Old January 27th, 2012, 16:00   #1
doland
Default MK4 golf tdi Cold starting problems
Hi,
I was wondering if any of you guys could possibly help me out, iv done some searches but havent found much luck with things to try !
Iv got a MK4 golf 1.9 TDI PD 115 engine but keep have issues starting the car when its cold. If i turn the key for a second to turn it over then turn it off and then back on again it will start within 4-5 seconds, whereas if i turn the key from start it keep turning over and wont start at all.
I have plugged a code reader into the car and it came up with error code - 17978 and 16705
I have given the car a full service - glow plugs, fuel filter, oil, air filter, oil filter, as i read in places it could be the plugs or fuel filter still no luck.
I believe one of the fault codes is to do with the cam shaft position sensor located next to the cam belt, which i have changed, it got better for a few days then went back to normal.
Since then i have ran out of idea ! if anyone has any advice i would be greatly appreciative.
doland is offline   Reply With Quote
Old January 27th, 2012, 17:05   #2
OlyTDI
TDI(s): '04 Golf
Try searching for "hard start" "cold start" and "glowplug" or try searching using the error code numbers.
There's a lot written about this and it probably is related to your glowplug harness or the connection of the harness to the glowplugs.
2004 Golf GL TDI -- Malone Tuned, Recaros, Nicktane Cat 2 fuel filter, Dieselgeek bypass filter, A4 Defender skid plate, Whitedog intake hose fix, Check Temp III, FrostHeater with bumper mounted plug-in mod (details here), Ventectomy, LED trunk lighting mod.
OlyTDI is offline   Reply With Quote
Old January 27th, 2012, 17:19   #3
Seatman
Seatman's Avatar
Fuel Economy: No idea
Maybe the ignition switch but I'm not sure, 17978
http://wiki.ross-tech.com/wiki/index...8/P1570/005488
My gt tdi estate oem type build thing
2001 Mk4 golf 1.9tdi ALH, Bosio PP764 nozzles setup by Project-power (.co.uk) and custom tune by Nytrix tuning
Seatman is online now   Reply With Quote
Old January 28th, 2012, 00:49   #4
doland
thanks guys il give it a look
Old January 28th, 2012, 06:47   #5
jettawreck
jettawreck's Avatar
You can also check out the coolant temp sensor. If its faulty it won't cycle the GPs for as long as it should. Common failure on the ALH/VE MKIV's, not sure about your model. The GP indicator lamp isn't neccessarily an indicator of how long they are cycling on.
2004 Cadillac SLS (wife's)
jettawreck is online now   Reply With Quote
Old January 28th, 2012, 07:27   #6
LLJ85
Fuel Economy: 49 mpg hwy
I have an 01 that would not start - "shifting into reverse kills engine".
This is what I ended up doing. Get a volt meter, with the key on test the voltage at each fuse and wright it down. I found several with less than 12 volts. Got a wiring diagram for circuits and see what they have in common. Mine was the ignition switch. Replaced the electrical part of the ignition switch and it has been running fine since. Problem was where the mechanical and electrical part of the ignition switch go togather was worn and I believe the was not making full contact, because it was not turning completely, and not getting full power so it would not start.
LLJ85 is offline   Reply With Quote
2011 VW Golf TDI - problems starting/not starting airstreamer TDI 101 3 January 11th, 2012 16:09
TDi 150 Cold Starting Problems Mieke VW MKIV-A4 TDIs (VE and PD) 2 September 20th, 2011 14:08
2004 VW Jetta TDI Cold Weather Starting Problems Gretchw20 Other VW Group TD(I)s 4 December 17th, 2009 18:27
2004 VW Jetta TDI Cold Weather Starting Problems Gretchw20 VW MKIV-A4 TDIs (VE and PD) 18 March 18th, 2009 14:26
2004 VW Jetta TDI Cold Weather Starting Problems (hoping for more responses) Gretchw20 VW MKIV-A4 TDIs (VE and PD) 0 April 4th, 2008 14:51
Page generated in 0.13667 seconds with 10 queries
[Output: 74.07 Kb. compressed to 64.93 Kb. by saving 9.14 Kb. (12.34%)]
