| VW B5 Passat TDIs This is a general discussion about B5 Passat(>98 (2004-2005 in North America)). Non TDI related postings will be moved or removed. |
January 31st, 2012, 10:41
#1
2005 Passat TDi - Engine Lite On -"Emissions Workshop"
I got the engine light this morning when i turne the car on. I was unable to drive any faster then 40mph.
I had the code read and it came back as "EGR".
Has anyone had this problem before?
Help.
Thank you
February 2nd, 2012, 10:07
#2
Are you blowing smoke out the back too? Any power loss at lower speeds?
February 2nd, 2012, 11:38
#3
Hopefully your egr valve is not bad. $$$
Have you ever cleaned it?
Is the connector on tight?
05 Passat GLS 2.0 PD, UnChained & Steel GPs by VW, 17" (CC) Spas, New TB/WP, motor mounts, alt pulley, trans filter, cv boots, premature cam wear?  now driven only once or twice a week
2012 Kia Optima SX turbo, 274 hp, 269 ft-lb @ 1750-4500 rpm, corsa blue, new daily driver
February 2nd, 2012, 13:43
#4
Best suggestion is to find someone with a Vag-Com and have them pull the actual code.
2012 Passat SEL Premium TDi Opera Red
2004 Passat GLS TDi Northern Green RC Stage 2 Chainless - RIP
2005 Ford F350 CrewCab PSD Dually
February 16th, 2012, 12:17
#5
I did have power loss and it is not blowing smoke.
I have never cleaned it.
I will make sure the it is on tight.
I cleared the code and the car has been driving fine since.
I dodn't know where to go next. I would like to fix it so it doesn't happen again.
February 16th, 2012, 14:51
#6
Clean it...it's probably clogged.
Or disconnect it, assuming it is closed, and live with the warning lights.
February 18th, 2012, 19:00
#7
Fuel Economy: 41 HWY, 35 City
You need to get the diagnostic code.
I just had the same issue.
Diagnostic code said it was the temperature sender. (Located on the back of the engine next to the firewall and not easy to get to.)
Mine was either open or closed which told the car it was -40 degrees outside, (when it was about +50 degrees,) which caused the car to miss once or twice and blow some white smoke.
Replacing the sender solved the problem. Shop charged 1 hour labor, plus diagnostic fee and $28 for the part and something, (I don't remember the amount,) for the anti freeze.
Total charge was around $275.
...where we stand determines what we see...
February 19th, 2012, 05:26
#8
the temp sender is a ntc(negative temperature coefficient device) , so an open circuit is infinite resistance, making the ecu think its -50
"You can't argue with a fool..."
August 8th, 2012, 23:01
#9
Pfreire727,
Did you find out what the problem was? I have the exact same symptoms on my 05.5. Going to try to get it scanned this week. Is the free checker at Auto Zone, same as the VAG COM everyone speaks of?
Greg
'05.5 Jetta TDI w/ rocket chip 1+, Frank06 Cam Kit
August 9th, 2012, 03:55
#10
No, but it will provide a code just the same.
August 9th, 2012, 17:23
#11
I got code P0299. Boost pressure regulation control range not reach.
I think it means that the actuator isn't moving freely. Might need a turbo cleaning or reman turbo.
Greg
August 10th, 2012, 17:50
#12
Pre-Forum Veteran Member
Fuel Economy: Which VW diesel? There have been Twelve of them!
...or not. A replacement turbo, and replacement EGR valve, and replacement MAF, did nothing for what was about to become mine. The dealer sold it, and I agreed to buy it, with this occasional fault cause still unidentified. I never did find the cause, but I did discover prevention methods that I passed on to the new purchaser when I sold.
Svante Arrhenius 1896
December 27th, 2012, 14:14
#13
interesting. i've lived with it for months now. going to do the "easy off" turbo chemical clean this website speaks of.
(sorry to get back 4 months later... I don't get notified when someone replies to my posting... need to work on that too.)
Greg
January 2nd, 2013, 06:23
#14
If you're talking about this thread: http://forums.tdiclub.com/showthread.php?t=367384, do it . It should be a maintenance requirement on these cars and it's so simple to do on an inline engine platform as the turbo sticks out invitingly for you to clean,etc. Mine is still running as new after this simple procedure. Sometimes we have to fish for what the limp modes and CELs are really pointing to and IMHO, a clean turbo will prevent a bunch of them.
