyonions's Avatar
TDI(s): Golf GT 170
The 170 engines have a cast alloy inlet manifold, 140 have a plastic.
Not sure if there's any internal difference tho, never removed mine....
Alex.
Car :- 2006, Mk5 Golf GT170, BMN.
Spec :- SBC Stage 2 Endurance
unclesfunnyonions is offline   Reply With Quote
Old February 15th, 2012, 03:35   #39
loudspl
loudspl's Avatar
TDI(s): 02 ASV
Are you also doing bigger valves on the ported BKD head?
Have you tried Firad 1043 +100%?
Congrats on the numbers. 16v FTW
02 Jetta, SBC IV+, ASV110, IE rods, TT springs, monster cam, Whitbread fabrications, B5 oil cooler, DG bypass, B&M ss, FueLab Prodigy pump, Giles 12mm, HFLOX nozzles, remote progressive NX N20, 2260vk, 4Bar, Bilstein coilovers, BFI mounts, Frostheater, Evo skid
70 Charger R/T 500 - restoration project
loudspl is offline   Reply With Quote
Old February 15th, 2012, 09:41   #40
ryanp
ryanp's Avatar
PD170 is Siemens Injection and Management. The Rods are stronger on the BMN PD170 compared to the BKD (The BKD has the same rods as the 105PS 1.9, the BMN has the same as the PD130/PD150) but these would be swapped with Rostens if we bent one. We keep trying but it won't die.
That would be good fun. Get saving and drop me an email
This is the CR engine right?? We are working on a CR Kit, but it is a minefield! I have your email, will reply soon
Alex.
Early BKDs had the Alloy Manifold, 06- had plastic. The PD170 have a plastic one with flaps controlled by a vacuum actuator. There are other differences I mentioned before
There is not much space on the 16v head to put bigger valves, the head guys I have worked with both think it is a lot of work and expense for little gain. A good porting job would suffice. Remember these figures are BEFORE the ported head, which is why we rekon most people will take it to this level and stick to that.
Do you have the Firad number for these Nozzles? They sound like the 8v to me, 16v nozzles are different and the largest we could find we Bosio R1287+. We have some custom ones on the way. Can't wait for them to arrive.
Thanks for the kind words everyone, I hope to have some good progress over the next month or 2.
Ry
RudolfDiesel - I will get you the logs you want to see when I get the car back, hopefully you are impressed Remind me in a few weeks, I am liable to forget
02M 6 Speed Conversions + Euro Parts - 6 Speed Setups for A4 + A5 platform,PD150 Intakes, TIP kits, Turbo's, Injectors as well as anything else!! PM Me! - Click HERE
ryanp is offline   Reply With Quote
Old February 15th, 2012, 10:49   #41
mlemorie
TDI(s): 2004 Jetta
Just for my own curiousity. In the CR engine SSP, VW talked about recessing the valves into the head and going with flat top pistons as opposed to the projected valves and recessed pistons of the BKD for better "swirl preservation". What kind of power benefit would that be. I know better swirl=better mixture=better/cleaner bang, but from a modification standpoint, would recessing the valves and switching pistons offer up much for gains? Not only for this engine, I have been wondering about that for the 8v engines as well. Not that I mean throw CJAA pistons into a BEW, but having a flat top piston without valve pockets. It would seem that the BEW head would be a bit more accepting of this as it already has recessed valves. Or am I just getting into something worth way less than the effort? lol. Sorry for the off topic.
Old February 15th, 2012, 14:05   #42
devonutopia
devonutopia's Avatar
Damn, there is no prize for second fastest diesel at GTI Spring Festival!
Jason - Skoda Fabia TDI project
http://www.youtube.com/watch?v=ELWqeeXvAAs 275bhp dyno run video of my car.
http://www.youtube.com/watch?v=8R5c496IG1Q Skoda Fabia GTB2260vk in-car acceleration video!
http://www.devoncardetailing.gb.net/
devonutopia is offline   Reply With Quote
Old February 15th, 2012, 15:16   #43
Tom.
Who says you'll be second Jason
Tom. is offline   Reply With Quote
Old February 16th, 2012, 00:08   #44
Alcaid
Alcaid's Avatar
Impressed that the rods aren't banana shaped or broken by now! Keep up the beating Ryan and let us know if/when they give in
'03 VW Golf PD130 4Motion Highline - GTB2056VL, 4 bar map, FMIC
'10 VW Passat 1.6TDI Highline - 2.5" DP (DPF/Cat delete), DP built and software by VVT - 145bhp/229ft-lbs
'83 VW Jetta 1.6TTD - GTC1444VZ + HE221W sequential compound, 11mm Dieselmeken pump, Rosten rods, girdle, Ported AAZ head with custom valves, valve springs, Ti retainers, camshaft +++ WIP
Alcaid is offline   Reply With Quote
Old February 16th, 2012, 01:46   #45
unclesfunnyonions
TDI(s): Golf GT 170
Riiiiight, so should i have a plastic instead of alloy or is it just model/year (mines a 56 reg) dependent? What year did it change to alloy on BMN? Confused me a bit with that one.
Just worried 'cos when it was in for the clutch you told me it might have done more miles than it says on the clock, can't trust anyone these days.....(not you Ry)
Anyway, is there any gains to be had in smoothing, port matching etc?
Alex.
Climbing Stradigy boutmuet TDI Fuel Economy 16 October 11th, 2009 19:58
Hill Climbing Efficiency BoboBear TDI Fuel Economy 122 May 8th, 2007 14:04
boost keeps climbing GuyGuy TDI Power Enhancements 15 April 3rd, 2007 14:16
boost keeps climbing GuyGuy Ontario 5 March 28th, 2007 04:39
Mountain Climbing Tdi Style RAMP TDI Fuel Economy 17 June 28th, 2006 22:24
Page generated in 0.14644 seconds with 10 queries
[Output: 144.77 Kb. compressed to 122.36 Kb. by saving 22.41 Kb. (15.48%)]
