Old February 9th, 2012, 08:15   #1
TDI817
TDI817's Avatar
Fuel Economy: ALH=750-1000km/55L BRM=550-700km/55L
Default 2006 Jetta TDI Turbo Problems. Possible Boost leak?
Hey guys,
I just recently starting having this problem where it sounds like boost pressure may be leaking. I have a 2006 Jetta TDI with 121,000 km. Its had a stage 1 Mikro tune since 109,000. At 1800 rpm when I step on the accelerator the turbo spools up very quickly and almost sounds like a blow off valve. Like boost pressure is leaking out. and it stops at 2,000 rpm and then the car takes off as normal. Under normal driving it will not make this sound, Only when I request full power. Iím also getting horrible fuel economy. 500-600km per tank. It was bad before but its just becoming really bad. I know the winter diesel sucks but this is becoming a big concern. There is no extra smoke at full throttle and there isnít any less. There seems to be a slight loss of power going on for the past few months, Very gradual loss of power. In the rain the tires could break lose in any gear at full throttle. Now I can barley get any wheel spin in 2nd gear. Any help is appreciated, Thanks
TDI817 is offline   Reply With Quote
Old February 9th, 2012, 21:46   #2
slamhouse
slamhouse's Avatar
Fuel Economy: Better than 95% of cars on the road
Turbo vanes get stuck closed?
slamhouse is offline   Reply With Quote
Old February 10th, 2012, 07:21   #3
JETaah
Fuel Economy: 53 max, 42 min, average 46
It is possible that you have more than one issue.
The turbo vanes are closed too much at full boost position creating back pressure in the exhaust manifold.
Here is a couple of youtube fliks by Jeff Robertson of Rocketchip to describe the condition
http://forums.tdiclub.com/showpost.p...6&postcount=62
http://forums.tdiclub.com/showpost.p...2&postcount=63
There is also the possibility that the EGR cooler is developing a leak at the flap valve bearing on the back of the engine. Thus the hissing. You can check for soot tracks where the lever pivots.
And lastly, there may be camshaft/lifter wear going on under the valve cover. This one is almost a given to some degree.
BRM cam failure - http://forums.tdiclub.com/showthread.php?t=225918
1999.5 a4 Jetta, port matched, RC2, sprint 520's, 1.5" lift kit
1996 Passat B4V, coat hanger supported exhaust system,
Visit me www.martinbergelllc.com
JETaah is offline   Reply With Quote
Old March 15th, 2012, 09:51   #4
TDI817
TDI817's Avatar
Default Problem found
I took my car into sun west VW in Courtney BC and they discovered the problem is a vacuum line has come disconnected as well as my EGR valve is not functioning properly. They said something about a control arm? Im not sure what that means. I know the EGR is exhaust gas recirculation and have a very basic understanding of how it works. They have said it will be about $840 to fix it. That seems extremely expensive. I'd found a EGR valve online for $250. Does anyone have an suggestions?
-Bret
Old March 16th, 2012, 07:19   #5
MakDad
TDI(s): 2012 Jetta.
-Bret
You can change the EGR and the ASV (anti shudder valve) yourself in under 2 hrs total. Save your $$$. EGR $200USD, ASV $130USD... I did it about a month ago. Nothing to it. You didn't say if re-connecting the vacuum hose fixed the boost leak problem or not..................
MakDad is offline   Reply With Quote
Old April 29th, 2017, 12:48   #6
06jettatdi89
Default 2006 Jetta tdi
Ok well here's how it started. I drove the car this morning and all was normal i parked it for about 3hrs and forgot the lights on so battery was dead. I jump started it + on + - on - started up and idled like **** so I noticed the exhaust came apart right in the middle of the car underneath so I put it back together thinking it was idling rough due to no back pressure. I started it back up and gave it some fuel and still didn't run right so I ran it down the road about 2 miles and came back. I was thinking fuel filter but then I drove it home and it drove better and smoother but I never felt the turbo spool up.
Need to get back on the road any advice is helpful
06jettatdi89 is offline   Reply With Quote
Old April 29th, 2017, 18:28   #7
eddieleephd
Fuel Economy: 45-51.9
You're going to have to do the rundown and see what's not working. Start with the easy stuff (vac lines, n75 swap) and see where it takes you.
I recommend you start your own thread though.
2003 Jetta Wagon Alh w/5spd swap, 11mm IP, VNT17, Malone stage4 tune, BMW Cyclonic CCV filter, 2" lift
eddieleephd is offline   Reply With Quote
2006 Jetta turbo leak at vane actuator shaft? cactus13 VW MKV-A5 Golf/Jettas 0 September 13th, 2011 01:43
new 2006 Jetta TDI with Exhaust leak DCR VW MKV-A5 Golf/Jettas 23 October 22nd, 2010 22:47
2006 Jetta Tdi - loosing coolant - can't find leak ferrarispider95 TDI 101 22 May 19th, 2009 07:28
First problem with my 2006 Jetta..boost leak? invader TDI 101 7 May 2nd, 2008 06:59
Audi a4 tdi turbo boost problems, agian! simyboye TDI 101 4 February 8th, 2008 11:06
Page generated in 0.15964 seconds with 10 queries
[Output: 81.55 Kb. compressed to 71.16 Kb. by saving 10.39 Kb. (12.74%)]
