Old February 7th, 2012, 12:08   #1
chevere
chevere's Avatar
Fuel Economy: 38 city/HWY; 58/HWY
Default How to Remove B4 Rear Suspension
I looked in Mitchell and the time called for 1.5 hours, but a local technician told me to expect around 3 because all of the interior components that need to be removed. I hear that I need to start ripping panels off JUST to get the shocks off. I looked back there last night and it looks like a nightmare. How do I get that cover off behind the rear seats with the seatbelt cover? Thanks much.
chevere is offline   Reply With Quote
Old February 7th, 2012, 18:09   #2
nh nam vet
Two prolific contributors, kooyajerms and Lug Nut, provided superior photos and details on this specific topic which I used when I R&R'd my rear struts and brakes two years ago this February.
Kooyajerms link is:http://forums.tdiclub.com/showthread.php?t=227143 or Google:Having your local mechanic install your suspension? B4V.
Lug Nut's link is:http://forums.tdiclub.com/showthread.php?t=163110 or Google: How to: B4V rear shock access
I save the printed write-ups on all of my previous projects on my 1997 Passat so I could find this information quickly. I have found over the years (since 2003) that the "Search" or "Advanced Search" for the TDIClub hasn't been particularly easy to master for instant information access which is why I rely on a fast computer and Google.
I've said it before, and I'll say it again, I'm sure: thank you all for your input. You have saved me thousands of dollars but greatly enriched my life.
TDI household total miles is currently at 905K: My 1997 B4 @340k, my back-up plan 1997 B4 @234k, and her 2002 A4 @331k gaining fast.
nh nam vet is offline   Reply With Quote
Old February 7th, 2012, 20:29   #3
turbodieseldyke
turbodieseldyke's Avatar
TDI(s): 98 jetta
Fuel Economy: 50
1.5 hrs seems generous. i think that's how long it took me at the junk yard (first time), and i had to fight one of the back seats that was locked in place. You don't even have to remove the tires.
turbodieseldyke is offline   Reply With Quote
Old February 8th, 2012, 04:51   #4
Abacus
That helpful B4 guy
Abacus's Avatar
Is this for a sedan or wagon? The sedan's are easy, just remove the top of the seatbelt housing from the seat by inserting a screwdriver horizontally. It'll engage a catch and release diagonally. The Bentley shows this pretty good. The bolts are underneath, but only 2 of them need to come off (the others are nuts). Then you twist the top of the strut 1/4 turn and it'll release the plastic keeper from the car (keep it straight so you don't snap the tabs). Once you get the seatbelt housing off, you'll see how everything is assembled. Underneath the car it's just a 19mm bolt that can be accessed without removing the brake or e-brake assembly.
I've had mine off a few times to adjust the Koni Reds and install new springs. No experience with a B4V (wagon), sorry.
'97 B4: 453,000 miles Malone 3, K03/04 Hybrid Turbo, PP520's, Stage 2 cam, SBC3, ARP studs, Westach EGT/Boost, Koni Reds/Yellows, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR, Evo plate,
BUG*PWR 2013 Award Winner
Abacus is online now   Reply With Quote
Old February 8th, 2012, 09:45   #5
kooyajerms
grocery getter
kooyajerms's Avatar
I still use that thread to figure out how to access the rears =) I'm glad it was helpful. It's too bad the title would be hard for anyone to search for.
Here is a how to also if you need more angles of it all.
http://www.myturbodiesel.com/1000q/a...tta-passat.htm
This is what Abacus is talking about (hopefully it's very similar on the sedan)
kooyajerms is offline   Reply With Quote
Old February 8th, 2012, 10:07   #6
Abacus
That helpful B4 guy
Abacus's Avatar
On the sedan, the belt guide comes off differently according to the Bentley. You insert a screwdriver underneath it and twist, which releases the catch. Here is a snapshot:
Old February 8th, 2012, 22:55   #7
vixentd
JUst make sure when you do the rears that the car is not jacked up or supported on the rear beam. If you do it will be very hard to remove the shocks as the rear beam which supports the bottom of the shock will not move easily.
www.vixenrv.org BMW diesel 30 mpg motorhome
1997 Passat tdi B4
1996 Passat tdi B4V
1984 Landcruiser diesel
1937 Chevy 350 TPI
vixentd is offline   Reply With Quote
Old July 19th, 2012, 10:45   #8
JerryPT
Fuel Economy: 39/43/47
Removing that black seat belt lead on top was the most difficult part for me. The retainer is along the front edge of the plastic, about midway, and down an inch or two. You'll know you find it when you push forward and the front edge releases, allowing you to pull up. Picture coming.
1996 B4V, Navy blue, 260K SOLD
JerryPT is offline   Reply With Quote
How do I remove rear bumper cover on a b4 passat? Pedrokep VW MKIII-A3/B4 TDIs 3 November 10th, 2013 02:24
1997 B4 Rear Suspension - Alignment Technician! VW MKIII-A3/B4 TDIs 1 May 24th, 2011 12:02
Non-rubber rear B4 suspension bushings? Abacus VW MKIII-A3/B4 TDIs 6 August 24th, 2010 09:32
How to remove rear bumper cover B4 sedan bmwM5power VW MKIII-A3/B4 TDIs 3 October 13th, 2008 10:08
B4 Wagon: How much trim to remove for rear shocks? GregK VW MKIII-A3/B4 TDIs 3 January 6th, 2006 12:48
Page generated in 0.18018 seconds with 10 queries
[Output: 89.19 Kb. compressed to 77.17 Kb. by saving 12.02 Kb. (13.48%)]
