Old January 12th, 2012, 21:25   #1
jacksonvilleTDI
Fuel Economy: 46mpg nice city, 55 highway, 42 mixed driving to get there ASAP
Default bluetooth auto play problem
I noticed my phone battery is dying very quickly because every time i start the car the stereo starts streaming music from my phone(via Bluetooth).
I DO NOT have the auto play checkbox(in setup menu) checked and dont see other options to disable it.
Did anybody else have the same problem.
Is this a bug across the board or is it just my car.
I have tried 3 other phones with the same result.
Also tried checking the box and unchecking again but no fix.
jacksonvilleTDI is offline   Reply With Quote
Old January 13th, 2012, 11:23   #2
IceRaider360
IceRaider360's Avatar
Fuel Economy: 4.7 L/100km
Not sure on this one, I have a 2011 Golf with the RCD-510 stereo and use a Galaxy Nexus S Android phone for bluetooth music streaming and haven't run into this problem hopefully someone will chime in on this.
IceRaider360 is offline   Reply With Quote
Old January 13th, 2012, 11:59   #3
Past_VNE
I have the same problem with both my husband's iPhone and with mine. I would LOVE to turn off this "feature" if possible. It's not just you, JAXTDI.
-- Jaclyn: Pilot, Mama, TDI Lover
2012 Tornado Red/Cornsilk JSW 3-pedal, pano, no nav, 13,400 miles as of New Year's.
2001 Jetta TDI 5-spd, chip, turbo, injectors, VR6 brake conversion, Evo SS skid plate, 185k miles
2002 Ford F-250 Power Stroke 4x4 --1988 Ford Thunderbird 5.0L, my first car....highly modded
Past_VNE is offline   Reply With Quote
Old January 13th, 2012, 13:43   #4
chris@revotechnik
chris@revotechnik's Avatar
Does this on my 2012 as well both my iphone and focus S (wp7). On the iphone it was a pain since I"d get to work and sync the phone it would then delete all the podcasts that played in the background on my way to work. luckily it doesn't do that with the wp7 but it does keep playing and drains the battery.
The bluetooth auto play just means that when you get into the car and turn it on it will switch from whatever media source was playing to the bluetooth. If you have that off it doesn't change over but it still triggers play on the phone and will just play silently in your pocket.
Android phones have an option to actually manually turn off BT audio which is why people with those don't seem to have a problem. However I had a Sony with BT audio in my cherokee and it didn't autoplay my iphone like the JSW does.
http://www.revotechnik.com/
REVO
chris@revotechnik is offline   Reply With Quote
Old January 18th, 2012, 19:35   #5
jacksonvilleTDI
ok here is what i did on android go to BT settings, find your car that was paired, uncheck the BT Audio checkbox and it works.
I can still play everything but it does not start streaming music when you turn on your car.
Old March 15th, 2012, 08:31   #6
geraldvol426
Fuel Economy: 38.69
I have the same BT problem on my 2012 Passat. Even after I change back to FM or SAT, the radio will just switch back to the iphone. It may do this every few minutes and repeat several (5-6) times VERY frustrating as the sound levels are different and can blkow out the speakers. Anyone have solutions. My dealer doesn't have an answer and Apple does not have a solutioni either.
geraldvol426 is offline   Reply With Quote
Old March 15th, 2012, 08:40   #7
maxedtdi
maxedtdi's Avatar
All 2012+ do this, 2009-2011 don't have this feature.
maxedtdi is offline   Reply With Quote
Old March 15th, 2012, 09:01   #8
goldgary
Count me in. Does it to my "non smart phone" I do not have any music on my phone, but I always have to cancel "no songs found" button on phone. It would be a real pain if I had music on phone.
I too am looking for an answer on this issue.
thanks, Gary
goldgary is offline   Reply With Quote
Old March 15th, 2012, 09:17   #9
Sweeps
Sweeps's Avatar
I disconnected this feature through VCDS.
This solved the problem.
