Old January 20th, 2012, 10:30   #1
nashbok
Default ALH Oil Leak - Front of engine
I've got a pretty good oil leak coming from the oil filter housing area on my 2000 TDi Jetta (175k miles).
My guess is the oil filter housing gasket. The plan is to just replace all the seals/gasket on the housing. Is this a common problem? Anything else I should look for?
Thanks!
nashbok is offline   Reply With Quote
Old January 20th, 2012, 10:31   #2
Dieselducky
Dieselducky's Avatar
Check the oil filter cap to make sure it's not cracked
Dieselducky is offline   Reply With Quote
Old January 20th, 2012, 10:37   #3
maxwellp
maxwellp's Avatar
Fuel Economy: 47.25
I just had one like that on my 98 Beetle. It was the oil cooler under the filter housing. I just tightened the large nut on it and it is leak free.
1998 Beetle TDI Malone Tuning Stage 2
2001 Dodge Cummins 5.9
2005 Dodge Cummins 5.9
maxwellp is offline   Reply With Quote
Old January 20th, 2012, 10:51   #4
shagin'wagen
shagin'wagen's Avatar
TDI(s): Bora
Fuel Economy: 5L/100KM
http://forums.tdiclub.com/showpost.p...2&postcount=51
'99.5 Bora TDI - Many mods.
'71 Tin Top Westfalia
'85 Mercedes 300SD - Highway Cruiser
'85 Jetta Coupe
shagin'wagen is offline   Reply With Quote
Old January 21st, 2012, 17:35   #5
nashbok
Default Re:
thanks for the info all. Shagin' is right (and thanks for the write up BTW. there's tons of good info in here but the search feature on the forums is seriously lacking). After cleaning everything off and taking a good look it seems to be the oil cooler.
I assumed the filter housing gasket since the dealer told me if it was the oil cooler seal I'd have antifreeze in my oil -- which I don't.
Old January 21st, 2012, 20:24   #6
paramedick
paramedick's Avatar
Oil cooler seal(s) keeps junction to oil filter stand from leaking.
To get coolant in oil, there would have to be an internal leak of the oil cooler.
Old January 23rd, 2012, 03:01   #7
cbrpaul
I have a AFN front engine oil leak , which also appears near to the oil filter housing !!
I would be very interested in knowing your outcome, thankyou
cbrpaul is offline   Reply With Quote
Old January 24th, 2012, 10:58   #8
nashbok
There's a small leak at the top of the oil filter -- the o-ring doesn't fit very well -- bulges out a bit.
The main leak was coming from the top of the oil cooler. I tightened up the bolt 1/4 turn and that seems to have fixed it for now. I ordered the o-rings from idparts for six bucks (the dealer quoted $19) but haven't installed them.
The biggest issue was cleaning off the engine to locate the leak(s). I had let it go WAAAAY too long and the engine was a real mess.
Old January 24th, 2012, 11:15   #9
alphaseinor
if you need something that cleans really well, use 50/50 simple green spray it down, then let it sit on there for about 20 minutes, then use brake cleaner to wash it off... rinse and repeat... you'd be surprised at the result!
alphaseinor is offline   Reply With Quote
Old January 24th, 2012, 11:25   #10
whitedog
Yes. It's sad that the dealer didn't understand this.
Winters come, and winters go.,
Summers come, and summers go.
Old November 5th, 2013, 15:08   #11
Mk4tdi02
TDI(s): 02 Golf TDI
Looks like my mk4 alh is leaking from the same place. Anybody have those part numbers for those seals. thanks.
Mk4tdi02 is offline   Reply With Quote
Old November 5th, 2013, 18:40   #12
paramedick
paramedick's Avatar
038117070a
Old November 6th, 2013, 03:07   #13
tonbab
There are two gaskets. The other one is the same number as above minus the "a". I just did mine and it was an easy job. Once I got the socket on the nut I realized it was just loose and the gaskets were fine- 182k. Changed them out anyway since I had them.
tonbab is offline   Reply With Quote
Old November 6th, 2013, 07:19   #14
TDI_
TDI_'s Avatar
Fuel Economy: Cool Stuff
Go to the dealer! Much cheaper from them than ordering online Unless you are ordering a whole bunch of stuff and have free shipping lol
Very First TDI_ 1998 Jetta (300)7,000 Miles On The Clock and Going Up Fast!!!
TDI_ is offline   Reply With Quote
Old November 16th, 2013, 06:21   #15
Mk4tdi02
TDI(s): 02 Golf TDI
Thanks Gents! Will do these before it gets too cold.
...OIL LEAK AT OIL-FILLER CAP of ALH engine... MrSafety VW MKIV-A4 TDIs (VE and PD) 26 December 1st, 2012 19:30
Oil Leak from front of engine vanhoand VW MKV-A5 Golf/Jettas 6 November 9th, 2011 06:01
Oil Leak in front of engine bay Badr VW MKIV-A4 TDIs (VE and PD) 4 April 12th, 2011 18:01
Small oil leak? front of engine, above oil pan. jyankus TDI 101 12 February 18th, 2008 17:51
B4 Oil Leak on Front of Engine Steve777 VW MKIII-A3/B4 TDIs 10 June 8th, 2004 07:01
Page generated in 0.14686 seconds with 10 queries
[Output: 122.88 Kb. compressed to 101.75 Kb. by saving 21.13 Kb. (17.19%)]
