Old January 31st, 2012, 03:31   #1
diesel359
Default 2002 Beetle TDI Hard Starting in Cold Weather
Hello,
I am new here............but I have down some reading and searching on your site for this issue.
This beetle happens to be my mothers and I have been driving it around to get a better handle on what the issue really is.
Day 1 (morning):
26 degrees out, turn the key glow plug light only on for about 2 seconds. I cycled it twice more and tried to start the engine. All I got was some stumbling and once I pushed the pedal down about 3/4 the way down, it lit right off.
Day 1 (evening):
45 degrees out, turn the key on and still the glow plug light is on about 2 seconds. I cycle it twice more and try to start the engine. This time no stumbling and it didn't even try to hit. I pushed the pedal most of the way down and it started stumbling and lit right off.
When I got home that night, I unpluged the engine coolant sensor and tried the glow plugs like I read on your site. This time the glow plug light was on a least 15 seconds.
Day 2 (morning):
35 degrees out, turn the key on and still the glow plug light is on about 2 seconds, started fine after I pushed the pedal most of the way down.
I should add that the engine starts fine after it has been run even a short time........which leads me toward the glow plug issue. Also, the battery and crank speed seem to be fine. I done some full throttle runs up hills to test degrading power (fuel restrictions, filter, etc.) but everything seems good.
I also read that retarded injection pump timing could be the reason for the hard starts in the cold.
At this point, I am thinking that replacing a $8.99 coolant sensor would be a cheap gamble unless you guys can point me in another direction.
Any ideas?
thanks,
diesel359 is offline   Reply With Quote
Old January 31st, 2012, 04:16   #2
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
I also drive a 2002 NB and I seldom have any problems. You should not need to have your foot on the accelerator. Do you have the heater fan, head lamps etc on? Have you checked the glow plugs?
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline   Reply With Quote
Old January 31st, 2012, 04:19   #3
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Sounds like a loss of pump prime. I'd inspect the pump itself for any signs of fuel leakage (wetness). It is not a coolant temp sensor or glow system problem most likely.
oilhammer
www.cardocautomotive.com
Old January 31st, 2012, 21:06   #4
diesel359
I had all the electronics off except the radio. The glow plugs and harness are fairly new.
When it does start......no plume of smoke or rough idling.
Checked all fuel hoses, lines, and filter..........no leaks
It seems as though its not getting fuel till it lights off.
What would keep it from fueling on start up
Old February 1st, 2012, 05:03   #5
CycleStar
This sounds like our beetle. I was starting to think that maybe my oil was too heavy. I use a FrostHeater regularly and it's still slow to start. I also have the EGR stuff removed, so I'm sure it's not clogged.
CycleStar is offline   Reply With Quote
Old February 6th, 2012, 08:27   #6
diesel359
I went ahead and replaced the coolant sensor and waiting on a cold morning to see if the glow plugs cycle.
I personally think that something is keeping it from getting fuel on startup.
Do 2002 Beetle TDI have a in tank lift pump? If see, I was thinking I could remove a line from the filter and check flow with the key on.
You have to pump or keep the pedal down in order for it to start cold and parked overnight or if you have parked it a little while. If you shut it off and make a stop then crank up...........all is well.
It really acts like it is loosing fuel prime............. but doesn't have the rough idling stumbling issues after it starts.
Any Ideas?
Old February 18th, 2012, 02:15   #7
shinkamp
Default hard start
Your hard start does possibly sound like a lack of fuel problem. As others have said, you shouldn't have to even have your foot on the accelerator if everything is working right. The fuel injection pump has a governor (which keeps your engine from overspeeding) but it also puts the engine at full fuel for starting (at low RPMs). The fuel injection pump may be misadjusted or the governor not working properly. The fact that you don't put out any partially burned fuel (smoke) until the car starts also supports the idea that you are not getting adequate fuel.
Another possibility is that you have an air ingress into your fuel lines. My 2001 Jetta has a clear fuel line going into the fuel injection pump. Maybe yours does, too. If so, you can check to see if there's some air in the line. Check this while the engine is running, especially right after starting. My Jetta had air but I moved hoses and clamps and fixed it. Air causes the most problems when the vehicle sits a good while because it congregates at a high point in the fuel system and can cause a "plug" which has to be "pushed through" or "filled" when you start the car. That can cause the injection pump to deliver inadequate fuel to the cylinders when cranking after sitting a while.
Just my two cents worth--maybe it's not worth two cents.
Steve
shinkamp is offline   Reply With Quote
Old February 18th, 2012, 16:19   #8
Curious Chris
Fuel Economy: 47/42/38
Have you checked the injection timing? Late last fall I had quite a few members stop over at my house to have their timing adjusted. With retarded timing the car will start in ok in warm weather and then poorly or not at all in cold weather.
The engine does not get any fuel until the starter spins the engine at IIRC 350rpm.
The 2002 does not have a lift pump the injection pump sucks the fuel in which is why air leaks can cause problematic starts. I added a lift pump to my car for top end performance but it also provides very nice cold starts; oh my injection timing is in the upper half of the injection timing graph as I own Hex-Com VCDS.
Wavetrac LSD, Bosch 230'a with RC4.5, Whitbread 2.5" downpipe, PD lift pump, South Bend Stage 2 Endurance Clutch, steel skid plate, Wingnut inspired EGR mod, MyCruiseAgent no drill EGT, MoGolf skidplate mod
Curious Chris is offline   Reply With Quote
2002 Beetle TDI Hard Starting in Cold Weather diesel359 VW MKIV-A4 TDIs (VE and PD) 0 January 31st, 2012 03:28
Cold Weather and Hard Starting cloudstrife TDI 101 15 November 16th, 2007 20:00
hard to start in cold weather 2000 Beetle Jdean General VW Discussion 0 May 16th, 2006 07:47
cold weather 'hard' starting kyote321 TDI 101 7 November 25th, 2003 21:04
B4 Cold Weather Hard Starting/Smoke - Coolant Temp. Sensor?? GMCpatrick VW MKIII-A3/B4 TDIs 12 February 6th, 2003 09:26
Page generated in 0.13777 seconds with 10 queries
[Output: 86.90 Kb. compressed to 75.13 Kb. by saving 11.78 Kb. (13.55%)]
