Old January 28th, 2012, 04:42   #1
Sotam123
Sotam123's Avatar
Exclamation Sterring wheel horn stuck on?
Ok do here is the deal,
bought a gti steering wheel yesterday to replace my old nasty 4spoke one. I assembled everything and when i plug the battery and turn the key on the cars horn goes of(one constant beep). soo i unplug the battery and take the airbag off.. i check for anything block the steering but that dosent seem to work i unplug the two grounds but it still beeps..
Anyone kknow what to do?? is the harness the same as thr gti harness
Please help!
Sotam123 is offline   Reply With Quote
Old January 28th, 2012, 06:35   #2
where2
where2's Avatar
The horn should not be going off if the wires that plug onto to the steering wheel are not being grounded. Not the yellow plug for the airbag, the other two wires...
'06 Jetta_TDI Pkg_1 5spd (4 wife) Got Boost... 155k
'04 Jetta_TDI_Wagon_GL 5spd (4 daily) Got Miles... 222k!
'90 Corrado_G60 Pkg_2 5spd (4 fun) Supercharged and half the fuel economy of a TDI!
where2 is offline   Reply With Quote
Old January 28th, 2012, 06:50   #3
Rxfire
Rxfire's Avatar
Until you figure it out, pull fuse 40
2 each 2003 GLS Jetta Wagons (White/tan leather and White/black leather), 5 speeds, Panzer plates, roof rack cross bars (hers), homelinks, 520 nozzles, ventectomies, trailer hitch (mine), VR6 front springs (hers); 1 inch lift kit w/ESP (mine) 1986 Isuzu Trooper Turbo Diesel, 1985 Isuzu P'up NA Diesel
Rxfire is online now   Reply With Quote
Old January 28th, 2012, 15:09   #4
Sotam123
Sotam123's Avatar
yeah i did plug the two wires to the steering wheel(the black ones)..
i highly doubt it but would it change somthing if i changed the lenght of the wires (one didnt reach the metal tab on the gti steering wheel
Has anyone done the swap from the oem 4 spoke to the gti 3 spoke wheel??
Thanks!
Old January 28th, 2012, 15:45   #5
Sotam123
Sotam123's Avatar
the problem is i dont know were to plug the second ground wire because there are only two mountting tabs(on the same top metal plate...) i dont find any other mounting spots to put the other wire beside the two that are one the top plate(as i mentioned)
Old January 28th, 2012, 17:13   #6
Sotam123
Sotam123's Avatar
Here is a picture of the inside of the wheel..is there anything missing??? i circled in yellow the two metal tabs to which i can plug my wires but then the horn stay on permanently.
http://img830.imageshack.us/i/imagefsk.jpg/
Old January 28th, 2012, 20:11   #7
where2
where2's Avatar
Your problem is that there is no air gap between those two tabs you're plugging onto. Those tabs are on the same piece of metal. The air gap is what makes a switch a switch. When the air gap goes away, then the two contacts join to make a circuit which sounds the horn. Without that air gap, your horn sounds 24/7 just as you've already found out.
Look around more and figure out how it's supposed to work. Without it in my hand, I cannot tell you were the second wire is supposed to go. There should be some "springs" that separate the parts that make contact when you depress the horn. If you look at your old 4-spoke wheel, you'll see what I mean.
Old January 28th, 2012, 20:39   #8
Sotam123
Sotam123's Avatar
Yeah i took appart the top plate on my old wheel and fout that on the back there are there cooper coloured tabs that make the connection when pushed..on the gti wheel that connection is made too but i think the second qire needs to be pluged on the backside of the steering wheel thru this little square hole next to the main M12 screw.
Im goin to try that tommorow see if i can figure it out..
Old January 29th, 2012, 06:51   #9
where2
where2's Avatar
The links I found on vwvortex show one of the two horn wires not being used. It just got taped up and shoved down the center of the 12 point bolt...
http://forums.vwvortex.com/showthrea...wheels-(moclov)
Old January 29th, 2012, 07:45   #10
Sotam123
Sotam123's Avatar
yeah i figured it out..
the first black wire(at the end of the harness plug should be touching the top metal plate and the wire in tye middle located bettween the 2 airbag wires an the other black wire should be touching the actuall steering wheel or the bolt..
the problem was i was doing the reverse...
also since i dont have any mounting brack on the actuall steering wheel i ended up stripping the last black wire and wrapping iy around the m12 center bolt soo it is guaranteede to stay in contact..
Old January 29th, 2012, 08:23   #11
Sotam123
Sotam123's Avatar
soo is is what it gave me:
http://img51.imageshack.us/i/imageywy.jpg/
final product :
http://img845.imageshack.us/i/imagegfgm.jpg/
Airbag light, steering wheel and horn fuse. BioTodd VW MKIII-A3/B4 TDIs 1 May 10th, 2009 16:59
No horn, no steering wheel controls, HELP!! Bluegrass VW MKV-A5 Golf/Jettas 2 August 25th, 2008 19:48
power sterring pump AlanTDI VW MKIV-A4 TDIs (VE and PD) 3 November 6th, 2007 16:19
steering wheel buttons + horn not working ErikR VW MKV-A5 Golf/Jettas 1 October 22nd, 2006 15:53
vibration (felt in sterring wheel) under load verylongdrive VW MKIV-A4 TDIs (VE and PD) 5 August 23rd, 2005 13:58
Page generated in 0.16087 seconds with 10 queries
[Output: 105.17 Kb. compressed to 88.96 Kb. by saving 16.21 Kb. (15.41%)]
