Old January 19th, 2012, 16:53   #1
Combine17
Fuel Economy: 50MPG+
Default Transmission Speed Sensor GEAR???
Im in the process of replacing my speed sensor.
turns out there is a gear inside the transmission? But it looks broken to me!
I tried google for answers but cant find anything...can anyone confirm that if its broken.
Here is the picture. Its the left side (near the gear) i think the whole rod is suppose to be bigger because when i look inside the transmission hole where the rod was i think i i see another piece...plus the end of the rod seems to be broken off (near the gear)
Can i get this new part from somewhere....where do i go from here? :S
Combine17 is offline   Reply With Quote
Old January 19th, 2012, 17:53   #2
AndyBees
AndyBees's Avatar
Based on the two I have laying on the shelf, looks like you got it all out! Not broken!
Why did you have to remove it?
'84 Vanagon '02 ALH TDI engine(32 to 35+ MPGs consistently) Malone Stage 1 tune. Road trip to Nova Scotia 2013. Road trip to Alaska summer 2014 & 2016, 11k & 12k miles. 80k miles on install, Jetta Cluster odometer currently at 209k miles.
AndyBees is online now   Reply With Quote
Old January 19th, 2012, 19:11   #3
rt_hawk
rt_hawk's Avatar
Fuel Economy: 40-TDI, 14-7.3 PSD, 32.9-Triumph
I just replaced my VSS too and it does look broken to me. Mine had aproximatley an extra inch on yours. Dealer would be the best bet to get the bottom piece for the VSS. If you have an auto that sensor (g68 I think) just runs the speedo and cruise, so it won't effect shift points or driveability. Good luck!
-Sean - I have vag-com
-08 F-250 6.4 CCSB, dpf-del., h&s, DIY-CAI, diy egr delete & coolant bypass.
-06 Jetta TDI GLS DSG, 100k, DIY zerostart heater, tune and egr delete soon...
rt_hawk is offline   Reply With Quote
Old January 19th, 2012, 19:42   #4
rt_hawk
rt_hawk's Avatar
Maybe autos are different??
Old January 19th, 2012, 22:56   #5
Combine17
what does VSS stand for?
so is it broken or no? and it came unscewed while i was replacing my speed sensor...so i took it out to see what it is and thats what i found....anyone know the part number or cost? idparts doesnt have it
car is 2001 Jetta TDI, 5 Speed
Old January 20th, 2012, 00:35   #6
rt_hawk
rt_hawk's Avatar
VSS - Vehicle speed sensor, I think it's broke... there should be a taper on the end of the shaft you use to check the fluid level in the differential...I'd just take it to the dealer, they can get the part number and part.
Old January 20th, 2012, 00:38   #7
rt_hawk
rt_hawk's Avatar
I'd see if it works with the new speed sensor, if it does throw some black rtv on the threads, to prevent differential leaks, and call it good.
Old January 20th, 2012, 04:45   #8
AndyBees
AndyBees's Avatar
Well, if part of it is still in the tranny, the new one will not screw all the way down!
Old January 20th, 2012, 06:00   #9
Combine17
Thats the thing...i cant tell if its floating around in the tranny or of its just sitting there...its screws all the way down.
but the real reason why i changed the speed sensor was because of "slow down shudder" When i had it unplugged the slow down shudder didnt happen. Now when its plugged in it still happens.
So i dont get it...does it have to do something with the broken gear end? or a blown fuse maybe?
Old January 20th, 2012, 06:05   #10
Combine17
also i had my injection quantity changed before...it was good for about half hour..then i shut off the car and let it sit for another half hour....started it up and the quantity jumped back to the original posistion it was at (when it was shuddering) i believe it was at 1. and i changed it to 3.
Old January 20th, 2012, 07:22   #11
KLXD
Wadaya mean by bigger? Longer?
Take a picher that shows the end better where you think it's broken. It looks ok to me.
Except the oil. Looks nasty.
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
Old January 20th, 2012, 09:27   #12
rt_hawk
rt_hawk's Avatar
Like this...http://i1140.photobucket.com/albums/...0/2648273b.jpg
The manual one may be different, the one in the pic is for a 01m, the taper is used to check the fluid level.
Old January 20th, 2012, 11:45   #13
Combine17
so most likely mine is broken....would that have any effect on "slow down shudder" ....like i said when my speed sensor was disconnected i didn't have a slow down shudder problem.
Old January 20th, 2012, 15:15   #14
rt_hawk
rt_hawk's Avatar
Slow down shudder is caused by injection quantity being off, should be between 3 and 5 mg. Go to TDI 101, go to the how to's and look up hammer mod. You need vag com to do it, your IQ can only be adjusted so much electronically, your pump probably needs a physical adjustment.
Old January 20th, 2012, 19:38   #15
AndyBees
AndyBees's Avatar
Its to check the "differential oil" which is separate from the transmission fluid in the 01M Automatic! (per the Bentley)
I just checked the two VSSes in my stock. One of them is obviously from an automatic because the part past the gear is just a little over 1.5 inches long and does have the smaller end for checking the differential oil level.
The other VSS between the gear area and the threaded area is shorter. I do know it come from a 5-speed. However, I cannot elaborate on the gear and beyond because I have cut that part off for custom use in my conversion project.
Transmission Speed Sensor scooperhsd TDI 101 4 May 22nd, 2011 05:56
Transmission Speed Sensor Help! cgi2099 TDI 101 9 September 24th, 2010 08:13
Transmission cannot get in gear 01 5 speed CrazyTDI VW MKIV-A4 TDIs (VE and PD) 5 August 10th, 2010 14:22
Speed Sensor Code causing transmission 1st and 5th gear loss minjablue TDI 101 6 March 12th, 2007 16:56
Speed Sensor Code causing transmission 1st and 4th gear loss minjablue TDI 101 1 March 11th, 2007 23:38
Page generated in 0.18710 seconds with 10 queries
[Output: 127.34 Kb. compressed to 105.74 Kb. by saving 21.60 Kb. (16.96%)]
