| TDI Power Enhancements Discussions about increasing the power of your TDI engine. i.e. chips, injectors, powerboxes, clutches, etc. Handling, suspensions, wheels, type discussion should be put into the "Upgrades (non TDI Engine related)" forum. Non TDI vehicle related postings will be moved or removed. Please note the Performance Disclaimer. |
January 17th, 2012, 20:00
#16
on hiatus
The new Bosch CRI injectors are .117 but support 140hp, these flow more than the .234 Titans. Hole sizes are going down but flow volume is going up as well as reduced production variance nozzle to nozzle.
Hole size does not always mean a higher peak volume when it comes to high pressure high velocity fluids. The design and shaping of the holes determine the flow more than the diameter. Of course if you blow the tip clean off, hole size wins in this case
January 17th, 2012, 21:04
#17
Originally Posted by Texas_sky
so anyone else running bosio or titan .234 nozzles on a alh w/ stock vnt 15 ? if so what tune are you using in conjunction with the nozzles?
I'm running the PP764's on a standard turbo and no tune yet, hoping to get it this year. Smoke is a light haze at most but the extra torque is really nice especially uphill. It's funny actually, the other night my friend and I were out and about, he has the evry mod on his car. Anyway he switched it on and planted his foot, I gave mine a bit of foot in 4th and thrashed him lol, all his did was smoke. I get a nice even power all the way to 4500rpm.
January 18th, 2012, 06:22
#18
Originally Posted by Drivbiwire
Just my plug here I guess. I have titan 520's and they dynoed identical to my power plus 764's. Both were tuned for acordingly and regardless of the tune adjustments neither varied from each other more than 5 hp.
Take it for what it's worth but I would just find the BIGGEST hole nozzle and have it shimmed/tuned to what you need. You can cut fuel out hard to request more than the nozzle can provide though.
Not disagreeing with what Drivbiwire has to say on purpose, but I think the R520 nozzles with .260 diameter holes always perform better than the pp764 that are supposed to "out flow" everything and compete with race520's (or close to them)
I'm of the opinion now a day that flow is to some extent a lot of hogwash. Your fancy calibration tests are cute, but real world application where the fuel temp varies along with the pressure of the IP due to RPM your $$$$$ machine just doesn't seem to match the real life data =(
424,000 miles and counting, On the frame that is (as of sold date)
Gt2256v 3 in downpipe and vibrant resonator, 3in OMI and FMIC all by Whitbread, Titan 520's, Port & Polished Head courtesy Franko6, RC 6, 11mm IP, PD LiftPump. Rosten Rods, PD150 Pistons, Oil Cooler, Fuel Cooler, Diablo W/M Kit,DC III clutch, Built 5 speed with LSD
January 18th, 2012, 07:22
#19
The cr makes up for smaller size by running higher and more stable pressure. Also, the cr doesn't have to work against the pilot/main spring as it is piezo actuated. EDIT: Almost forgot, they run more holes on the CR too!
Also pressure ratio alone doesn't tell the full story:
Lets say we have CR 1500 bar, VE 1000 bar, and a guess of 150 bar avg in cylinder.
Without cylinder pressure CR is 150% higher pressure.
With differential to cylinder pressure (1500-150)/(1000-150) x 100 we get 158%, meaning that higher pressures help in the real world where the injector is injecting into an already pressurized cylinder.
Titan 764,11mm IP,VNT17@1.6bar,3 bar MAP,ColtStg2,Whitbread Ported Head,ebay FMIC,2.5"exhaust+cat,lift pump,Koni Reds,wagon springs
January 18th, 2012, 08:11
#20
I spoke with Malone and he recommended that I go with a Stage 2 tune, and when I upgrade my turbo go to stage 5..... I do have a 11mm pump, so that might be a bit different for you.
-Dave
VAG-COM owner
2001 GL, Stage 2 Clutch, Lightweight Flywheel, Dieselgeek Racepipe, Titan 764's (.234)  Ceramic brake pads, 11mm Injection pump IN! 10/30/2011, Bilstein TC Sports front & back!
January 24th, 2012, 15:25
#21
Fuel Economy: unknown at the time, waiting for engine swap
Due to the fact that I'm going to be running a stock turbo (for the time being) and stage two tune, I'm gunna go with the PP764's. Seem to have better real world results over the Titan Nozzles from the testing you guys have done.
thanks to all who have put forth their intuition and technical data into this topic... will be nice just to get this car out on the street and put the hammer down to see what a modified diesel machine can do!
