View Poll Results: How do I fix fuel gauge
Fuel filter 0 0%
Fuel sensor 0 0%
Voters: 0. You may not vote on this poll
Old February 5th, 2012, 13:07   #1
Tim Saint
TDI(s): 2009 Jetta
Angry Fuel gauge not working
2009 TDI has 37,139 miles. This is a salvage that I had rebuilt, minor rear bumper damage along with rear quarter panel an left rear wheel replacement. problem is fuel gauge read full. However, after driving about 40 miles got suspicious as to why it still read full and decided to fill up. It took 14.9 gallons. Proceeded to drive 22 miles and according to fuel gauge it consumed a quarter of the tank. Any suggestions to fix the fuel gauge? This is my first attempt for a thread as I just signed up as a new member yesterday. This 2009 is the third diesel I have owned.
Tim Saint is offline   Reply With Quote
Old February 5th, 2012, 13:54   #2
Jnitrofish
Jnitrofish's Avatar
Fuel Economy: Bad on short trips, good on long trips.
You are very lucky you filled up when you did. Normally these gauges take ~120 miles to move off of full if a tank is completely topped off. If your tank was completely topped off by the last person, you might have had another gallon of fuel. Several people have had the engine die after 15.9 gallons.
[ 2005.5 :: 06/05 Jetta 5m Franko6 BEW Cam/Malone Tuned - Equipped for towing (Bosal/Airlift/Tekonsha) || 2005.5 :: 05/05 Jetta 5m Tuned (Wife's Car) || 2006 :: 02/06 Jetta DSG Malone Tuned (Dad's Car) ]
[ 4 TDI tally: 4 cam jobs, 5 timing belts, 4 alternator pulleys, 2 DMF, 1 G60/VR6, 1 Jetta ] [ Explained engine vibration
Jnitrofish is offline   Reply With Quote
Old February 5th, 2012, 14:06   #3
tdiatlast
Welcome to the club. Lots of great info, and discussion, here.
Why have you chosen to create a poll? I don't think it's necessary. Usually, with a question like your's, the poster just states the question in the "thread title" line...such as "2009 fuel gauge erratic"...or something like that.
I'm sure someone will answer your question very quickly.
2014 Passat TDI SEL DSG (returned 12/14/16)
2009 JSW TDI DSG (returned 12/15/16)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
tdiatlast is online now   Reply With Quote
Old February 5th, 2012, 14:22   #4
dweisel
dweisel's Avatar
Fuel Economy: 09 MB R320 Bluetec and too many ALH Beetles!
You're going to have to check out the fuel sending unit,but you will need to run the fuel down a bit since you just fueled up. You don't want to try and access the fuel sending unit with a full tank of fuel as you will make a mess.This is best done with a nearly empty fuel tank. Its located under the rear seat on the passenger side of the car. Pull up the seat and you will see that the carpet is cut. Lift up the carpet to expose a black plastic cover. Remove this plastic piece. You will now see the fuel sending unit. Disconnect the electrical connector and the two fuel lines. Now using a screw driver or punch plus a hammer tap the steel locking ring to loosen it. Once its loose spin it off. The fuel sending unit is spring loaded so it will push upwards. Now lift the unit out of the hole being careful to make sure the float arm clears the edge of the hole.
One the fuel sending unit is removed from the fuel tank you can do some test to try and determine what the problem is if there are no immeditate indications as to what may be causing the problem. I'm not sure if the wiring harness is long enough,but if it is plug the harness back into the fuel sending unit and then manipulate the float arm by hand to and watch your fuel gauge to see if the gauge is working with the position of the fuel sending unit float. With the float all the way down it should read empty. Float all the way up,it should read full. 3/4 and so on. Don't expect it to be dead nuts on,but each position should be close and correspond with your gauge. If the wiring harness is not long enough just make a couple of jumper wires that will run from the connector to the terminals on the fuel gauge. You will need 3 jumper wires to jump the fuel gauge wiring which will be the 3 smaller terminals to the inside of the electrical connections. The 2 largrer connections are for the lift pump motor.
Also be aware that once you do all of this you need to refill your fuel tank at least 3/4 before you restart the car.
Hope that helps.
Below pic: fuel sending unit,black plastic cover and steel locking ring.
Below pic: fuel sending unit with jumper wires on lift pump motor terminals.
LUBRICITY,LUBRICITY,LUBRICITY!
dweisel isn't diesel anymore!
dweisel is offline   Reply With Quote
Old February 5th, 2012, 14:24   #5
whitedog
Here's an overly-complicated suggestion: Run the car for maybe 400 miles. get amultimeter and figure out which wires on the sending unit are for the gauge. Go to fuel station and put the multimeter on the connector and proceed to fill the tank while watching the multimeter. If the readings are as wacky as what you see on the dash, then you know it's the sending unit.
There is probably an easier way, but I don't know enough to help.
Or you could do as Dweisel suggested and run the float up and down while watching the multimeter.
Drinks raw water
03 TDI Jetta Fuel Gauge not working. ralekato VW MKIV-A4 TDIs (VE and PD) 14 September 11th, 2015 10:10
Temperature gauge not working! Agent Asian VW MKIV-A4 TDIs (VE and PD) 24 May 9th, 2011 10:00
temp gauge not working mike1937 Ontario 11 December 1st, 2010 05:31
B4 fuel gauge not working james43 TDI 101 4 December 21st, 2007 01:00
fuel gauge not working? twig93 VW MKIV-A4 TDIs (VE and PD) 1 May 21st, 2002 16:43
Page generated in 0.13450 seconds with 11 queries
[Output: 75.02 Kb. compressed to 66.54 Kb. by saving 8.47 Kb. (11.29%)]
