Old February 5th, 2012, 12:35   #1
powers0430
TDI(s): 2010 2.0T
Default 2010 jetta running sluggish any help??
Okay i have a 2010 jetta 2.0t with about 15k miles on her. Love the car, my problem i am having is it seems a good bit more sluggish then my friends 09. what i mean is that when you punch the pedal on his it goes no real lag mine delays for a few seconds then pulls till about 3000 then stops also mine doesnt start to spool until about 1900 or so is this all normal? they are both 6spd manuals and stock beside a CAI.
powers0430 is offline   Reply With Quote
Old February 5th, 2012, 13:13   #2
powers0430
TDI(s): 2010 2.0T
i heard from someone that it could be a programming issue that can just be tweak to cut down on the turbo lag? i know its not a race car but it should have some more get up then it does
Old February 5th, 2012, 13:16   #3
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
Both cars came from the factory with a 'CAI'. Change your fuel filter, return the car to stock and see if there are any improvements.
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old February 5th, 2012, 13:30   #4
powers0430
TDI(s): 2010 2.0T
Bill
just changed it and ill slap the factory filter back on ... i just know when i had my diesel truck CAI , Exhaust and tuner boosted hp and doubled my mpg. i should have done more research before jumping into buying things.
Old February 5th, 2012, 14:07   #5
MyAvocation
MyAvocation's Avatar
You're a fast learner. These little motors are completely different from light truck cousins. Best to learn or ask before modding. Welcome aboard.
"Never trust Internet quotes." - John F. Kennedy
MyAvocation is offline   Reply With Quote
Old February 5th, 2012, 15:36   #6
powers0430
TDI(s): 2010 2.0T
Okay cool i will be sure to ask first thank you ... You think it could have lost some power bc of that CAI ?
Sent from my SCH-I510 using Tapatalk
Old February 5th, 2012, 15:40   #7
powers0430
TDI(s): 2010 2.0T
And do you know why a CAI is bad for the tdi ?
Old February 5th, 2012, 16:40   #8
Jnitrofish
Jnitrofish's Avatar
Fuel Economy: Bad on short trips, good on long trips.
Are we talking about a 2010 Jetta TDI, or a 2.0T?
Diesel TDI, or Gas Turbocharged Direct Injected (not TDI) engine?
[ 2005.5 :: 06/05 Jetta 5m Franko6 BEW Cam/Malone Tuned - Equipped for towing (Bosal/Airlift/Tekonsha) || 2005.5 :: 05/05 Jetta 5m Tuned (Wife's Car) || 2006 :: 02/06 Jetta DSG Malone Tuned (Dad's Car) ]
[ 4 TDI tally: 4 cam jobs, 5 timing belts, 4 alternator pulleys, 2 DMF, 1 G60/VR6, 1 Jetta ] [ Explained engine vibration
Jnitrofish is offline   Reply With Quote
Old February 6th, 2012, 03:00   #9
powers0430
TDI(s): 2010 2.0T
Its diesel ... i believe its the cjaa i just thought id throw it out bc every is always talking about the 1.9 sorry about the confusion.
Old February 6th, 2012, 08:28   #10
MayorDJQ
I doubt you would lose any performance because of an aftermarktet air filter, unless you disconnected the MAF and didn't pkug it back in, but then you'd get a CEL. Is it an oiled filter?
That said, there a few problems with the aftermarkter air filters:
1. They offer no performance upgrades.
2. If it's an oiled filter, the oil will eventually contaminate you MAF sensor.
MayorDJQ is offline   Reply With Quote
Old February 6th, 2012, 08:47   #11
740GLE
Unless other upgrades are also preformed. Many here have benifited from a true CAI, but it wasn't their first mod, and yes this is on a CJAA.
Old February 6th, 2012, 09:08   #12
MayorDJQ
Did any of them do before & after dynos of the CAI itself? The only "numbers" I've ever seen have been on the CAI sellers' websites, and they've all been suspect for one reason or another.
Old February 6th, 2012, 11:46   #13
powers0430
TDI(s): 2010 2.0T
Hmm if the MAF is contaminated would that cause the hesitation ? because i bought this CPO at a dealer and when i put the intake on it seemed as if there was one on here at one point. It looked like there was a line drawn on the MAF which lined up perfectly with the one i installed. And yes i have it all back together and no cel. I don't have another mod besides the cat back that was one here when i bought it. I will reinstall the oem unit back on tonight. Someone told me about a flap in the bottom of the stock setup that i should hold open or closed with a bolt or something ever heard of this and why ?
Old February 6th, 2012, 12:22   #14
740GLE
no dynos, but one did VCDS logs of demanded air flow and actual air flow, and there was an improvment, was it worth the cash and do they filter the same? that's for them to comment.
Another member reported the CAI cut down on soot under "hard acceleration". Like I said their CAI wasn't their first mod.
Here's a discussion on tunes/mods and CAI, looks like not a whole lot of change with/without the intake except for spool up a smoke.
http://forums.tdiclub.com/showthread...&highlight=CAI
Old February 7th, 2012, 09:29   #15
carnotgas
carnotgas's Avatar
TDI(s): 2015 Jetta
Fuel Economy: Very Good
Default Gear Ratios
The gear ratios are different on the 09 and the 10s. This might make the 10 feel more sluggish.
2015 Jetta S TDI Sedan, Black, Automated Dual Clutch Constant Mesh Gearbox
Avatar: Never Forget
carnotgas is offline   Reply With Quote
Disabling Daytime Running Lights on 2010 TDI madmarty1 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 111 May 14th, 2012 06:49
2010 TDI DSG Sluggish Accleration Kthackst VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 7 October 12th, 2011 05:54
2010 Jetta TDI - Radiator Fan running NovaScotian TDI 101 1 December 14th, 2010 14:11
2010 JSW fan running and brake smell skevimc VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 16 May 21st, 2010 23:09
2010 running rough jjohns72 VW MKV-A5 Golf/Jettas 6 January 8th, 2010 20:16
Page generated in 0.17563 seconds with 10 queries
[Output: 127.31 Kb. compressed to 106.57 Kb. by saving 20.74 Kb. (16.29%)]
