Old February 4th, 2012, 08:33   #1
pupli
Default Golf IV 1.9 TDI Engine Oil Change
Hello everybody,
Please help me regarding this issue of mine:
I am about to change engine oil, and a friend of mine suggested to me SHELL Helix 10W-40 oil type.
My car has passed 250.000 km, it's a diesel one (1.9 TDI, 6speed-gearbox)
The last time I changed engine oil, I used Castrol 10w-40
Pls advice ,
regards
pupli is offline   Reply With Quote
Old February 4th, 2012, 08:38   #2
tditom
Fuel Economy: Golf: 54/48/43.5 B4 Passat: 52/48.5/45 B5.5 Passat: 30 mpg mixed
I'd recommend a 5W40 oil for your car.
I'm not sure which engine you have:
If it is a VE pump then use at least VW505.00. If it is a PD then use VW505.01 specification.
good luck!
-tom
autos: 15 Volvo V60, 08 MB E320 Bluetec
Find your VW part numbers here.
Why I recommend fuel additive.
tditom is offline   Reply With Quote
Old February 4th, 2012, 13:02   #3
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
What does VW recommend? It should be in the owner's manual. I would stick with VW's recommendation for YOUR car. I could tell you want is recommended for my car but that may not be what is best for YOUR car.
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline   Reply With Quote
Old February 5th, 2012, 23:32   #4
03bora
03bora's Avatar
Fuel Economy: consistantly getting at least 36 mpg.
I'm sure your car has the ALH engine like my 03 jetta has. I always check the oil ratings for the vw 505.01. If it there, then I'd say your good but I'd stick with the 5/40 weight though. I have seen that shell oil brought up on discussion many times so it must be good stuff!
ASE master tech with A9 diesel certification
2003 TDi Mafia Member
Mods:Cat fuel filter w/ custom stainless steel braided fuel lines, Elbrus rims, Euro headlamp switch, fuel tank ventectomy, DieselGeek short throw shifter, Redline accessories custom shift boot, custom brake calipers from GoldLineCalipers.com.
03bora is offline   Reply With Quote
Golf mk IV ASZ cam belt change gdjohny VW MKIV-A4 TDIs (VE and PD) 2 November 9th, 2010 18:13
Golf iV TDI manual transmission oil change KeithOfOhio TDI 101 10 May 19th, 2010 15:45
Engine Life: Golf V 2.5L VS Golf IV TDI 1.9L kilimats TDI 101 9 January 27th, 2010 15:56
Golf IV/Jetta IV TDI Bentley ARBY Private TDI Items for Sale/Wanted 4 August 19th, 2008 09:38
Gearbox oil part number?? for GOLF IV TDI amgad VW MKIV-A4 TDIs (VE and PD) 5 March 21st, 2001 09:51
Page generated in 0.10060 seconds with 10 queries
[Output: 63.36 Kb. compressed to 56.66 Kb. by saving 6.69 Kb. (10.57%)]
