Old January 11th, 2012, 15:59   #1
gpvideen
TDI(s): 03&06 Jettas
Default Exhaust system warning light illuminated in my 06 Jetta TDI
I hooked the vagcom up and found the fault code:
008213 intake Manifold flap Position Sensor (Bank 1)
P2015 000 Implausible Signal Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 12
Mileage: 144644 km
Time Indication: 0
Date: 2000.00.00
Time: 16:30:47
I looked in my Bentley and it appears this part is on the back of the intake manifold - part # 03G-128-063A. Can you give any suggestions as to how to change the part? Or, if it can possibly be serviced?
gpvideen is offline   Reply With Quote
Old January 11th, 2012, 16:05   #2
bluesmoker
bluesmoker's Avatar
Fuel Economy: 57 highway mpg
its probably the anti shudder valve, sometimes the little gears strip and it throws a mil
this should help
http://www.youtube.com/watch?v=BoPBZ---fJo
a good parts supplier
http://www.idparts.com/catalog/produ...oducts_id=1946
2004 pd 5 speed tip,malone tuning stage 1.5 with egr delete
former:1998 red jetta 5 speed man, malone tuning stage 1 with egr delete (it still lives in Maple Ridge)
new gas guzzler: 2001 Mercedes Benz Ml 320
bluesmoker is offline   Reply With Quote
Old January 11th, 2012, 17:03   #3
gpvideen
Thanks, it looks like a simple project!
Old March 12th, 2012, 10:01   #4
janssen_nicholas
janssen_nicholas's Avatar
I seem to have a similar issue, however I think mine is the intake flapper and not the anti shudder valve. Is this the same part or are they separate components? A nasty clicking noise happens when I turn the car off and it comes from the electrically operated intake flapper valve right on the rear left side of the engine where the rubber hose clips onto the valve hardware. (when looking at the car from the front)
VCDS showed the following code:
1 Fault Found:
008213 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 254
Mileage: 148484 km
Time Indication: 0
Date: 2000.00.00
Time: 17:06:17
Freeze Frame:
RPM: 966 /min
Speed: 12.0 km/h
Load: 5.1 %
Voltage: 14.14 V
Mass Air / Rev.: 185.0 mg/str
Duty Cycle: 76.9 %
Bin. Bits: 00000000
Readiness: 1 1 0 0 0
I have heard this flap operates with a plastic gear and I'm assuming this is the issue. Would the replacement be the same as the link above?
janssen_nicholas is offline   Reply With Quote
Old March 12th, 2012, 13:14   #5
D-Cell_Mekanick
Fuel Economy: 45ish
Same part.
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Mileage: 148484 km
Time Indication: 0
Date: 2000.00.00
Time: 17:06:17
Freeze Frame:
RPM: 966 /min
Speed: 12.0 km/h
Load: 5.1 %
Voltage: 14.14 V
Duty Cycle: 76.9 %
Bin. Bits: 00000000
2014 Passat SEL TDI(GONE BUT NOT FORGOTTEN). Tungsten Silver exterior with Titan Black interior. I have VCDS HEX-USB+CAN, still learning how to use it.
D-Cell_Mekanick is offline   Reply With Quote
Old March 12th, 2012, 14:36   #6
MyAvocation
MyAvocation's Avatar
It's the same part, which performs several duties, but is the only flap on the intake. Instead of buying a new ASV, some have fabricated a new gear out of scrap plastic.
"Never trust Internet quotes." - John F. Kennedy
MyAvocation is offline   Reply With Quote
WHy is my engine exhaust light solid illuminated kpiazzisi VW MKV-A5 Golf/Jettas 26 October 4th, 2010 17:19
Engine exhaust light illuminated today...why kpiazzisi TDI 101 8 September 28th, 2010 17:30
Light out (Warning Light) 06 Jetta... dieselimblut TDI 101 7 December 17th, 2009 14:14
Hight temp warning light 06.5 TDI Rick DD VW MKV-A5 Golf/Jettas 2 August 6th, 2009 16:04
Exhaust system warning light? daleho1 VW MKV-A5 Golf/Jettas 4 July 21st, 2007 12:31
Page generated in 0.14009 seconds with 10 queries
[Output: 77.64 Kb. compressed to 68.04 Kb. by saving 9.60 Kb. (12.37%)]