January 31st, 2012, 04:51
#22
Fuel Economy: 42 mpg average (mk4) 38 mpg average (mk5)
Hey guys! I'm wondering what Tune to go with. I also have Titan 520s (.216) injectors on my stock turbo and I'm ready to have it tuned now. What tunes are you all going with?
January 31st, 2012, 05:17
#23
Depending if you have other supporting mods I think that you can safely run a stage 2. The tuner of your choice will be able to set you up correctly once he knows what hardware you have.
April 13th, 2012, 16:06
#24
Who say shat Titan 764 is 0.234?
I bought them this week, but they make the same fuel as my old 0.225 German "dieselcontor" nozzles. I see this because of boost i need to burn the fuel at the same fuel map settings. I made test 60-160km/h run - the result with Titan was not better, it was near the same but without any smoke. I To burn fuel with this nozzle i need 1.65 bar.
I wonder, or German seller ships me 0.240 or 0.260 nozzle (he had 225, 240 and 260 sizes), or this Titan 764 not 0.234 but smaller!
Any ideas?
(I edit this topic, because after 30 min ride with vag-com. Last ride was shorter and not so correct)
Reason: re-ride it
April 14th, 2012, 09:50
#25
If the titan is making the same power but without smoke, it may be bigger and better atomization of the fuel, but with smaller window. I dislike it when people compare nozzles at different smoke levels. Also, they say that they have to adjust the nozzles pop pressure to get them to flow a bit more than PP764.
From what I have seen, the Titan nozzles have a slightly bigger needle, more inertia for the injection event. Maybe this helps the nozzles work well in midrange but not top end. OR maybe these nozzles change the injection timing, so you may be getting less timing at the top end. There are too many variables to take account for with nozzles. What matters to me is the fuel econonomy and smoke level for a given power level!
I can say that they are leaps and bounds better than my bosio sprint .216 nozzles. Those nozzles were running very good balance too, but it may just be that my tune prefers nozzles in the size of PP764. I haven't balanced either set. The titans measure less than +- 0.30 on each nozzle in group 013!
April 15th, 2012, 12:48
#26
I am completely happy with my setup personally. Check out my signature for what I have man. I am soon doing FMIC not SMIC with 2in piping, and 2.5inDP w/ 2.5in catback and then prolly VNT17. The PP764's allow you to perform better as you upgrade the car, do it right the first time IMO
PP764, Kerma tune, swiss-cheesed airbox, VR6 clutch kit, boost gauge Koni STR.T struts, 14in BMW bottle cap rims and more to come
April 17th, 2012, 11:10
#27
R520 it the right way i think.
I just ask about "why Titan764 are so small" because i compare it to 0.225 and feen no difference in power and cant see smoke at the same boost as i had with 0.225.
I think they are really 0.216 764 with some more needle volume.
April 17th, 2012, 16:40
#28
It can be bigger than .225 and give same power but less smoke. That depends on the injection window and spray quality. That is why some people years ago when .205 was popular, were making same power as people with stock .184, but with less smoke. Also, they got better economy even though holes were bigger!
With the Titan, you might be able to change IQ to a lower number at idle to give more fuel, as I was able to do. I went from .216 to Titan764... from a bit of smoke to none, with IQ adjustment (hammer mod) I was able to get the same bit of smoke back by making the pump inject more, with an increase in power.
BTW, in previous posts Drivbiwire explained that the size of the holes don't explain everything. That is where pop pressures and injection windows come in, which are tuned by someone who balances injectors, like him or Frank06.
May 2nd, 2012, 15:22
#29
Something *** strange. After long time vag-com-log i saw, that actual boost are lower than requested, and full go-pedal was 2620-2670mbar.
I chipped before for my pre-0.225 nozzle, and actual were=request. Full go-pedal holds 2700mbar easy.
So, only one on my mind - this titan 764 are smaller?
Yes, it's nise for smoke-level, but they feels like "smaller".
the IQ with my old 0.225 and new titan 764 set to 6mgR, if i set 5 or lower - it make some shake with light load (example "AC on") at iddle.
As i wrote before, maybe i had bigger than 0.225 (0.240, 0.260 was on shop) because of blind-eye seller  .
who exactly test titan's by flow?
May 2nd, 2012, 16:02
#30
That shake thing seems to be a common problem with the AHF engine itself
