Old January 29th, 2012, 13:21   #1
f100 nut
Default 2006 jetta tdi heat control missing 1-3
My heat control switch works only on # 4. Read in here somewhere about control board change out. Where do I find this component. Nearest VW dealer is 4 hrs from me. Any help would be much appreciated. Thanks.
f100 nut is offline   Reply With Quote
Old January 29th, 2012, 19:01   #2
goatcheese
goatcheese's Avatar
I'd check resistor first. About $30 And 20 min to change. Good luck.
lucy lu & jackson
goatcheese is offline   Reply With Quote
Old January 29th, 2012, 19:08   #3
whitedog
There is a block of resistors called (oddly enough) a resistor block that controls the fan speed. Unfortunately, I don't have destructions on the R&R, but search for "resistor block" and I bet you can find something.
Can fold paper in half eight times.
Old January 30th, 2012, 09:36   #4
740GLE
isn't it by the fan? which is in the passangers foot well, by the cabin filter.
Old February 1st, 2012, 06:46   #5
Jesse1983
TDI(s): 06 Jetta TDI
see this thread
Jesse1983 is offline   Reply With Quote
2006 Jetta TDI doesn't produce heat with Fan on cdarfus VW MKV-A5 Golf/Jettas 3 November 29th, 2013 15:41
2006 jetta tdi control module - vanishes! tbrennan14 TDI 101 4 March 1st, 2011 21:28
2006 jetta tdi _ Control Arm Bolt Dilemma tbrennan14 VW MKV-A5 Golf/Jettas 5 February 10th, 2011 12:41
Missing Engine Splash Guard in 2006 Jetta 1.9 TDI lkinderv VW MKV-A5 Golf/Jettas 5 May 30th, 2010 04:42
2006 Jetta TDI Floor Heat Issues JillSHanson VW MKV-A5 Golf/Jettas 13 January 24th, 2009 07:04
Page generated in 0.13012 seconds with 10 queries
[Output: 66.58 Kb. compressed to 58.72 Kb. by saving 7.86 Kb. (11.81%)]
