Old January 29th, 2012, 07:59   #1
SPR
TDI(s): mk4
Default brake booster
I just got my 01 tdi on the road and drove for about 250 km`s and suddenly lost feel of braking, stiff pedel, and the it felt fine. I continued to drive homeward with caution and had low power with a odd fell brake pedel. Home in my garage i checked all vacuum lines, vnt was still operating with my mitty vac, vacuum on the end of the brake booster pipe was 29+. pipe connected to brake booster,mitty vac to one way valve thing and 0 vac. I then disconnected the pipe from the booster and taped it off well and my turbo worked. So at this point i would say my booster is shot? If so any tips, if read about the rod to the peddle.
I all so have the stumble or rumblely fell when i come to a stop , last for about 5-10 sec. Is this where the hammer mod discription might fix? I realize i have a few bugs to get worked out,
SPR is offline   Reply With Quote
Old January 30th, 2012, 07:35   #2
jettaround
Similar thing happened to me on Friday; funny we both have a 01. You might want to read the following post. http://forums.tdiclub.com/showthread...ster+procedure
My brake booster made a pop sound when I jammed on the brakes at 30mpg. Now there is no brake assist requiring lots of leg force to stop the car. In the weeks leading up to this event, the booster was making a hissing sound only when the pedal was depressed about 80% down so under light braking it would never really hiss as far as my ears were concerned. Now itís causing a major vacuum leak as the vacuum at idle is 28 mG with the brake booster disconnected and the vacuum pump to brake booster line closed off at the booster end. With the booster connected however the idle vacuum is around 5 mG.
Questions I have is the following:
1. Where can one purchase a genuine part besides at the stealership?
2. The original defective brake booster part no. is 1J1614105M. Is there an updated part number or new and improved part?
3. Should the master cylinder also be replaced simultaneously for the sake of having both paired up as new?
4. Has anyone ever put in a used brake booster and what was your experience with longevity or reliability?
Little info about my car:
2001 Jetta TDI, 230K miles, 8th digit in VIN is M so I donít have ESP.
Thanks for sharing.
jettaround is offline   Reply With Quote
Old January 30th, 2012, 09:17   #3
JB05
Fuel Economy: 43/41/40
Try World Impex or idparts.com, just to name a couple of our on-line vendors.
JB05 is offline   Reply With Quote
Brake Problem ABS or Brake Booster? Tyler E TDI 101 21 December 24th, 2011 09:23
Brake Issue. Brake Booster? oEo TDI 101 7 August 18th, 2007 08:52
Brake booster? nick02 VW MKIV-A4 TDIs (VE and PD) 5 August 5th, 2005 11:11
NB: Replace brake switch = brake booster failure eauboy VW MKIV-A4 TDIs (VE and PD) 23 November 9th, 2004 10:46
Faulty Brake booster = auto tranny & brake prob. firecopter VW MKIV-A4 TDIs (VE and PD) 6 October 20th, 2004 07:58
Page generated in 0.12547 seconds with 10 queries
[Output: 57.80 Kb. compressed to 52.68 Kb. by saving 5.12 Kb. (8.86%)]
