Old February 1st, 2012, 11:56   #1
updaze
Fuel Economy: 50-52 on 2003 5-speed; 42 on 2005 Automatic
Default 2005 jetta sedan..have to replace ECM???!!!
My dealer just told me that my whole ECM has to be replaced at a cost of $950 because my manifold valve is getting no voltage from the ECM...and cannot use a used ecm because it is tied to the VIN #...am I being bull****ted or not?...help!
updaze is offline   Reply With Quote
Old February 1st, 2012, 12:01   #2
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
A new ECU is not initially tied to your VIN either. You need to get to a GURU and have the codes pulled with a VCDS. And what "manifold valve" are they referring to?
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old February 1st, 2012, 12:24   #3
updaze
is that a fair price for the ecu/ecm?
Old February 1st, 2012, 19:52   #4
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
No way. That's completely absurd. And beside, you can buy a used ECU and it will adapt to the car and and pull the VIN number from the gauge cluster which also stores the VIN. Of course, there is the whole issue with the glow plug software though.
What intake flap? There are several on a BEW. I would head toward a broken wire somewhere rather than the ECU. Replacing the ECU is absolute last resort to a problem.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old February 1st, 2012, 19:58   #5
Seatman
Seatman's Avatar
Fuel Economy: No idea
I think it's the asv because it's electrical on the newer car.
Find a pin out for the ecu and check that first, I really wouldn't use the dealer for it either, as said there's second hand ones that work just fine if needed. You might find the pin out here
http://www.ecuconnections.com/
Seatman is offline   Reply With Quote
Old February 2nd, 2012, 04:52   #6
PDJetta
PDJetta's Avatar
I'd trace the wiring back to the ECU first and then check out the throttle valve. Why did they say the throttle valve was bad? Is the CEL on and a code stored for it?
BTW, if the throttle valve is bad, a new one is about $250 from firstvwparts.com (a VW dealer with internet sales). Your local dealer may charge near to twice that for this part. I know. I had to replace mine.
Unplugged, by default, it stays open, but you will get a CEL. The car runs fine without it. Its sole purpose is to increase EGR flow rate into the engine and quite the engine on shut-down. I think it may also offer some protection in case the turbocharger fails and dumps lubrication oil into the intake manifold, which could cause an uncontrolled engien acceleration.
The best option is to have it working, but there are other options, especially if you do not have to pass emissions testing.
--Nate
Old February 2nd, 2012, 05:11   #7
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
I've run across this issue before, it was on a BRM though. ECU's driver circuit for that output just tooefed. Have to make certain it is not a wiring problem first. Dealer tech's love to get roped into Volkswagen's lame "guided fault finding" which basically assumes the tech is a moron, and hand holds them through some pedantic basic checks that are often not grounded in reality, and ultimately leads to 'replace control unit'.
You can get a used ECU, however, once again the dealer's techs will be hand cuffed to their system which won't allow for any thinking outside the box when it comes to the immobiliser or VIN-embedding.
What I would do is try and contact Jeff at www.rocketchip.com or one of the other tuners to see if they can help you. They may have an ECU they can exchange for you, or even program that output out of your existing ECU if you prefer. Either way, it will be less money.
oilhammer
www.cardocautomotive.com
2005.5 jetta, how to replace lowbeam headlight sweatmachine TDI 101 12 July 13th, 2011 05:30
FS - 2005.5 Jetta Sedan - Immaculate kluessendorf TDI Cars for Sale/Wanted 24 July 29th, 2010 21:30
Anyone looking for 2005.5 Jetta TDI sedan? benpfree West Coast Canada/USA 0 June 12th, 2008 13:29
How do I replace Jetta 2005.5 headlight bulb? Guttboy VW MKV-A5 Golf/Jettas 8 March 9th, 2007 12:43
F/S 2005 Jetta GLS TDI sedan gleep TDI Cars for Sale/Wanted 5 February 23rd, 2006 22:28
Page generated in 0.14453 seconds with 10 queries
[Output: 83.31 Kb. compressed to 72.59 Kb. by saving 10.72 Kb. (12.87%)]
