IDParts now has two solutions to fix 5-speed manual transmissions in MkIV Jetta TDI, Golf TDI or New Beetle TDI that have worn shifter assemblies and shift difficultly or have grinding problems.
The Shift Tower Repair Kit replaces the shift tower components, including the ball-bearing guide sleeve. The shift tower moved up and won but should not move side-to-side. Worn shift tower components will allow the tower to shift around and make the car difficult to shift into and out of gear.
The Gear Selector Repair Kit for MkIV manuals replaces the gear select lever on the top of the shift tower. This lever system uses nylon-bushing guides that are starting to wear through, once again knocking the shifter out of alignment. The new gear selector comes with two new bushings, a new guide channel and a new end clip.
Hard shifting can also be caused by old or incorrect manual transmission fluid. Refresh the fluid with new VW OEM G 070 fluid for better lubrication.
