Old January 15th, 2012, 20:50   #1
escheffler1985
Fuel Economy: 47.46
Default valve cover gasket 2000 jetta tdi
does anyone know if they make a gasket for the valve cover on a 2000 jetta tdi ALH? or do i have to buy the whole damn valve cover?
thanks!
escheffler1985 is offline   Reply With Quote
Old January 15th, 2012, 21:36   #2
Vince Waldon
Vince Waldon's Avatar
Some reading material for ya:
http://forums.tdiclub.com/showthread.php?t=99227
http://forums.tdiclub.com/showthread.php?t=335248
http://forums.tdiclub.com/showthread.php?t=324580
http://forums.tdiclub.com/showthread.php?t=294013
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is online now   Reply With Quote
Old January 15th, 2012, 21:40   #3
whitedog
Whole cover.
Winters come, and winters go.,
Summers come, and summers go.
Old January 16th, 2012, 18:26   #4
Powder Hound
Powder Hound's Avatar
Just clean the old one off. You shouldn't need to renew it unless someone left it for mice or a hungry neighbor child to chew on while you were doing something like, oh, a week long timing belt change. But, in the worst case, I guess buying the whole thing will be your best solution just like everyone above me said already. Nope, no separate part.
Old January 16th, 2012, 18:30   #5
btcost
btcost's Avatar
Fuel Economy: using Fuelly. . 33ish for now
you have 2 options:
get a new valve cover
remove, clean, seal with rtv type sealent (reinz is a good one) and re-install.
I rocked a "sealed" cover for years, and just did the same to my cousin's car. it works fine.
2012 JSW platinum grey, Euro mirrors, euro switch, front & rear fogs, DG Panzer plate, euro hitch, towing springs & Parktronic (not finished yet)
1987 300DT: Blistein HD's, 16" CLK wheels, euro headlights w/levelers
URL=http://www.fuelly.com/driver/Btcost/jetta][/URL]
btcost is offline   Reply With Quote
Old January 16th, 2012, 19:26   #6
escheffler1985
Fuel Economy: 47.46
ill pull it off and take a look!
danke!
Old March 10th, 2015, 07:24   #7
mrseadog
TDI(s): 2002 Jetta
This is an old thread but I thought I would throw in my 2 cents/experience. Yes it is possible to purchase just the gasket for the ALH tdi engine valve covers. I found them at HansAutoParts.com / eMiata.com. They are $5.50 plus shipping. That said, the real job is getting the old gasket off and the valve cover clean. VW glues the gasket to the cover which makes them extremely difficult to remove, but not impossible.
I found the replacement gasket fit perfectly. You will end up using some sort of adhesive to bond them to the valve cover before reinstalling the cover.
mrseadog is offline   Reply With Quote
Old March 10th, 2015, 07:37   #8
whitedog
I would rather buy a new valve cover assembly than buy a piece of garbage gasket from Prothe - AKA HansAutoParts.com.
Old March 10th, 2015, 17:35   #9
mrseadog
TDI(s): 2002 Jetta
I posted only to point out the gasket itself can be purchased to answer the original question. Not to debate the person selling it. To each his own whether or not one wishes to spend upwards of $200 for a new cover & gasket, use one of the other sealing methods mentioned above in this thread, or to go through the work to replace the gasket.
If the gasket was garbage with regards to fit or material I would have commented as such. I was satisfied with the product but cleaning the valve cover was a real pain in the ass.
Old March 10th, 2015, 17:57   #10
AndyBees
AndyBees's Avatar
Down through the years, I purchased three extra used valve covers for the ALH engine at for cheap prices. I placed them on a custom made support tray under the rain drip of my garage. After months of getting beat with rain water and the gasket given the opportunity to expand back to it's original shape, they seal just fine ...... and, are nice and clean.
So, I just rotate valve covers as needed ...
To those environmental minded individuals, the rain drip has crushed stone with leaves on top. The synthetic and Dino oils, as well as soot, biodegrades proto ... or, those night crawlers like the stuff!
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
Old March 10th, 2015, 18:02   #11
Joester
Joester's Avatar
Fuel Economy: 52/42/28
Oh man I had a good laugh at this, I love us diesel guys.
2002 VW Golf 4dr 5spd TDI ---- Malone stage 4 - Borg Warner BV-39 - PP520 Nozzles - South Bend Stage II Daily Clutch - TacoTaco Intercooler - Bilstein Sport Shocks and Struts on H&R Sport Springs - 17x7 Long Beach Wheels with Bridgestone S0-4 Summers - General Altimax Arctic on Stock 15s for Winter
Joester is offline   Reply With Quote
2005 Passat TDI Valve Cover Gasket MATsam12 TDI 101 7 July 26th, 2012 09:23
mk4 tdi valve cover gasket Makdaddymac TDI 101 7 June 8th, 2010 19:21
Dealer wants $547 for Valve Cover Gasket replacement force me to buy new valve cover honesttussey TDI 101 11 May 4th, 2008 10:02
Valve cover gasket for 2001 Jetta redbarchetta VW MKIV-A4 TDIs (VE and PD) 8 May 27th, 2007 11:18
Valve cover gasket for 2001 Jetta redbarchetta General VW Discussion 0 November 1st, 2005 14:39
Page generated in 0.16656 seconds with 10 queries
[Output: 103.98 Kb. compressed to 88.14 Kb. by saving 15.84 Kb. (15.24%)]