Steve
- MK4, MK5, MK6 Jetta TDI's in the past
- 2013 Outback 2.5i - wife's commuter
- Subaru Demo
- 02 BMW 330i - weekend fun.
Sweeps is offline   Reply With Quote
Old March 15th, 2012, 09:50   #10
mamock116
mamock116's Avatar
+1 to having the same issue. So lame.
mamock116 is offline   Reply With Quote
Old March 15th, 2012, 15:47   #11
Kebbat
TDI(s): 2012 JSW TDI
I'm also having this issue. Additionally, it is a real pain in the rear to get music to play from my iPhone using the MDI cable. It shows all of the contents of the iPod feature of the phone, but it often will not play them. And, when it finally does play a song, the song /album information is often incorrect.
Kebbat is offline   Reply With Quote
Old May 2nd, 2012, 21:16   #12
blueclaws
TDI(s): '21 Golf TDI
Peeps, I feel your pain. I hate that I have to manually press stop on my iPhone everytime I get into my car and turn on the ignition.
After talking with VW and Apple about this, I've found that the culprit is Apple. They suggested I make a formal request to have this "bluetooth autoplay" option as a disable-able parameter in our phones.
If you have a moment, go to the Apple feedback website and hopefully the next software release will fix this. God knows it will make me happy. Spread this to other threads and forums for this problem, and maybe we can crowdsource Apple to get this fixed!
http://www.apple.com/feedback/iphone.html
Here is what I put down, for reference:
"Whenever my bluetooth-enabled car connects to my iPhone 4, even when the radio is off, my iPhone automatically plays the first available music source (iTunes or Pandora). No music is heard by me because the radio is off and the iphone is playing via the bluetooth. When I turn on the radio, I can hear that the phone has been playing the entire time the car's been despite no command to play music. This ends up being a big drain on my battery and data (pandora) if I don't go to my phone after turning on my car and hit stop on the playing music.
I suggest there be a parameter to turn off autoplay within the bluetooth system commands of my phone."
blueclaws is offline   Reply With Quote
Old May 2nd, 2012, 23:15   #13
TDI_Timmy
TDI_Timmy's Avatar
It would be nice for Apple to add a toggle - my money is that they won't do that. Not very user friendly to have more steps to go through when setting something up.
It is really something wrong with the software of the new HU's. When I uncheck the autoplay box on the HU it SHOULD NOT autoplay the music on my phone. For whatever reason the HU is sending some sort of signal to the phone to start playing music.
And to add - this drives me crazy too.
2012 JSW DSG sunroof - white - "Wally"
2004 Chevrolet Aveo - red - "Lil' Red"
1967 Ford Fairlane 500 convertible - converted to 5 speed manual - red - "Betsy"
TDI_Timmy is offline   Reply With Quote
Old June 4th, 2012, 09:56   #14
Donkeyshins
Fuel Economy: 36.4
Same frickin' problem here with my Lumia 710 WP7 device. I'll talk to folks I know at Microsoft about whether this can be made configurable in some future release.
-D
Donkeyshins is offline   Reply With Quote
Old June 4th, 2012, 16:12   #15
fgiraffe
Not sure I buy that. Other cars with similar BT playback capability do NOT have the Autoplay problem with the iPPhone, so the blame cannot be all on Apple.
fgiraffe is offline   Reply With Quote
Bluetooth Audio and auto-starting from iphone 4 James' MK6 TDI VW MKVI-A6 Jetta Sedan (~ 2011+) 132 February 15th, 2015 13:21
bluetooth problem sportwgn VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 4 April 21st, 2011 15:05
How to stream/play music via bluetooth ncvw97 VW MKV-A5 Golf/Jettas 4 December 30th, 2009 21:56
Let's play a game... guess the problem SilveR316 TDI 101 28 September 15th, 2008 07:08
Problem with Wheel Bearing Play Or??? Beowulf VW MKIII-A3/B4 TDIs 19 April 10th, 2004 00:11
Page generated in 0.16398 seconds with 10 queries
[Output: 123.73 Kb. compressed to 103.20 Kb. by saving 20.53 Kb. (16.59%)]
